Snow hydraulic filter block
/ hydraulic filter block #1
hd5
Missouri
MF2705, MF135 XR4046H
I just evidently cracked the hydraulic filter block on my 4046 for the second time in six months .anyone else do this?
I was running over some brush both times. Nothing big. I think I could fix it myself if I knew the part number
Fluid is pouring out above filter. The filter points straight down too far in my opinion.
I'm going to fabricate a guard this time. It cost me 400.00 last time. Any help ??? With part?
/ hydraulic filter block #2
The main hydraulic filter is mounted horizontal on the 4046, guessing you are referring to the hydrostatic filter? Is it a cab model?
/ hydraulic filter block #3
Man I did the same thing but I dont think its cracked, just knocked the filter a little.
/ hydraulic filter block #4
Tractors are just not armored for forestry use. They only design them for use in open fields. Before taking any tractor in the woods, I would invest in armoring all sensitive areas. They make them easy to service, but that leaves the filters exposed.
/ hydraulic filter block #5
You're right. Also the backhoe frame is super easy knock that filter when taking it off or putting on. Bad design I think.
You are correct about not armored I thought I was being carefull
It is not cab model. And I guess it is the hydrostat filter. I think I could do it myself. But they are picking it up today to fix. As soon as I get it back I am fabricating a brush guard out of expanded steel
2017 Dodge Charger Sedan (A61574)
2017 Dodge Charger...
2011 FORD F-150 (A63569)
2011 FORD F-150...
2023 John Deere 400R Spreader (A63109)
2023 John Deere...
2019 CHEVROLET 5500HD LCF S/A  4X2 24FT BOX TRUCK (A59910)
2019 CHEVROLET...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A59904)
2017 FREIGHTLINER...
2022 Kuhn FC4461 TCD MoCo (A63116)
2022 Kuhn FC4461...
