Ls xr3135 diagnostic port?
/ Ls xr3135 diagnostic port? #11
There is an obd2 on the right side by the throttle pedal. The dealer told me that use a specific plug for there diagnostic tool and not the obd2.
Are you sure that you understood him correctly? The one in the cab is diagnostic and programming. They do use a specific interface between the obd and the laptop.
On new holland models the plug is used for both but on the ls it is a obd2 with only can communications.
On your boomer how many wires go to your diagnostic port. I assume you have the standard 9 pin connector but wonder how many pins are used
/ Ls xr3135 diagnostic port? #14
4 pins are used.
Which 4 are used?
/ Ls xr3135 diagnostic port? #16
Is this the one you are looking for? Lower right side console.20191225_093254.jpeg
/ Ls xr3135 diagnostic port? #17
Which 4 are used?
You've made 7 posts now asking about this and haven't even hinted at why you want to know or why you haven't asked the dealer. If this is something only a dealer can use for whatever reason, why does it matter to you?
/ Ls xr3135 diagnostic port? #18
CAN high and CAN low is what is used for diagnostic and programming.
As far as pins, it is A, B, C, D.
I am asking because I have access to a new holland dealer scan tool. Ls and new holland use different plugs and when I asked the ls dealer that told me there is a different plug thay thay use and not the obd2. Thay said obd2 was just thare because it was mandatory.
CFG Industrial H12R (A60463)
CFG Industrial...
2014 FREIGHTLINER 108SD CONCRETE MIXER TRUCK (A59823)
2014 FREIGHTLINER...
2012 PETERBILT 367 (A60736)
2012 PETERBILT 367...
Dodge Charger (A56859)
Scag Turf Tiger (A60463)
Scag Turf Tiger...
ALLMAND LIGHT TOWER (A60736)
ALLMAND LIGHT...
