Snow 54 quick hitch blade
/ 54 quick hitch blade
Thanks bigtiller! It took some time, not perfect at all, seeing as it has a couple extra holes. Ha! But like beenthere mentioned, as long as it works! Well ovrszd, the most I can squeeze out is about 70*...that’ll have to do! I should’ve thought about that when I lined up that bottom pivot hole...�� Next time. Ha! I didn’t add those lock holes, but I could always do that later. Real test will be plowing snow, if we get some, or some dirt come spring/summer time when we landscape our yard.
Yea? I’m hoping. That’s a guess too.. Could be less. Was a poor mans set up to check the angle. I’ll grab my daughters protractor and give it a go. Ha! I’m not to worried about hitting curbs, rocks, etc. I have a paved drive, albeit 600’, but im not using it for parking lots and commercial properties. Should be fine.
/ 54 quick hitch blade #44
You cannot push any dirt without locks. You might be able to push significant snow without locks. I got tired of it tripping all the time and locked mine. Good luck.
Ahh. Good point ovrszd! I will need to add some holes this spring then! Thanks!
2021 Weber CF 2-IIHD Plate Compactor (A61572)
2021 Weber CF...
2001 Peterbilt 330 4,000 Gallon Water Truck (A64194)
2001 Peterbilt 330...
YANMAR VIO35-6A EXCAVATOR (A64279)
YANMAR VIO35-6A...
Harlo HP6500 (A60462)
CATERPILLAR 12M3 MOTOR GRADER (A64276)
CATERPILLAR 12M3...
2015 IC Corporation PB105 School Bus (A61573)
2015 IC...
