Ls xr3135 diagnostic port?
   / Ls xr3135 diagnostic port? #31
So what horsepower are you going to program?
I may bump it up to 40 or 45 lol I'm more interested in deleting the dpf.....
   / Ls xr3135 diagnostic port? #33
Why stop there? If you're going to void the warranty you may as well go for broke. Course the XR31xx is missing some items for beyond 40hp but being a mechanic you probably already know what's missing. Regarding the DPF delete, probably not going to happen with stock software.
May check with a few CNH mechanics on here cause I'm pretty sure CNH will know what that laptop did.
I only have 1 year of warranty left. I probably wont bump up the hp anyway because I'm happy with it th way it is. I only want to explore the possibilities of a dpf delete just in case I have issues with it later on.
   / Ls xr3135 diagnostic port? #35
What year is your tractor? I thought 2017 and newer LS's came with 2 year bumper to bumper and an additional 4 years limited powertrain for 6 years of coverage.
Haven't really seen DPF issues on these tractors so I wouldn't worry much about it. The EGR now there is a discussion.
Let us know if you are successful or how things turn out.
I will update this thread. I have had issues with my dpf at 16 hours it was replaced then again at 67 hours and thay did an update and now have 700 hours on it and I believe it's starting to be an issue again. I have one of the faulty ones that I plan to gut and try to use for the dpf delete.
   / Ls xr3135 diagnostic port? #37
Yes. It is located just to the left of your brake pedals.
   / Ls xr3135 diagnostic port? #38
Any updates? I'm asking because my 2015 LS XR4046H with 260 hours has a dpf issue specifically the burner injectors which run 2k for just 2 injectors.
2007 Sterling L7500 Terex Commander C6060 T/A Insulated Derrick Digger Truck (A60460)
2007 Sterling...
1996 Transbridge Detach Low Boy (A59814)
1996 Transbridge...
International S1900 (A56438)
International...
2022 NEW HOLLAND 266BMM 66-INCH BELLY MOUNT FINISHING MOWER WITH SIDE DISCHARGE (A57024)
2022 NEW HOLLAND...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
1992 Talbert 70 Ton Lowboy Trailer with Removable Gooseneck (A56438)
1992 Talbert 70...
