Ballast On the subject of ballast
   / On the subject of ballast #21
My wife has told me I'm not a great listener, what if I don't hear the tractor until she screams? :laughing:
You proved her right in post #13. :D
   / On the subject of ballast #22
My SCUT only had to tell me once....
Ballast is 2' x 2' x 1' (4cu ft) and weighs in between 500-600 pounds
Dale
   / On the subject of ballast #23
I have a JD 2025r and my opinion is JD is on the heavy side for ballast needed. I don’t remember the exact numbers but something like filled tires with 700 lbs of rear ballast. I have about 400 lbs in my ballast box and it seems fine to me. They do make ballast box extenders for some boxes that adds several inches around the top. I’ll join the club and say try what you have to start.
   / On the subject of ballast #24
This is a very cool idea. I had been thinking down the path of just buying one or two more ballast boxes, to load at different weights, but that creates a little storage headache. Your solution solves that, but is harder on the back than just backing up to a different box with a quick hitch. Both options to consider...
It's only hard on the back if you lift them manually ;) .....and what size weights/objects are being used. A core 700lb ballast box + ten 40-50lb weights/bags/etc would put you at (or above) 1100lbs.
Alternatively if you wanted to get fancy; additional weight boxes (potentially even just filled with concrete) on casters (or dollies) could be rolled up next to the core ballast box & attached (by whatever means) with no/minimal lifting needed as the 3pt.
....and there's also the route of a carry-all like was mentioned in post #20 by Imold.
Just me, but personally I prefer not to have a whole lot of weight (beyond what is needed) because it's all additional weight that the brakes/engine has to stop ..... which on my flat terrain means there's times I'll move light materials (e.g. mulch, aged manure/compost) without having anything on the back other that the wheel weights. ...again just me, as I tend to keep my hand by/on the loader controls to drop the whole load if/when needed.
All good suggestions, just double or triple the sub-compact size numbers of the last few posts. Remember loader has a lift capacity of 2125 lb with a reach of 59 inches, easily double or triple some of the machines used as examples in the last several posts. But it’s mounted on a machine with a base weight of only 2900 lb. and wheelbase of only 68 inches, making it darn near a seesaw... a 6000 lb. seesaw with a full load, before adding ballast. This is my third Deere loader tractor (previously 750 and 855), and it is by far the most tippy of the three, more than 230% that of the 855, when looking at lift x reach vs. weight x wheelbase.
The total ballast Deere spec’s for this loader on this machine is right around 2000 lb. If taking the proposed 700 lb. box and adding 40 lb. suitcase weights, I’d be looking to add 32 of them for the heaviest jobs. Superbly flexible, but that’s an awful lot of weights to purchase, move, and store. I think I’d be better off just having two or even three different ballast boxes of different weights, definitely more convenient and easier to change weight, when considering the number of weights I’d really need on this machine.
At this point, I’m down to two options, both of which would have me keep my 700 lb. ballast box for a lot of the lighter work, and buying bigger boxes for heavy work:
1. Put 400 - 500 lb. on the rear wheels, either liquid or iron but not both, and buy a second ballast box to load around 1500 lb. This won’t be a Deere ballast box, they don’t make one that big in cat.1, but I believe some others do.
2. Skip the wheel weight, buy that same 1500 lb. ballast box, plus 15 x 40 lb. suitcase weights. This would allow me to drop all weight for lawn jobs (I do a lot of yard work with loader removed), and load up with 700, 1500, or 2000 lb. on the 3-point as needed. Unfortunately, it does very little for my side-hill stability when loaded. It also means I’ll have to continue removing the loader to pull small trailers in 2wd, I presently can’t even get up the hill that is my back yard without either going into 4wd or removing the loader, my rear is just that light.
My gut is telling me to go with option 1, but I’m receiving advice from other channels to go option 2, from some who know my usage patterns, and have substantial experience (Deere dealer, Deere mechanic, and golf course equipment manager). I do have a lot of hilly terrain right around the house (we’re up on a small bluff), which means a lot of side-hill work when mulching gardens and moving my wood trailer around from the wood lot to the house.
   / On the subject of ballast #26
It seems tractor's wheelbases are getting shorter and their loaders are sticking out front farther. I can understand they want better numbers like turning radius and FEL lift height but they are designing a cheap tractor that is unstable without a ton of weight on the rear. Why? My TC33D had the Supersteer option that pushed the front axle further to the front but still had a better turning radius and the loader was shorter to the front of the tractor. It was a much better balanced machine without ballast. Skid steers and my Toolcat have the bucket tight to the front wheels for a reason. These tractors are getting the FEL further and further out the front. Why?
It seems tractor's wheelbases are getting shorter and their loaders are sticking out front farther. I can understand they want better numbers like turning radius and FEL lift height but they are designing a cheap tractor that is unstable without a ton of weight on the rear. Why? My TC33D had the Supersteer option that pushed the front axle further to the front but still had a better turning radius and the loader was shorter to the front of the tractor. Skid steers and my Toolcat have the bucket tight to the front wheels for a reason. These tractors are getting the FEL further and further out the front. Why?
Yeah, I was thinking exactly the same thing, when I was shopping this machine and others. But they’re all doing it, I assume for the reasons you mentioned, better marketing numbers. I don’t think it’s bad, though, you can still make them stable with the appropriate ballast, it just increased the importance and amount of ballast required to use the loader at full capacity.
It appears the big bump in loader capacity was back when Deere introduced the “X” loaders in the early 2000’s. From a friend who used to be a Deere mechanic: “The capacity bump for the loaders was back when the 300, 300X, and the 300CX loaders were introduced, on the twilight of the 4x10 series tractors and the onset of their 3x20 replacements. Your 320R is very similar to the 300CX loaders we were putting on 43/4410's and 3x20 series machines back in 2005. And they were an incremental improvement over the 410/420/430 loaders they replaced. Of course, all of these models have significantly more capacity than what was available when your 855 was new.”
What has changed is the tractors have gotten larger and heavier for each model series. People think the modern 4-series is a replacement for a 4410, but actually my 3033R is exactly the same weight and wheelbase as an old 4410.
Any opinion on option 1 vs. option 2?
   / On the subject of ballast #28
Because power densities are permitting it, and consumers are buying them would be the obvious answer. ;)
After all, are there many (or any) who would turn down a more capable machine in a smaller package? (even if that smaller machine needs a whole lot of add-ons to use the full potential of the machine).
To be honest, between the continuing development of engine technology, the increasing pressures used in hydraulic systems and even advancing material technologies it's probably not long before some of these machines start straying into being legitimately unsafe for use without configuring it for the various specific uses.
   / On the subject of ballast #29
On my 4310 I set the front wheels in the wide position. I haven't found where Deere says not to for loader work on my model but I think they say not to on yours. If I tear up the front axle then I guess I will have to fix it.
On the rear I bought a set of mounted turfs that came on wheels with a greater offset by almost 2 inches each. Set in the wide position my tractor is right at 6 ft wide in the rear.
None of this offsets the front to rear balance but it feels infinitely more stable.
I upsized the cylinders on my loader and I think it would be equivalent to the 430 loader capacity.
The 1200 lbs I put on the 3pt keeps it planted for loader and grapple work. May be harder on the 3pt but still well under the rated capacity.
Ballast on the 3pt is exaggerated by hanging past the axle just like having weight further forward on the loader decreases it's capacity.
My feeling is adding different ballast to the 3pt for different needs makes the most sense to me.
   / On the subject of ballast #30
Think we may have had a miscommunication as I wasn't intending to suggest taking the ballast box to 2000lbs - just to the manufacturer's recommended 1100lbs (or slightly beyond).
I'd always recommend adding at least some weight to the wheels (either liquid, iron, or both) in order to keep the unladen tractor (with loader attached) safely balanced without the use of a rear implement. This also keeps some of the ballast weight off the rear axle as weight on the wheels is usually carried on the wheel itself.
So the recommendation of making the current ballast box selectively heavier was intended primarily to avoid having multiple ballast boxes (and having to shuffle tools between them). In other words, basically option #1 but using add-on weights to take the current ballast box to 1100lbs -- or up to 1500lbs (if possible/wanted/etc).
Personally I would avoid the option of not having any weight on/in the tires. Experience has taught me the rear end can get light when the tractor isn't actively carrying the attached 3pt implement (i.e. the 3pt implement is down and being used rather than carried). Wheel weights can be removed if the loader is removed, liquid can't (or not as easily). However, both iron and liquid are good options.
However, ultimately it's your money, time and choice to make and all the rest of can do is offer options/suggestions.
2014 BRENNER CRUDE TRAILER (A58214)
2014 BRENNER CRUDE...
2016 Kia Optima Sedan (A56859)
2016 Kia Optima...
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2019 Ford F-150...
DRAGON 500 BBL FRAC TANK (A58214)
DRAGON 500 BBL...
Greenworks Commercial 82V CZ60R Zero-Turn Mower- DEMO UNIT (A56438)
Greenworks...
Year: 2016 Make: Ford Model: Taurus Vehicle Type: Passenger Car Mileage: Plate: Body Type: 4 Door (A55853)
Year: 2016 Make...
