T574 hydraulic filter change
   / T574 hydraulic filter change #1
NewfieTractorNut
Newfoundland, Canada
TYM T574 HST
So i am at the 50 hour mark with the new 574 and in the owners manual it says to change the hydraulic filter. However it does not say i need to change the fluid, so i am wondering if i need to drain said fluid to change the filter or if i pull the filter will it dump all the fluid? Is there be a shut off valve to prevent loss of fluid? Kinda lost at the moment any help is appreciated. Thanks
By the way the tractor is a 2020 tym t574 hst
   / T574 hydraulic filter change #2
You will lose a little fluid, but it shouldn't be much. Just check your levels and top off if needed.
   / T574 hydraulic filter change #5
Newfie, I have the RK37 which is made by TYM and it specifically says to change the fluid and filter at the 50 hour service. I can't imagine that machines made by same manufacturer would have different requirements just because they have different name badges. That's just my opinion......Don
   / T574 hydraulic filter change #6
50 hours you should change hydraulic oil AND filter in that TYM if you want to be really proactive.
2021 JOHN DEERE HX14 LOT NUMBER 14 (A53084)
2021 JOHN DEERE...
2013 Kia Soul Hatchback (A51694)
2013 Kia Soul...
2016 Big Tex 24ft. T/A Flatbed Trailer (A50323)
2016 Big Tex 24ft...
2018 Ford F150 XL (A52384)
2018 Ford F150 XL...
2020 Mitsubishi Fuso FEC7TS Cab and Chassis Truck, VIN # 4UZBVH115LGLFU342 (A51572)
2020 Mitsubishi...
Ford Tractor (A50120)
