Ford 4000 Industrial - Alternator Problem
   / Ford 4000 Industrial - Alternator Problem
It's normal to just have the nut holding the pulley and fan to the alternator shaft, most of them turn so that the nut is trying to tighten during operation. There is probably a hex hole in the front of the shaft to get on it with an allen wrench to hold it, but I've never had any problem taking a pulley off with a rattle gun, just hold the fan with a gloved hand or heavy rag.
You should be able to get a rough idea of the diameter and get a replacement; I probably have three or four out in the shop that would work. If you can't find the exact size it shouldn't matter as long as it's not so drastic as to require a different belt size.
I'd be curious to know how it broke; I can sort of imagine how one would fail if it was too tight, but I would have thought that the bearings would fail first.
flyerdan,
I was able to remove the nut. Although there is a hole in the front end of the shaft as you mentioned, it doesn't seem to be hex. But I was able to remove it by hanging on to the fan blades.
I couldn't tell you for sure what made it break. I do know that it occurred while I owned it. That belt also drives the water pump, and, no surprise, the tractor overheats in just a few minutes with nothing to push the coolant around. That behavior only started recently. The only diagnosis I could come up with is that the belt was oily, and so it probably made the belt slip, leading to the over-tightening. But what you said makes sense too, i.e. that the bearings would take the abuse initially. The shaft seems to spin smoothly as near as my fingers can tell.
It's good to hear that I should be able to find a pulley by simple steps (shaft hole size, V-belt type, belt-width, and getting reasonably close to the outer diameter). Maybe I'll try a different auto parts store.
Thanks!
ovrszd and aczlan (and all),
I imagine you're right that the belt being too tight didn't break the pulley. I just don't know of any other causes (yet).
You mentioned that I should consider buying a new alternator, and that I should consider converting to 12-volt. Originally, when I was figuring I'd keep this tractor, I had considered that conversion. And, in fact, I still would consider it even though my intent is to sell it -- as long as it didn't cost a ton, and as long as it is within my capabilities.
Here is a list of the issues/questions I came across. Feel free to stop reading whenever you like. :)
Q1: I assume that, as I'm converting from 6 to 12 volt, I would also convert from positive-ground to negative-ground -- agree? If so, that leads to additional questions below.
Q2: Would I go with one of those kits that are for converting from 6-volt to 12-volt? I imagine yes. However, as I look at the various kits, there are a number of questions, ambiguities, and inconsistencies. Examples listed below, with questions.
Q3: I found a kit that might apply, but, in the lengthy list of which tractor models & years it applies to, although it includes 1964 Ford 4000, it then says "does not apply to Industrial models", which is what I have. Do you know what difference there is between an Industrial and a non-Industrial, such that this electrical conversion kit would not apply? (FYI - that product page did not happen to include a link to a kit that would apply to Industrial.)
Q4: One kit includes the alternator, wire harness, and mounting brackets, but nothing else. That kit specifically states that it doesn't include the coil because "the ignition system remains at 6 volts". Meanwhile, another kit (different manufacturer, different seller) includes the coil. How would I decide if I should change the coil or not?
Q5: At least one kit refers to the question of whether my tractor's proofmeter is driven off my generator. My guess is that, since the current one is a one-wire alternator, it does not drive my proofmeter. Correct?
Q6: My search also introduced me to the term "self-exciting alternator", with one forum member stating something about requiring the engine to be running at higher RPMs in order for the alternator to actually charge the battery, and the response was that the 3-wire versions were better in that respect. Is that true? And should I care about that and change to a 3-wire alternator? Here's a basic question demonstrating my lack of experience in this area: Given that the current configuration expects a 1-wire alternator, if I were to convert to a 3-wire alternator, where do the other 2 wires go?
Q7: When talking with a friend about converting to 12-volt with negative ground, he also mentioned the starter. A number of people in forums have said that sending 12 volts to a 6-volt starter is okay -- it'll just spin faster. But even if true, he asks if the conversion from positive-ground to negative-ground would cause the starter to run backward, such that I would need to replace that too. And yet, none of the "kits" or the forum discussions that I've found mention that concept. What do you think?
Q8: Along those same lines, I'm guessing that alternators themselves are also specific to positive-ground vs. negative ground. Is that right?
Q9: Going back to question 7 regarding the starter: My friend said that perhaps it makes sense to convert from 6-volt to 12-volt, but leave it at positive-ground. His point was that I could avoid buying a starter. Of course, by making that decision, that would affect the other things too, e.g. the alternator would need to be positive-ground, and I'm not sure how easy it would be to find one like that.
Q10: One kit mentioned the need to change the gas gauge to 12-volt, but the kit did not include it. Would I therefore need to look for the sending unit, the instrument panel gauge, or both? Is the change just due to the conversion to 12-volt, or also due to the conversion to negative-ground?
Q11: How about the other 2 gauges -- temp and oil pressure: Are they driven electrically, such that I need to replace those either because of the 6v to 12v change or because of the positive-ground to negative-ground change?
Q12: Are there other electrical components to be considered? Light bulbs, of course. Others?
Those are all the questions I could think of, but I would not be surprised to learn that there are more.
Cost: I'm seeing 6-volt to 12-volt conversion kits for about $175. On top of that would be a 12-volt battery ($80?) and light bulbs (probably negligible), plus some of the "oh, by the way" items (e.g. starter, coil, gas gauge, etc., depending on the answers to those questions above). Depending on those answers, this project sounds like it could push its way into the $400 range. I'd even be okay with that if I thought the tractor would sell better and be worth most of that additional money. I'd consider it a learning experience. But as you can see by my questions, there are some fairly basic things I just don't understand yet -- like "Will the current starter run backward?", and "Which gauges would be impacted by the conversion?"
In case you're interested, here's a bit more info on the tractor:
Model: 41301 S
Serial: 57788
The engine is gas, 4-cylinder.
It has about 4100 hours.
The transmission is 4-speed with fwd/rev shuttle.
Thanks again for all your input.
   / Ford 4000 Industrial - Alternator Problem #13
That looks like a "standard" GM 3 wire or 1 wire alternator that has been modified to run on 6v Positive Ground.
If the non-threaded portion of the shaft is 5/8" in diameter, a pulley such as: https://www.amazon.com/DB-Electrical-APL5000-Alternator-Prestolite/dp/B00Q8LRT72/ should fit (that pulley is for a 5/8" wide belt)
Yes.
Those kits should work.
I am not sure.
It is a good idea to replace the coil, you can use the 6V coil with a ballast resistor (to drop the voltage that the coil sees from 12V to 6V), but IMO you are probbaly better off putting in a new coil.
Correct, the alternator pictured does not have provision to run a tachometer drive.
The biggest wire is the charge cable, then there is a 2 wire plug (where the 1R and 2F terminals are on your alternator), 1 wire is the voltage sensing wire (would go to the fusebox on a car, to make sure that the alternator knows better what voltage the electrical system is at. On my David Brown project, they just ran it to the charge terminal). The last wire is the excitation wire, that goes to key switched power (often through a lightbulb so that it will glow to warn if the alternator fails).
You can use the same starter, switching voltage and polarity doesn't make it spin backwards. Not sure why, but it doesnt.
Correct.
I wouldn't, IMO if you are going to put the work into converting it, you will find it easier to sell if it is a "modern standard" like 12V negative ground.
That depends on who you talk to, here is a discussion and they seem to have no problem running 6v fuel gauges on 12v: 6-12 volt fuel guage/sender theory ?? - The Stovebolt Forums and Making a 6v to 12v Conversion Easy! echos that sentiment.
They are probbaly mechanical, you will need to look at the back of them, if they are mechanical you will see a line (probbaly copper) going from the oil pressure gauge to a port on the engine and a copper line with a metal coil around it going from the temp gauge to the engine to read temperatures.
You will want to take the old voltage regulator out completely.
Model: 41301 S
Serial: 57788
Your conclusion sounds correct.
Aaron Z
   / Ford 4000 Industrial - Alternator Problem #14
flyerdan,
Thanks!
Don’t waste time in the auto parts store. Measure out the puller needed and then go to an industrial supply place and get one that matches your needs.
Thanks for your input guys. I have some thinking to do. It's winter here, and my shed is not heated, so if I'm going to do the conversion, I may wait for warmer weather.
A few follow-up comments:
- I contacted the vendor for the kit that said "Not for Industrial type tractors", asking what the reason was. He essentially said he doesn't know the answer. He thought it may be a physical conflict between the alternator and the framework for the loader. I tend to doubt that, based on what I am seeing on my tractor. Also, I mainly wanted to know if there was some electrical reason for the statement -- like the Industrials require some additional doodad, or maybe the specs (e.g. amps) of the alternator are different. (Oh the joys of putting non-original equipment on a non-vanilla version of a tractor that is comparatively hard to work on.)
- Regarding the gas gauge question -- I guess I just don't understand electricity well enough to come to a conclusion. I read through the discussion on both of the links you included, and I didn't understand the details. More to the point, however, is that those folks do understand what they are talking about, and yet still don't come to a definite conclusion. I'm not sure what happens when you provide 12 volts to something that was expecting 6 volts -- sparks? heat? If so, then that doesn't sound like a good thing to do inside a gas tank. (I fully admit that my statements are based on my ignorance, but I nevertheless am not in a position to make confident, knowledgeable decisions in this area.)
- The second link you provided for the gas gauge discussion also mentioned other aspects of the conversion. Regarding the starter, they said the 6v one would be just fine, as you stated. However, they mentioned that the solenoid would need to be changed to 12v. They said a 6v solenoid could work in an emergency, but would burn out quickly, and possibly start a fire.
I may still try to give it a go, but I get the impression that this project is significantly into the "figure it out as you go" category. When you start with a good understanding of vehicle electronics, then a decision between "try it and see if it works" vs. "don't try it because it may cause a fire" becomes elementary. But without that understanding, that makes me pretty uncomfortable.
Thanks.
Brad
2014 JOHN DEERE GENERATOR SET (A51222)
2014 JOHN DEERE...
1998 CATERPILLAR TH103 TELESCOPIC FORKLIFT (A51242)
1998 CATERPILLAR...
Adams Conveyor (A51039)
Adams Conveyor...
2012 John Deere 7230R (A51039)
2012 John Deere...
2016 VOLVO VNL300 TANDEM AXLE DAY CAB (A51222)
2016 VOLVO VNL300...
2014 COTTRELL CX-09LS2 AUTO HAULER (A51222)
2014 COTTRELL...
