Single or double acting dump trailer pump?
/ Single or double acting dump trailer pump? #1
James Eric
I am just starting to bring an old dump trailer back to life. It has a double acting cylinder with a single acting pump. As you can see in the picture, the top port on the cylinder has rubber hose that returns to the tank. Since I am installing a new dump pump kit, should I switch to a double acting pump or continue the current single acting setup?
6x12 dump trailer
Cross 3 inch bore , 24 inch stroke double acting cylinder
(2) 3500 pound axles
Factory built, unknown manufacturer
/ Single or double acting dump trailer pump? #2
You only need the hydraulic power to raise the dumper, gravity brings it back down.
The builder simply used the cylinder he had on hand and rendered it to single action mode.
/ Single or double acting dump trailer pump? #3
If it worked before why bother changing it?
/ Single or double acting dump trailer pump? #4
I have a double action hydraulic cylinder on my dump trailer.
Pros; I needed to transport an 800 lb. safe but couldn't get it into the back. I raised the dump trailer into the vertical position. Strapped up the safe against the back of the trailer and lowered the bed. The double action cylinder pulled the safe up off the ground to where we could slide it into the bed.
Cons; I dumped a load of debris at the city dump. The hydraulic pump refused to operate to lower the bed. It did not have a relief valve. I couldn't drive home with the bed up, so after a couple of hours of work and a new battery. I got it working again. I later installed an emergency relief valve system, to drain the fluid out of the cylinder and into the reservoir to lower the bed in an emergency. That cost about $125. Double action puts more strain on the battery.
/ Single or double acting dump trailer pump? #5
I have power up, gravity down and run transmission fluid in the pump, never had an issue no matter how cold it gets.
/ Single or double acting dump trailer pump? #6
I too have a double acting cylinder and ran a hose back to the tank just to have some fluid on reserve.
/ Single or double acting dump trailer pump? #7
I operated dump trucks and trailers for 14 years and none were equipped with a double acting cylinder. If its good enough for the industry, it should be good enough for anybody. The only time I operated a vehicle with a double acting cylinder was in and old Ford 9000 flatbed lumber delivery truck, it only came in handy when delivering to city lots with overhead wires where it was necessary to power down to clear the wires before pulling out from under the load.
/ Single or double acting dump trailer pump? #8
My ton dump truck is a double acting cylinder. I can’t think of any advantage to having power down on a dump truck. The only advantage I can think of is it doesn’t require as big of an oil tank. The downside is it’s a lot slower to go down.
/ Single or double acting dump trailer pump? #9
Ron,
I’m curious how you plumbed in your ‘emergency’ lower?
I too have a double acting dump trailer. When I use it on the tractor with tractor hydraulics it works great! When I use it on the truck with the pump.....I’ve been stranded before too. I’ve even added a 4ga wire and associated solenoids, breakers and fuses to have about 40 amps of power trying to keep the battery charged. My fully charged battery (deep cycle group 24) lasts one dump. I’m thinking the pump motor is getting tired and must be drawing a heck of a current tire drain the batteries so fast, which over a few months seems to destroy them.
OP, go single acting!!!!
/ Single or double acting dump trailer pump? #10
All of this talk of battery draining makes me glad both of my trucks are pto powered pumps.
/ Single or double acting dump trailer pump? #12
Mine is power down. Just how Sure-trac built it.
But if you decide to go to power down on the existing cylinders which have only been used as power up....I'd at least flush out the rod-side of the cylinder before tying it all together.
And get rid of the Galvanized water-pipe fittings for high pressure hydraulics
/ Single or double acting dump trailer pump? #13
More and more it seems I have issues with this single acting hoist to get back down again.
EDIT: It just occurred to me what it probably is. I had a different transmission put in the JD and they didn't use the Low Visc Oil I used to use.
/ Single or double acting dump trailer pump? #14
you could get this Pump Triple Action KTI with Remote, This Pump Features Power Up , Power Down , and Gravity Down action
/ Single or double acting dump trailer pump? #15
My Ez-Dumper trailer is power both ways.
What controls the down speed on a one-way?
/ Single or double acting dump trailer pump? #16
Feathering the manual valve.
/ Single or double acting dump trailer pump? #17
They go down fast which is one of the main advantages IMO. You’re limited by how fast the fluid can exit the cylinder so it’s not like free falling or anything. On my manual valve truck you can somewhat control it. On an electric valve dump trailer you probably only had one speed.
/ Single or double acting dump trailer pump? #18
My smaller highway-use dump trailer has a valve you can feather. In the up position, the pump comes on. No remote. Yes, that wouldn't give any control over speed.
Thanks to everyone for your suggestions. Just so you know, the trailer was free so I plan to replace the pump and motor unit completely so yes all new lines and fluid. Thanks again.
/ Single or double acting dump trailer pump? #20
I had trouble with my single acting cylinder trailer going down. It was the pivots getting seized. After cleaning and greasing all is good again.
2017 Ford Escape SUV (A64557)
2017 Ford Escape...
2024 Wolverine X2 1000 R-Spec (A62679)
2024 Wolverine X2...
Allmand 8KW Light Tower (A64194)
Allmand 8KW Light...
2016 280 Trailers Towable LED Advertisement Board (A64553)
2016 280 Trailers...
New 1.5x27 Ratchet Strap (A65583)
New 1.5x27 Ratchet...
IRANCH IRGC40 ELECTRIC SCOOTER (A64280)
IRANCH IRGC40...
