Cab Heat / Air Conditioning Issue
/ Cab Heat / Air Conditioning Issue #21
I noticed something odd relative to this topic this morning. Today was one of the coldest mornings that I have used my tractor - about 10 F. When I first got in, I turned on defrost and tried to toggle the AC button. No light. After running it for a little while, I tried it again, and the light toggled. My theory is that the AC is not allowed to be turned on below a certain temperature in order to protect the AC system. After the tractor ran a bit, it warmed up everything enough to be above the disable threshold.
/ Cab Heat / Air Conditioning Issue #22
Interesting idea, although that sounds like a rather sophisticated feature for a CUT HVAC system. Hopefully others will weigh in on this and we'll at least get some more data points to test it. Maybe Kioti617 will jump in to let us know whether ambient temperature might be a factor in his case also. Don't know his location from his profile. Here in Northern Virginia, and with my tractors kept in garage and barn bays, I thankfully don't have the opportunity to do an empirical investigation of this. :laughing:
/ Cab Heat / Air Conditioning Issue #23
My NX seems to act this way as well. If really cold, will not turn on. After you get some heat going, will work.
/ Cab Heat / Air Conditioning Issue #24
That is correct. The thermister, that works as a temperature switch for the AC in our tractors, must be warm enough before allowing to AC pump to turn on and begin drying the air for defrost. If the thermistor did not do this, the AC refrigerant would slug the compressor. Yesterday while blowing and plowing my tractor didn't kick its AC on until maybe 15-20 minutes of work and this with a block heater on for over 24 hours.
/ Cab Heat / Air Conditioning Issue #25
Sounds like the HVAC system is well thought out in this regard. I'd be curious to know what the thermistor set point is. :scratchchin: Morning air temp around here occasionally is in the high teens or low twenties. Sometime much lower. But balmy by comparison to what many TBNr's regularly experience. :cold:
Eric and Kioti Dave, during your minutes of work before the AC switches on, have you experienced much fogging on the glass?
/ Cab Heat / Air Conditioning Issue #26
Sadly, it fogs all over the place until the underhood or cap top temperature rises high enough to cut in the AC compressor to start drying the air (I have no idea where the thermistor is located in our application). Thermisters are the cheap version and somewhat more reliable version of a traditional mercury temperature switch. AC systems have at least one temp or limiting switches: a cut in and sometimes a second cut out switch to protect an overheating system. Cut in is the cold side, cut out is the hot side. Cars nowadays may have humidity switches and solar load sensors in addition to fine-tune the driver's comfort.
/ Cab Heat / Air Conditioning Issue #27
Unfortunately, yes I do get some fogging. I have a 12 volt fan that I use to keep the rear window clear. That helps. Once the A/C starts to work, clears up really quick. I did have to get the warranty work done on the blend gates on top of cab to be able to blow warm air while A/C on.
/ Cab Heat / Air Conditioning Issue #28
Perhaps this. Attached is a description of the "Thermocon" operation in the NX HVAC system. If I'm interpreting it correctly, the thermistor's set point is nominally 32 F. So, if it senses an ambient temp in the roof cap below that, the AC relay will not switch on. Does that sound right?
Since some are reporting no illumination of the AC indicator light prior to warm up, the light evidently is wired between the thermistor and the AC relay, thus will not illuminate below 32 F. That seems a bit odd, though, as more logically I would expect it to illuminate whenever there is power to the thermistor. :confused: Then, as the roof cap temp reaches the set point, the thermistor would allow current to flow to the AC relay, while the light stays lit the entire time until the AC switch is toggled off.
But, then, I'm no electrical design engineer, so I may be all wet on all of this. :laughing:
/ Cab Heat / Air Conditioning Issue #29
My A/C indicator light will not go on if A/C is not operating.
/ Cab Heat / Air Conditioning Issue #30
A question related to this topic. Is there a max temp that will cause the A/C to cut out??
/ Cab Heat / Air Conditioning Issue #31
There is a switch on the dryer that senses the pressure of the refrigerant. If the pressure drops below the set point, it opens and prevents the compressor from operating without adequate freon.
There is a 'pop-off' valve on the compressor that opens and bleeds off refrigerant if the pressure becomes too high. Other than that, I am not aware of any switches to protect against overheating.
/ Cab Heat / Air Conditioning Issue #32
Roger, thanks
Finally, an unfortunate update: After four calls to the dealer, they finally called back. Dealer has no fix, they spoke with Kioti and Kioti has no fix, Kioti has no intention of fixing. "... just one of those things, I guess...". I think that is actually worse than when this same dealer told me to crack a window open to get rid of the moisture on the windows.
In reference to information from earlier in this thread, why would they fix the NX and not the RX? Time for Kioti customer service i guess.
/ Cab Heat / Air Conditioning Issue #34
You are a patient man. :) You have a 2018 cab tractor that becomes virtually unusable in normal winter conditions because the glass fogs up so badly that you can't see out. Your only work-around, which you had to find for yourself, is to unplug a part of the HVAC system.
I know it's not what you want to do, but here's my suggestion. Write a polite but firm letter to Kioti corporate, with a cc to your servicing/selling dealer. Faithfully recite the history of this problem, and the steps you and the dealer have taken to deal with it. Note that this is not only an operational issue, but a safety issue as well, due to the impaired visibility. You consider this clearly to be a warranty issue that Kioti is obligated to resolve, and indeed should want to resolve quickly. Close by requesting a response within ten business days as to how Kioti proposes to proceed.
/ Cab Heat / Air Conditioning Issue #35
Did you ask about part number TE16-A0083A? When I called my dealer, he inquired about the part number with Kioti. Kioti sent the kit and approved the warranty work. The kit is just a wiring harness, actuator motor and new controller. You would think it worked across the different lines of tractors.
/ Cab Heat / Air Conditioning Issue #36
I would imagine the same. If you had to call dealer four times, I'm doubting there ever was a response from Kioti. Call another dealer and tell him what its doing and see if he's heard of this issue with an RX. :)
/ Cab Heat / Air Conditioning Issue #37
I installed the kit on my 7320. It's a game changer.
/ Cab Heat / Air Conditioning Issue #38
Same on my 2017 NX. Again, his dealer is an idiot.... not Kioti. His first or second post says 'he hates to call them, they were bought out....... " He already knows theyre idiots but still wants to believe them that Kioti doesn't care. FALSE.
/ Cab Heat / Air Conditioning Issue #39
Think you have an answer. Time to call another dealer.
I never indicated, or meant to infer, that Kioti does not care; was just relaying what I was told by the dealer. Thus far, this is indeed a dealer issue, and the patience has come about because I try to give the dealer the benefit of the doubt. The four phone calls were in the midst of or perhaps very shortly after a buy out, so I had to extend my patience a little (at least I thought that would be the right thing to do). I think that at this point in time the dealer has failed, the next steps is when I get to find out whether or not Kioti cares.
Thanks, all!
1999 AMERICAN EAGLE CLASS A MOTORHOME (A65643)
1999 AMERICAN...
2015 Chevrolet Silverado 3500 Pickup Truck, VIN # 1GB4KZC88FF627993 (A65563)
2015 Chevrolet...
2013 Kubota BX2370 44in 4x4 Compact Utility Tractor Mower (A61572)
2013 Kubota BX2370...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2007 PETERBILT 386 (A65643)
2007 PETERBILT 386...
2005 GMC TOPKICK C6500 TESTING UNIT (A65643)
2005 GMC TOPKICK...
