Snow hydraulic filter block
/ hydraulic filter block #1
hd5
Missouri
MF2705, MF135 XR4046H
I just evidently cracked the hydraulic filter block on my 4046 for the second time in six months .anyone else do this?
I was running over some brush both times. Nothing big. I think I could fix it myself if I knew the part number
Fluid is pouring out above filter. The filter points straight down too far in my opinion.
I'm going to fabricate a guard this time. It cost me 400.00 last time. Any help ??? With part?
/ hydraulic filter block #2
The main hydraulic filter is mounted horizontal on the 4046, guessing you are referring to the hydrostatic filter? Is it a cab model?
/ hydraulic filter block #3
Man I did the same thing but I dont think its cracked, just knocked the filter a little.
/ hydraulic filter block #4
Tractors are just not armored for forestry use. They only design them for use in open fields. Before taking any tractor in the woods, I would invest in armoring all sensitive areas. They make them easy to service, but that leaves the filters exposed.
/ hydraulic filter block #5
You're right. Also the backhoe frame is super easy knock that filter when taking it off or putting on. Bad design I think.
You are correct about not armored I thought I was being carefull
It is not cab model. And I guess it is the hydrostat filter. I think I could do it myself. But they are picking it up today to fix. As soon as I get it back I am fabricating a brush guard out of expanded steel
Schuler Feed Wagon (A66408)
Schuler Feed Wagon...
2023 Stearling Trailer (A60352)
2023 Stearling...
International 311 6ft. Pull Behind Mower (A65640)
International 311...
2020 VOLVO EC200EL EXCAVATOR (A65053)
2020 VOLVO EC200EL...
Cattle Feeder (A65640)
2012 VOLVO DBL SLEEPER ROAD TRACTOR (A62130)
2012 VOLVO DBL...
