Battery Tenders
/ Battery Tenders #101
I have a Schumacher charger that I bought over 45 years ago and it's still working. I believe it has a selenium (not silicon) rectifier, it's that old and it's still working - as a bulk charger. If I leave it connected to long it will boil a battery so it's always on a timer or checked frequently. I do have several maintainers that I bought after reading the posts on here that I can and have left connected.
/ Battery Tenders #102
Grandpa's Schumacher is still in service... must be from the late 50's
I will need to check but I am certain my first tender is made in USA... maybe circa 1980???
/ Battery Tenders #103
I've been using Battery Minders now for maybe 4 or 5 years. They are incredibly good - and rather expensive. I buy them through Amazon.
Worth it in spite of the price because the Minder makes a noticible difference in battery life if hooked up to the battery for a day or two every couple of months.
I don't know what the Battery Minder is doing to the battery at that time...but whatever it is, the batteries seem to thrive on the attention.
/ Battery Tenders #104
Formerly I would only buy Battery Tenders.
Now: I only buy Battery Minders.
I have a few!
Same good experience as you are having.
/ Battery Tenders #106
Where do CTEC chargers fall in all this? I haven稚 seen them brought up here. I got a 5.0 last year and haven稚 used enough to start bragging . One thing sure. On older heavily sulphates batteries it didn稚 work any miracles......
/ Battery Tenders #107
I don't have any experience with the CTEC charger. So far as I know, the CTEC is basically a trickle charger - maybe with some intelligence & maybe not.
Years ago I had a mechanical shop and it wasn't unusual to have 20 batteries all needing attention. Usually they were lucky to get trickle charged if I remembered to move the home-made trickle charger from one to another. My experience is about like yours.... trickle charging is good because if the battery is good it keeps it from going flat when it isn't being used. So you have battery when you need it. But I can't say that trickle charging did anything to help an older sufated battery. I always hoped it would, but it never seemed to improve an old battery. It did keep good ones at full charge though and that was worth doing.
So I think the answer to where the CTEC fits in is that trickle charging is one of the things that the Battery Minder does. But the Battery Minder seems to do more than that. Along with whatever it does for sufated batteries, the Battery Minder has a high amp mode for charging fully flat batteries. On high amp mode it monitors what's happening somehow so that it doesn't overcharge and then turns itself into trickle mode at the end. It has some dash lights to let you know what mode it's in.
I don't know exactly why the Battery Minder is good, and I've no stake in the company. It works for me.
rScotty
/ Battery Tenders #108
Modified my cheap chinese charger/tender with a fuse for peace of mind. Noticed they didn't even have engineered crimps on the aligator clamps or solder, just squeezed on! Nice.
/ Battery Tenders #109
Excellent idea!
All Battery Tender brand units are shipped that way.
/ Battery Tenders #110
rScotty
^^^^^ Agreed!
/ Battery Tenders #111
Keeping a battery charged is a good way to avoid forming sulfates - that happens in a discharged or partially discharged battery. However, a simple trickle charger will not undo sulfation that has already formed in the battery. You need a charger with the desulfation feature for that.
The BatteryMINDer desulfates a battery by sending a high-frequency pulse through the battery every few seconds. I'm not sure HOW it accomplishes it, but that pulse works to break up the sulfation. BatteryMINDer chargers perform desulfation continuously, both during charging and during "float" operations. Being a smart charger, it monitors the battery condition, and will not overcharge (overcharging is a problem with some "dumb" chargers).
Some other desulfating chargers us a high-voltage pulse to accomplish the same thing. The pulse is brief enough that the high voltage does not damage the battery, but it does break up the sulfation. I have no idea if one method is better than the other. "Battery Tender" brand chargers do not do desulfation (which is why I do not use them). Most (maybe all) NOCO chargers do desulfation with the high-voltage pulses, however, they do this only while the charger is in charging mode, not while they charger is in float/maintenance mode.
rScotty
I've also had very good luck with the BatteryMinder chargers. (I own at least 5 of them, one of which is approaching 20 years old.) I also own a Noco Gen2 charger. I've not owned it for long, but it appears to be working well also. I'm not a fan of the Battery Tender or Harbor Freight brands of chargers. Battery Tender works OK if used regularly, but will NOT recover a sulfated battery. The Harbor Freight chargers I just can't bring myself to trust.
/ Battery Tenders #112
I have 2 Ctec chargers(multi 3300 model) going on my 2nd year of ownership.So far so good.
/ Battery Tenders #113
I discovered the Battery Minder I bought a couple of years ago has already died.
The tractor that hasn't been started since last fall has shown a steady 12.3 volts with the battery minder attached and the green 'charged' light showing. I finally looked in the charger's manual, it says the battery should be 13+ volts and the red light should be on whenever the battery minder is plugged into the wall. I haven't seen the red light for a long time. 1017 stamped on the charger is, I assume, the Manufactured date.
Are others having good luck with these?
/ Battery Tenders #114
Does the title of this thread give anyone else a hankering for a breaded, deep fried snack?
Seriously, I read all 12 pages hoping for information. I bought a "maintainer" some time ago and still haven't taken it out of the package. Must have been an impulse buy because I've never had problems with batteries even after the equipment sat for months unused. After reading all the comments I can't decide whether I should press the maintainer into service on something or toss it.
/ Battery Tenders #115
I have a solution.
Send it to me!
/ Battery Tenders #116
I've bad batteries show green but couldn't deliver enough amps. The charger is still good
/ Battery Tenders #117
A battery reading 12.3v is a 50% SOC(state of charge). Fully charged batteries are typically around 12.77v(100% SOC). That charger is failing as it needs to push a high enough voltage to overcome the resistance of the plates. I am a fan of the Battery Minders but they do fail.
/ Battery Tenders #118
I've had very good luck with mine (all 5 or 6 of them). My oldest, model 12117 (same as the one in your link) is almost 20 years old and still going strong. Warranty is 5 years. If yours was made in Oct 2017, it's still under warranty. If you are sure it is not working, contact them about a replacement.
If the "Battery Condition" light shows solid green when connected to a battery, it's charging. If it's flashing, it's in "float mode" and has completed charging. If the charger never goes into float mode, there is either a problem with the charger, or something wrong with the battery. It might be worth trying connecting it to a known good battery to see how it behaves.
/ Battery Tenders #119
1017 may be 2010, 17th week.
/ Battery Tenders #120
Perhaps I just had a little bad luck but I purchased two 3300's at the same time. One crapped out within the first year by failing to go into maintenance mode on every battery I attached it to. After a couple years the second one failed by not being able to cycle between modes. It was the button switch problem which if you search you'll find info on this issue. Went to another CTC popular brand since then by purchasing an automotive and 2-bank marine charger and wasn't happy with those at all (great marketing lingo however). Finally landed on a Battery Minder 128cec1 which by all accounts lives up to the marketing and billing.
2023 JCB S3246E ELECTIC SCISSOR LIFT (A63276)
2023 JCB S3246E...
2021 21ft Scout 210 Dorado Boat with 2011 18ft Magic S/A Boat Trailer (A61574)
2021 21ft Scout...
Dodge 5500 Bucket Truck (A63688)
Dodge 5500 Bucket...
2015 John Deere 210 GLC Excavator (A60352)
2015 John Deere...
2019 John Deere 460E 46 Ton Articulated Dump Truck (A64194)
2019 John Deere...
2013 Kubota BX2370 44in 4x4 Compact Utility Tractor Mower (A61572)
2013 Kubota BX2370...
