Sprocket for snowblower chute
/ Sprocket for snowblower chute #1
Grant052810
Holland Patent, New York
LS R3039
I am looking to add a sprocket to my 3 point hitch snowblower chute. I can not seem to find a sprocket large enough to make this happen. I have ordered everything else I need to make my chute hydraulic driven using #40 chain. The diameter of the chute is 9 so that would mean I need the sprocket I/d to be just larger than 9 and o/d does not really matter to me. Maybe 11 or so. Anyone have any websites or ideas to make this happen. I have found tons of sprockets online but nothing really of this size. I have a couple pictures of what I am trying to accomplish but I am new to the forum and for some reason I cannot figure out how to attach a picture.
/ Sprocket for snowblower chute #2
What brand of snowblower do you have? Have you considered matching the sprocket on the hydraulic motor to the sprocket pitch on the snowblower chute?
I tried. The sprocket pitch comes out to be roughly 1 1/8 I keep finding stuff that will work with 1 1/4 or 1? The snowblower is made my Braber equipment sold by northern tool. The rotation kit that they sell for the snowblower is too much money and I know with enough research and questions asked I can make it happen for half of what they want for it.
/ Sprocket for snowblower chute #4
/ Sprocket for snowblower chute #6
Why not use the existing sprocket / shaft and adapt a Hyd or electric motor to that? Also is this your unit? see the manual attached
  • Braber SB.pdf
/ Sprocket for snowblower chute #7
/ Sprocket for snowblower chute #8
See item # in the drawing ... #28 - Turning Screw - 13002828
Nice that the gear detaches from the hand crank. Could you use that in conjunction with your hydraulic motor?
I did think of that option but the hand crank has a lot of play in between the teeth of the chute and i have seen a few screw type cranks destroyed from a hydraulic motor.
/ Sprocket for snowblower chute #12
My Meteor snowblower has a sprocket on the bottom of the chute that measures 1.0" center to center at the bottom of the teeth. That would be a #80 roller chain.
/ Sprocket for snowblower chute #13
Oh shucks,
I used an old winch (like $50/$60 $ or so) and reconfigured it so that it turns nice and slow and can actually break ice frozen chute loose.\
And that is like 4-5years going on now.
Not magic simply an analysis of available torque and some DIY capabilities.
The nice up come is that nice low investment vs outlay.
Bonus is it works!
/ Sprocket for snowblower chute #14
Here is a 40 pitch 80 tooth (13" Outside Diameter) Sprocket on ebay for $30 + $26 shipping. You would have to cut the center out. At least ot gives you an idea of tooth count and size;
Teeth OD
66 10.796 10.508 10.195
67 10.955 10.667 10.352
68 11.115 10.826 10.514
69 11.274 10.985 10.670
70 11.433 11.145 10.832
71 11.592 11.304 10.988
72 11.752 11.463 11.151
73 11.911 11.622 11.306
74 12.070 11.781 11.468
75 12.229 11.940 11.625
76 12.389 12.099 11.786
77 12.548 12.258 11.943
78 12.707 12.417 12.105
79 12.866 12.576 12.261
80 13.026 12.736 12.423
My Meteor Snowblower has 80 pitch, 32 teeth, 10.75" OD. Are you certain the dimension the bottom of the teeth isn't 1" (80 pitch)?
Teeth OD
I will double check again tomorrow and take a picture of it if I can figure out how to attach it and go from there.
/ Sprocket for snowblower chute #16
Can you not just order the sprocket as used in the kit from Northern?
I called northern tool to try to get some information. They said it is a drop ship item so they never actually see it so they referred me to Braber equipment. I called Braber and was on the phone with the guy for a half hour. He said the only thing he can see for information is just the entire kit which is $629. + $25 for shipping. I even played stupid and told him that I had bought the kit and I had a broken tooth on the sprocket so I wanted to replace it instead of dropping 650 bucks on an entire package again but he could not help or see anything on his computer that would help me.
/ Sprocket for snowblower chute #18
/ Sprocket for snowblower chute #19
I'm guessing that you tried McMaster-Carr. That's where I go first for any mechanical parts.
rScotty
/ Sprocket for snowblower chute #20
United Box Blade (A64047)
United Box Blade...
1995 Freightliner FLD120 Tandem Dump (A62613)
1995 Freightliner...
2012 John Deere 1990 Planter (A63109)
2012 John Deere...
1994 SHOP MADE ENCLOSED TOOL TRAILER (A58216)
1994 SHOP MADE...
2015 GMC 1500 Sierra Crew Cab Pickup Truck (A61573)
2015 GMC 1500...
8x5 Cattle Panel Gate (A64047)
8x5 Cattle Panel...
