Seized Drain Plug
   / Seized Drain Plug #21
YaY a new drain plug thread!
   / Seized Drain Plug #22
First, stack some pallets in a field
Second, borrow a pipe wrench from Kando
   / Seized Drain Plug #23
Then list it on the Pet Peave page
   / Seized Drain Plug #24
Can't get a good picture as the loader is in the way and the tractors disabled at this point. But it's like the one in the picture with the hose but a little different in that the ears are cast and quit large. Looks handy, but not when it's seized. At this point we have it drained enough that the water pump came off with very little mess. The only reason I'd need it loose at this point is if I have to bleed it once everything is back together and filled. The drain on the rad was no problem, but that one looks to be brass.
He could be talking about item 21
Mike scroll down and you will see a oil drain plug
It appears to me by Train's posts that he is dealing with coolant drain #10 rather than oil drain #20.
   / Seized Drain Plug #25
It does not take much for the Sesame St. goofs to come out...!
   / Seized Drain Plug #28
Properly done, this thread should get us through winter, and well into spring.
LOL, I am with U there. But by spring he will have sold the tractor so the new owner will have to do that oil change. (or like someone I know simply not bother. LOL)
Hey, want to hear all about me changing a block heater on my CUT?
Bet I can drag that to 100 posts! LOL. (actually took me 3.5 hours due to inaccessibility)
   / Seized Drain Plug #29
Reporting to duty. Present and accounted for :salute: :salute:
2757 (A55787)
2757 (A55787)
2014 Chrysler 300 S Sedan (A55853)
2014 Chrysler 300...
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50323)
BW RVB3405...
2010 LAREDO 5TH WHEEL (A55745)
2010 LAREDO 5TH...
2007 Jeep Liberty SUV (A55853)
2007 Jeep Liberty...
2016 Dodge Charger Sedan (A55853)
2016 Dodge Charger...
