Which one to choose
/ Which one to choose #1
keenan
Massey Ferguson GC1723E
I currently have a Massey Ferguson GC1723E I am wanting to upgrade to a SCUT with a backhoe. I am down to the Massey Ferguson GC series and a John Deere 1025R. I like different features on each one just looking for insight and opinions. I have two Massey dealers with in 30 miles and Deere dealer with in 10 miles of me.
/ Which one to choose #2
Take a look at Tractor Time with Tim on YouTube. He did a nice comparison between a JD 1025r and a Kubota BX. The Kubota does not help but it might give some insight into the JD.
/ Which one to choose #3
Have you really looked at the Kubota BX? The BH is part of the base price, not an add on. actually you cannot by it w/o the BH. Mine has been a fantastic performer.
Ron
/ Which one to choose #4
These threads always go to people preferring what they have. I looked at all colors before going blue. Comparing price and value left only one option for me.
Was just wondering if anybody had both and preferred one over the other. As far as manufactures specs are concerned the GC series beats the John Deere 1025r. But I have watch a lot of YouTube videos like Tractor Time with Tim, doing things with there 1025r that I am almost certain my current GC1723e will not do, even though the specs on my tractor are "higher".
/ Which one to choose #6
I recently bought a JD 2025r, which has the same drivetrain as a 1025r and the same end loader, just on a larger chassis. I traded in a Kubota BX for the JD. The telling thing for me is on Tractor Times comparison is the physical size of the JD compared to the BX. It is just bigger with a much larger end loader bucket. When looking at specs there are different ways to compare specs, such as where the lift is from, the pins or in front of the pins. I am not sure how your current tractor compares in size to the JD 1025.
/ Which one to choose #7
Ron
The new Kubota BX1880, BX2380 & BX2680 are sold without a backhoe. The new Kubota BX23S can only be purchased with a backhoe.
/ Which one to choose #8
Make the dealer let you try out both the JD 1025R and MF GC with FELs. I had a 1025R between a 4010 (would be a 2019E now) and a 2025R. The main problem with the 1025R was its completely untrustworthy FEL. You never knew when it might just take a dump. By comparison the FELs on the 4010 and the 2025R are completely goofproof.
Yes, my 1025R was a real lemon, but I've read about other 1025E/R owners experiencing strange FEL behavior.
I like the MF GC line. Nice size/hp. Think their FELs are not as hefty as the 1025R's but hopefully much more trustworthy. We only have Kubota and JD dealerships within any decent distance from us here in Charlottesville, Va.
Think I vaguely recall that MF uses Isuzu engines? Have a 12.5 kw Isuzu diesel generator that's a real gem, since early 2013.
Ralph
/ Which one to choose #9
Well look, you already know how the MF is, the backhoe model is mostly the same thing, only with a sucky wobbly seat and a hoe dangling off the back. Bigger rops, also. Me, I'd take the 10 mile trek out to the JD dealer, try out their fare for comparison.
The GC's main advantages are a) you could work the loader and backhoe without bumping the rpm's way up, and b) PRICING!
/ Which one to choose #10
I dont know anything about either tractor that you mentioned, but I will just say this, both are just backhoe add on's to a tractor frame. If I were buying, I would go with the Kubota BX23S which is a factory designed TLB not a tractor that someone has hung a backhoe on to. My B26 is also a factory designed TLB and has much more weight than a standard B 26XX series with an added hoe.
I dont think anyone other than Kubota makes a factory designed TLB in the SCUT/CUT sized tractors. The last company to make a competitor was the JD 110 but they quit making it years ago. Guess they couldn't compete with the Kubota design.
/ Which one to choose #11
A Kubota BX with a backhoe is really just a subcompact tractor with a backhoe hung on the back. It has a subframe setup so it is designed for it. It isn't like a B26 though in terms of being a true construction grade machine, its more of a homeowner setup.
/ Which one to choose #12
A bx23 is a bx2380 with a subframe bolted on, the backhoe mounted to that. Same thing with my gc1710 or any color scut tlb. You're probably referring to backhoes tacked onto a 3ph, yeh that's generally no good on a scut, but that's not what the o/p is referring to.
2005 Peterbilt 387 with Wet Kit (A63118)
2005 Peterbilt 387...
Year: 2018 Make: Towmaster Model: TC-16 Vehicle Type: Trailer Mileage: Plate: Body Type: Trim Lev... (A61567)
Year: 2018 Make...
Club Car Electric Golf Cart (A66285)
Club Car Electric...
New Holland LB75B Backhoe (A62613)
New Holland LB75B...
2019 FREIGHTLINER SPRINTER 2500 4X2 S/A CARGO VAN (A59912)
2019 FREIGHTLINER...
2022 Mack Anthem T/A Wet Kit Day Cab Truck Tractor (A61568)
2022 Mack Anthem...
