Yanmar safety switches
/ Yanmar safety switches #1
deadeyejedi
saratoga springs ny
yanmar sa424
Does anyone have a source where u can buy the safety switch that mounts under the hydrostatic pedal of my 2016 yanmar 424 I have to jiggle the pedal every time I start it. I ordered one through my local dealer and been jerked around for a month now and still it痴 not here .thanks
/ Yanmar safety switches #2
Does anyone have a source where u can buy the safety switch that mounts under the hydrostatic pedal of my 2016 yanmar 424 I have to jiggle the pedal every time I start it. I ordered one through my local dealer and been jerked around for a month now and still itç—´ not here .thanks
You have posted in the import area for yanmar’s.
Most folks here will not have info on your 424. We are more from the YM and FX models.
There is a separate section for the newer models. I suggest you post there if you have not.
The only suggest I would have would be Yanmar USA or search online (ebay, amazon or others?
/ Yanmar safety switches #4
Yep, call your dealer or check eBay. While some may know we are more likely to be able to help you bon your 40 year old Yanmar in this sub for than the new ones. We can help you track down any part on the old one though I bet.
Welcome to TBN though.
/ Yanmar safety switches #6
Is that switch special in some way? Does it have a unique shape or some sort of other special property? Do you want that particular Yanmar safety switch, or are you willing to use a more universal switch and fabricate a mounting?
If your choice is to prefer a Yanmar part - and the tractor is currently or recently manufactured then I assume that your dealer can have it for you in a few days. Although if the dealer is a problem I'm not sure what this vintage Yanmar group can do to help. Does anyone have any suggestions on that?
One of the reasons this vintage Yanmar group prefers the older Yanmars is that those older models tended to be repairable using standard industrial parts rather than specific dealership parts.
If you would prefer to fabricate the safety switch yourself, you can probably come up with one that works as well or better than the original.
There are industrial suppliers who carry a huge line of components. Several are online and will sell individual components.
Prices and all the specifications you need to know about the switch are also right there online.
My favorite source for universal mount industrial parts is McMaster-Carr. Here is a link to their switch selection page: McMaster-Carr.
For example, I just bought am industrial push-button switch from McMaster to replace a broken push-button switch that works a hydraulic relay on my Kubota. My tractor dealer's price for that switchwas several hundred dollars. But all that was really needed was a simple push button SPST switch to fit in a round hole in the dash. Very much like a safety switch, in fact. It turns out that when I looked up that type of switch at McMaster online I found that those switches are sold by the diameter of hole it fits in, whether or not it is illuminated when actuated (it was), and the power it is capable of handling.
McMaster sells an standard industrial switch with those qualities that turns out to be close enough to a Kubota part to be interchangeable. Cost is ten dollars for the industrial switch. The industrial part was in stock with 3 day delivery and is far superior in quality.
However, it wasn't a direct exchange. I did have to salvage the electrical leads off of the old switch and solder them onto the new one.
Good luck with it,
rScotty
/ Yanmar safety switches #7
I would find a similar seat safety switch at a lawnmower shop then as rScotty said, adapt a mount.
/ Yanmar safety switches #8
I just reread your post. The ‘jiggle’ effect you have to do with your peddle, may indicate an issue with your peddle going to ‘neutral’ rather than issues with the switch itself. Or a second possible issue may be with the mount of the switch. Just thoughts on other things to be sure to invesigate.
(INOP) CATERPILLAR 518 LOG SKIDDER (A63745)
(INOP) CATERPILLAR...
2006 Western Star 4900 Concrete Mixer U98358 (A62613)
2006 Western Star...
CASE INTERNATIONAL 1020 GRAIN HEAD (A63290)
CASE INTERNATIONAL...
2019 MERTZ MANUFACTURING MANIFOLD TRAILER (A58216)
2019 MERTZ...
Clubcar Carry All 1700 Utility Vehicle (A64047)
Clubcar Carry All...
75" X 16' SHOPBUILT T/A TRAILER (A63745)
75" X 16'...
