Starting my search
/ Starting my search
We'll get into the whole 'what's in a dealer' schpiel here in a bit. LS dealers tend to be independent operators, farm stores, mom & pop shops, etc. LS doesn't have the big fancy glass and chrome megastores like others do, so they don't have any of that overhead. You say you have mechanical aptitude, so you have less to be concerned about than many.
Yes that place sells a lot of stuff, basically an Ag store. Ls tractors are one item they sell
RK Tractors RK37S
2017 -
Compact Utility tractor
Production:
Distributor: RK Tractors (a part of Rural King)
Manufacturer: TYM
Original price (USD)
$16,999 (2017 )
Variants:
RK37S: shuttle ROPS
RK37H: hydrostatic ROPS
RK37SC: shuttle cab
RK37HC: hydrostatic cab
RK Tractors RK37S Engine:
Yanmar 1.6L 3-cyl diesel
RK Tractors RK37S Power:
Engine (gross): 37.4 hp [27.9 kW]
PTO (claimed): 30.2 hp [22.5 kW]
Capacity:
Fuel: 9 gal [34.1 L]
3-Point Hitch:
Rear Type: I
Control: position control
Rear lift (at ends): 2646 lbs [1200 kg]
Rear lift (at 24"/610mm): 1764 lbs [800 kg]
Power Take-off (PTO):
Rear PTO: independent
Clutch: electro-hydraulic
Rear RPM: 540 (1.375)
Dimensions
Weight: 3065 lbs [1390 kg]
Wheelbase: 64.5 inches [163 cm]
Length: 126 inches [320 cm]
Width: 53.5 inches [135 cm]
Height (ROPS): 94.5 inches [240 cm]
Ground clearance: 12.8 inches [32 cm]
Loader:
Loader type: RK Tractors L102
Weight: 1052 lbs [477 kg]
Height (to pin): 102.3 inches [259 cm]
Clearance, dumped bucket: 77.4 inches [196 cm]
Dump reach: 23.2 inches [58 cm]
Dump angle: 40
Reach at ground: 67.2 inches [170 cm]
Rollback angle: 30
Breakout force (at pin): 3435 lbs [1558 kg]
Lift to full height (at pin): 2116 lbs [959 kg]
Bucket width: 62 inches [157 cm]
Attachment style: quick coupler
Mechanical:
Chassis: 4x4 MFWD 4WD
Steering: power
Brakes: wet disc
Cab: Two-post ROPS.
Hydraulics:
Valves: 1
Pump flow: 6.4 gpm [24.2 lpm]
Total flow: 11 gpm [41.6 lpm]
Steering flow: 4.6 gpm [17.4 lpm]
Electrical:
Ground: negative
Charging system: alternator
Charging amps: 55
Battery:
Number: 1
Volts: 12
Page information:
Last update: September 26, 2019
Copyright: Copyright 2019 TractorData LLC
Contact: Peter@TractorData.com
RK37 has similar specs to Kubota L3309. In my opinion ample for eight acres.
If this will be your first tractor, satisfy yourself that Rural King will be able to service the machine. How distant is your NEAREST Rural King store?
Thank you, everything I haveLooked at I look at tractor data.com. Kept me from buying a few used tractors!
/ Starting my search #23
I would take a look at a JD 2 series or Kubota B series. 20k will get you a brand new one.
/ Starting my search #25
RK37 has similar specs to Kubota L3309. In my opinion RK37 is ample for eight acres.
RK37 will be able to power a Heavy Duty 60" Rotary Cutter through practically anything, but not a 72" Heavy Duty Rotary Cutter.
RK37, Kioti and LS are all manufactured in Korea by Korean companies.
Have you ever measured the angle of the slope?
No I just know it scared me when I first went up it with the mower and my ATV. Was worried about flipping the ATV, and getting the e140 stuck
$18K got me a tractor, FEL, mower, backhoe, 48" tiller and middlebuster/subsoiler.
I would probably be looking at MT2 series. Unless I can be convinced to get a 24. They compare to the rk 24 (MT1)and Rk 37 (MT2) which I have been investigating.
/ Starting my search #29
I'll second the advice to get more tractor than you think you may need, and to look at all manufacturers as well. I am on 5 wooded acres, and 3 months ago bought a 45 Hp LS XR4145HC 4,400 lb bare weight tractor. I haven't regretted the size for a second.
I've been very impressed by the "fit and finish" of my LS as well. I just finished completely removing all of the interior panels in the cab (ceiling, side pillars and interior fender mounts) to install and wire up a backup and implement camera, and while I was in there, install a stereo and put in new speakers. I was pleasantly surprised with how professionally everything was wired up with cables protected from abrasion, fully-secured to avoid rattles and vibration, sealed-up to be water tight and minimize sound transmission, etc.
/ Starting my search #30
I suggest you measure the slope angles in several places before you continue your tractor search. ;)
Thank you, great information. Good to know, rktractorguy (no longer here) explained why RK is lower, it does always make you worry that some lower quality to,get the lower price.good to see firsthand that quality is still up there
Thank you, one thing I hope to do is find another area less steep, but need a bush hog and to cut some trees back to see what’s under the growth. My son also drives his 4x4 jeep down that hill, afraid it will get worse
/ Starting my search #33
Take a look at Massey Ferguson. They don稚 cost as much as JD or Kubota.
Go look at everything near you and drive them see what you like best. Then go from there.
Good luck on your search
/ Starting my search #34
I know you all are trying to be helpful but there are very few tractor dealers in and around Salt Fork. The Kubota dealer is the only one nearby and he has 4 stores in SE Ohio to draw from. The land is very hilly and muddy a lot of the year. Most of the winter it is to warm to freeze the ground solid. A larger tractor would be ideal but there is a budget to consider. I would suggest a L2501 for a weekend house. It will allow you to transverse the terrain better then then B models due to the larger tires. Set the wheels out wide and practice hill side safety rules. Use the 4wd to help with braking.
fyi, Besides the kubota in Quaker city. I have rural king in New Phili and an LS dealer in Dennison. I think there is a JD in cambridge, I also have a JD (Ag Pro) less than 2 miles from my home in hilliard and a place I can get kioti not to far from columbus as options. Have not researched any of the others. I am also looking for used.
if I go kubota will most likely be L3301. I am worried about the 24 HP 2501 being to small.
/ Starting my search #36
We have 8 acres as well. My background is operating heavy equipment. My suggestion if you need to build roads or make a path, clear areas. Better off to rent an excavator and do the work with that. Be ready to have a tire repair kit as those are very useful when you own a tractor. As far was what you should buy. Sounds like you need some weight for the area. Just keep in mind it doesn't matter what you have or how big it is. Tipping a tractor is relatively easy. Especially if you are in a unfamiliar area. Part of the reason why i think you should rent an excavator. Good luck
After RK told me we could not add any rental back hoe to the tractor. I already decided I was going to rent the whole machine. Most of the work will be adding dirt and gravel to raise the area, with pipe buried to allow water to run from one side to the other, as i already have the main path finished. Well do what I have to when I open new paths. But most will be dry.
its to bad you can't rent back hoes.. but already have my machine scoped out I am gonna rent to dig a few trenches and get some stumps out.
/ Starting my search #38
A possible issue with renting hydraulically operated attachments and using them on a machine that you owned is you never know what kind of contaminates could be in that fluid from previous users/renters, and what it might do to your hydraulic system components.
hmm never thought of this. Thanks.. Still cheaper to rent a machine.. Saved me 7 - 8 thousand if I do not have to get a BH
/ Starting my search #40
We purchased 8 acres so we could use as a weekend getaway and spend our vacations in the summer and have a place for grandkids to get out of the city. The house sits on top of a hill, most of the property is far below this area. Most of yard is wooded, we have tried to clear a few areas. But it was untouched for years, a lot of growth. Had a neighbor bush hog a main path to the other side of property down the street. From that area, we have to go through a wet area to, get to back of property, in spring it was about 6 inches deep, once we get past that, it is pretty dry
I purchased a JD E140, but have blown 2 tires, and went through blades in like just a few times mowing spots we bush hogged, so will need something bigger
Was looking for a sub compact, but am worried it will be too small. My JD mower is 24HP hard to imagine a 24 HP tractor will be of great use on hills, especially since I want to take gravel down and try to make a land bridge past water area so the back of my property is not useless in spring
Also, will be taking wood up the hill to get to the house as plan on putting in a wood stove and outdoor fire pit.
Other than transport of gravel and wood, main purpose will be bush hog and maintaining or cutting paths into the wooded area.
Have been here for a few weeks, have learned more than I thought I would but still want advice as I make my search. Don稚 want to regret after I buy,
Of note, we own a home in Columbus Ohio, still make payments, there is a 125 year old house we are restoring, there was no septic, and may need to put in a cistern as water is not very good, a lot of iron, most people in area have cisterns also eventually want to put pole barn in, also restoration is not cheap, there were 20 some people living here and they were evicted about a year before we bought it, we do own the home, was able to get a good deal and paid cash.
But as you can imagine, Keeping cost down is essential,
Been looking at RK, but am worried, especially since 2 representatives mysteriously disappeared. Was thinking of RK 24, but am leaning toward RK 37, not sure I can afford a JD or Kubota that has the weight HP I think I need. Never heard of kioti or some of these other bands I have been reading about here. And not sure of dealers in area.
This is my starting point, open to suggestions and help sorry this is so long, wanted to give you as much info as possible so you know where I am at.
No one here has recommended Branson.
The TBN member (ptsg) in post #15 owns a Branson, and is apparently very happy with his.
I have never seen a Branson, but after reading reviews, Branson would be the very first place I would look, followed by LS.
2018 Ford F250 4x4 Ext. Cab Pickup Truck (A64194)
2018 Ford F250 4x4...
K & F 14" CUT-OFF SAW (A64276)
K & F 14" CUT-OFF...
New/Unused Landhonor 26ft x 13ft Metal Carport (A65583)
New/Unused...
Carryall 1700 4x4 (A61574)
Carryall 1700 4x4...
Frontier Quick Attach Pallet Forks (A64126)
Frontier Quick...
2009 BMW Sedan (A61569)
2009 BMW Sedan...
