Starting my search
/ Starting my search #1
Bryan1965
Hilliard, ohio
2016 Kubota L3901
We purchased 8 acres so we could use as a weekend getaway and spend our vacations in the summer and have a place for grandkids to get out of the city. The house sits on top of a hill, most of the property is far below this area. Most of yard is wooded, we have tried to clear a few areas. But it was untouched for years, a lot of growth. Had a neighbor bush hog a main path to the other side of property down the street. From that area, we have to go through a wet area to, get to back of property, in spring it was about 6 inches deep, once we get past that, it is pretty dry
I purchased a JD E140, but have blown 2 tires, and went through blades in like just a few times mowing spots we bush hogged, so will need something bigger
Was looking for a sub compact, but am worried it will be too small. My JD mower is 24HP hard to imagine a 24 HP tractor will be of great use on hills, especially since I want to take gravel down and try to make a land bridge past water area so the back of my property is not useless in spring
Also, will be taking wood up the hill to get to the house as plan on putting in a wood stove and outdoor fire pit.
Other than transport of gravel and wood, main purpose will be bush hog and maintaining or cutting paths into the wooded area.
Have been here for a few weeks, have learned more than I thought I would but still want advice as I make my search. Don稚 want to regret after I buy,
Of note, we own a home in Columbus Ohio, still make payments, there is a 125 year old house we are restoring, there was no septic, and may need to put in a cistern as water is not very good, a lot of iron, most people in area have cisterns also eventually want to put pole barn in, also restoration is not cheap, there were 20 some people living here and they were evicted about a year before we bought it, we do own the home, was able to get a good deal and paid cash.
But as you can imagine, Keeping cost down is essential,
Been looking at RK, but am worried, especially since 2 representatives mysteriously disappeared. Was thinking of RK 24, but am leaning toward RK 37, not sure I can afford a JD or Kubota that has the weight HP I think I need. Never heard of kioti or some of these other bands I have been reading about here. And not sure of dealers in area.
This is my starting point, open to suggestions and help sorry this is so long, wanted to give you as much info as possible so you know where I am at.
/ Starting my search #2
Congrats on the new place. You need to rethink somethings when you live in SE Ohio. There are not many places to purchase from nor get things repaired. There is a Kubota dealer in Quaker City that has been there for years. It may make your tractor selection easier. Also look for a low center of gravity. Get ag tires as the mud and snow will be a problem on the hills. Also load the tires and check for the addition of iron wheel weights. Purchase a good heavy rotary cutter. Watch CL for the area and you should be able to find other equipment used at a good price. Spend the money for a good solid gate and make sure you hire a neighbor to watch the place if you are not moving there. I grew up in Caldwell and I will never be able to live there again but I love the area.
/ Starting my search #3
Was looking for a sub compact, but am worried it will be too small. My JD mower is 24HP hard to imagine a 24 HP tractor will be of great use on hills, especially since I want to take gravel down and try to make a land bridge past water area so the back of my property is not useless in spring.
There is no comparison at all between a lawn cutter with a 24Hp gasoline engine and a SCUT with a 25Hp diesel engine. They are worlds apart in capabilities.
Don't be afraid to look at Blue. Those of who have like them as well as the extra cash in our pockets to buy other things.
/ Starting my search #4
I only have 6 acres but I went with a 48hp tractor in the 5,000lb range. I do a lot of lifting both front and rear. If you shop uses, especially 2wd, you can get a lot of bang for your buck in the 50ish range. I only paid $5000 with bush hog and loader used. Granted its 20-30 years old.
Do you have 2wd? I am worried about getting stuck especially on hills, I already had to use my ATV to get my JD unstuck
/ Starting my search #6
I have hills, and I wouldn't suggest 2wd, especially with a loader. In 2wd, I've gotten stuck on wet grass trying to go uphill.
thank you,
I worked on diesel and gas electric generators for about 20 years, I understand a 24 diesel will have more power, especially at lower rpm, which we need to lifting and other heavy work.
I still am worried about using a bush hog especially on hills. I have a prety steel hill to get up and down to the different elevations, especially if I am hauling logs or gravel. At least from many threads I have read here seems to be a big complaint. That’s why I was looking for 30 plus at the least unless people an talk me down.i almost got a 24 hp as it was well within my price range, but am worried
Thanks, that’s what I was worried about!
By blue I assume you mean new holland.
/ Starting my search #10
My suggestion is to get bigger than what you think you need because once you start using a tractor you will be amazed at the things you use it for.
/ Starting my search #11
thank you,
I have a hill almost too steep to walk. I can do it, but it takes effort. I mow it with the belly mower. I wouldn't even try to use a trailing mower though the previous property owner did with his larger JDs. I'm ALWAYS in 4WD when on my hills.
Nope. LS, as in my sig.
This seems to be a common idea in here. Which is why I stopped and joined, I love to research anyway and what a better way then to talk to people who own them
I will most likely is my JD to mow around the house and up and down hill, but still need to get everything up and down as I store everything by the house
/ Starting my search #15
Oh ok, another name I never heard off. Lol
LS builds all the SCUT and CUT up to 50 HP ( I think) for New Holland.
So buying a New Holland is just paying the extra for the name.
/ Starting my search #16
You'll most likely destroy the transmission in fairly short order if you do. I have a tired old hand me down JD X300 I can use on the hill, but only for a few passes. Then I have to let it cool. Lawn cutter hydros don't like work.
/ Starting my search #17
We purchased 8 acres.
RK Tractors RK37S
2017 -
Compact Utility tractor
Production:
Distributor: RK Tractors (a part of Rural King)
Manufacturer: TYM
Original price (USD)
$16,999 (2017 )
Variants:
RK37S: shuttle ROPS
RK37H: hydrostatic ROPS
RK37SC: shuttle cab
RK37HC: hydrostatic cab
RK Tractors RK37S Engine:
Yanmar 1.6L 3-cyl diesel
RK Tractors RK37S Power:
Engine (gross): 37.4 hp [27.9 kW]
PTO (claimed): 30.2 hp [22.5 kW]
Capacity:
Fuel: 9 gal [34.1 L]
3-Point Hitch:
Rear Type: I
Control: position control
Rear lift (at ends): 2646 lbs [1200 kg]
Rear lift (at 24"/610mm): 1764 lbs [800 kg]
Power Take-off (PTO):
Rear PTO: independent
Clutch: electro-hydraulic
Rear RPM: 540 (1.375)
Dimensions
Weight: 3065 lbs [1390 kg]
Wheelbase: 64.5 inches [163 cm]
Length: 126 inches [320 cm]
Width: 53.5 inches [135 cm]
Height (ROPS): 94.5 inches [240 cm]
Ground clearance: 12.8 inches [32 cm]
Loader:
Loader type: RK Tractors L102
Weight: 1052 lbs [477 kg]
Height (to pin): 102.3 inches [259 cm]
Clearance, dumped bucket: 77.4 inches [196 cm]
Dump reach: 23.2 inches [58 cm]
Dump angle: 40
Reach at ground: 67.2 inches [170 cm]
Rollback angle: 30
Breakout force (at pin): 3435 lbs [1558 kg]
Lift to full height (at pin): 2116 lbs [959 kg]
Bucket width: 62 inches [157 cm]
Attachment style: quick coupler
Mechanical:
Chassis: 4x4 MFWD 4WD
Steering: power
Brakes: wet disc
Cab: Two-post ROPS.
Hydraulics:
Valves: 1
Pump flow: 6.4 gpm [24.2 lpm]
Total flow: 11 gpm [41.6 lpm]
Steering flow: 4.6 gpm [17.4 lpm]
Electrical:
Ground: negative
Charging system: alternator
Charging amps: 55
Battery:
Number: 1
Volts: 12
Page information:
Last update: September 26, 2019
Copyright: Copyright 2019 TractorData LLC
Contact: Peter@TractorData.com
RK37 has similar specs to Kubota L3309. In my opinion RK37 is ample for eight acres.
RK37 will be able to power a Heavy Duty 60" Rotary Cutter through practically anything, but not a 72" Heavy Duty Rotary Cutter.
If this will be your first tractor, satisfy yourself that Rural King will be able to service the machine. How distant is your NEAREST Rural King store?
RK37, Kioti and LS are all manufactured in Korea by Korean companies.
I just looked, there is a dealer close to cambridge, I will have to check it out. Thanks. Nothing near hilliard, so will have to wait till I head back out east
/ Starting my search #19
We'll get into the whole 'what's in a dealer' schpiel here in a bit. LS dealers tend to be independent operators, farm stores, mom & pop shops, etc. LS doesn't have the big fancy glass and chrome megastores like others do, so they don't have any of that overhead. You say you have mechanical aptitude, so you have less to be concerned about than many.
My hill path is actually very narrow, I can mow it in like 2 passes down and two back up.
2025 Pabreak 80in. Skeleton Grapple Skid Steer Attachment (A61567)
2025 Pabreak 80in...
2025 TEXAS PRIDE 14FT T/A DUMP TRAILER (A59910)
2025 TEXAS PRIDE...
SDlanch SDLGC80 (A60462)
SDlanch SDLGC80...
2011 JACK COUNTY 130 BBL VACUUM TRAILER (A63569)
2011 JACK COUNTY...
2014 International WorkStar 7300 4x4 Altec AA55E 55ft. Material Handling Bucket Truck (A60460)
2014 International...
2004 Gradall XL3100 Highway Speed Wheeled Excavator (A64194)
2004 Gradall...
