T574 hydraulic filter change
/ T574 hydraulic filter change #1
NewfieTractorNut
Newfoundland, Canada
TYM T574 HST
So i am at the 50 hour mark with the new 574 and in the owners manual it says to change the hydraulic filter. However it does not say i need to change the fluid, so i am wondering if i need to drain said fluid to change the filter or if i pull the filter will it dump all the fluid? Is there be a shut off valve to prevent loss of fluid? Kinda lost at the moment any help is appreciated. Thanks
By the way the tractor is a 2020 tym t574 hst
/ T574 hydraulic filter change #2
You will lose a little fluid, but it shouldn't be much. Just check your levels and top off if needed.
/ T574 hydraulic filter change #5
Newfie, I have the RK37 which is made by TYM and it specifically says to change the fluid and filter at the 50 hour service. I can't imagine that machines made by same manufacturer would have different requirements just because they have different name badges. That's just my opinion......Don
/ T574 hydraulic filter change #6
50 hours you should change hydraulic oil AND filter in that TYM if you want to be really proactive.
3097 (A63117)
3097 (A63117)
2015 DITCH WITCH FX25 VACUUM TRAILER (A63276)
2015 DITCH WITCH...
8'C10' ROLL UP METAL SHOP DOOR (A65055)
8'C10' ROLL UP...
2024 JOHN DEERE TURF GATOR TX 4X2 UTV (A63276)
2024 JOHN DEERE...
Wooden Glider Chair (A64557)
Wooden Glider...
2019 GMC SIERRA HD 3500 (A63569)
2019 GMC SIERRA HD...
