HF 70lb hammer and tamper
   / HF 70lb hammer and tamper #11
I made one for a hydraulic jackhammer. Used a cut off chisel. Broke it from stress within minutes.
   / HF 70lb hammer and tamper #13
I probably should not have welded close to the point where the chisel left the tamper. It was well welded, but a friend managed to unglue the whole thing and start again.
   / HF 70lb hammer and tamper #15
Roll the gravel with the bobcat and just tamp the edges. Use a washed gravel with no fines and it won’t compact much anyway.
   / HF 70lb hammer and tamper #16
Friend of mine got this to tamp sand before laying down pavers. Said it worked great. Also used a coupon, so another 20 percent off.
6.5 HP Plate Compactor
   / HF 70lb hammer and tamper #17
I have the same one and used a 20% off coupon as well. I have rented better ones but for personal use and the price I have been satisfied with it.
   / HF 70lb hammer and tamper #18
Y’all are tempting me to buy one and I don’t even need it yet!
   / HF 70lb hammer and tamper #19
I have the plate compactor also and for the money it has paid for its self a couple of times over
   / HF 70lb hammer and tamper #20
I have one also. My backhoe has an 18" bucket and I welded eye-bolts onto the tamper so I could lower it into the trench and compact the dirt (lots of clay) as I fill in the trench. It works better than anything else I've tried, but still leaves a small ditch after a year of settling.
New/Unused 30in Rolling Service Cart (A54865)
New/Unused 30in...
CATERPILLAR 420E BACKHOE (A52707)
CATERPILLAR 420E...
2013 MACK GU (GRANITE) TRI AXLE WINCH TRUCK (A55745)
2013 MACK GU...
1989 BOMAG BW213D SMOOTH DBL DRUM ROLLER (A52707)
1989 BOMAG BW213D...
UNUSED Grey Waterproof PE Tarpaulin w/Grommets (A53117)
UNUSED Grey...
CATERPILLAR CB-224C DOUBLE DRUM ROLLER (A52707)
CATERPILLAR...
