Chainsaw self sharpening attachments
/ Chainsaw self sharpening attachments #1
beowulf
Central California Foothills
Kubota L3410 HST, J Deere riding mower
An ad for an attachment which is supposed to sharpen the chain teeth simply by running the chainsaw (goes on the end of the bar) popped up today. Intriguing idea, but I am typically suspicious of things that would make things too easy to believe. But, still, it would be nice.
Does anyone have any experience with these? I would post the link to the ad here, but not sure that is permitted. If it is, I will come back and post it.
The cost was only $19.95 so I suppose it is worth a try - as long as it would not make thing worse or harm the saw somehow. Just wondering.
/ Chainsaw self sharpening attachments #2
It needs to be a complete system. No way one of those cheap stone thingies will sharpen and regular chain properly.
/ Chainsaw self sharpening attachments #3
Years ago I had a 16" Craftsman with what they called a Barracuda Chain. It had a sharpening stone on a pivoting handle built into the clutch housing. The chain design had the teeth facing upward with a chisel edge. All you had to do to sharpen it was to rev the engine and pull back on the stone handle for a few seconds. Rumor had it that anti kickback safety legislation was the end of the design. It was an awesome little saw I would pit against any saw on the market. I would have probably kept it and rebuilt it forever but parts dried up and became unavailable.
I made a bet with a buddy once I could cut through a 16" log with it before he could with his Husqvarna bow saw. He pushed so hard on his saw trying to keep up his chain jumped about half way through. About that same time I was done. It was one wood eating SOB.
/ Chainsaw self sharpening attachments #7
If something is too good to be true . . .
I quickly Googled "Oregon Powersharp". In addition to the bracket, stone, and special chain one would need a new bar that would accept the device, only available in 14 - 18" lengths. The only chain was 3/8 low profile 0.050 gauge which would likely mean a new sprocket. The fine print says "Compatible with certain models [my emphasis]of the following brands: [extensive list of brands but not models]", elsewhere "Up to 42 cc". I think the $19.95 price is only for the stone, certainly not the chain, bar, etc. My local power equipment shop doesn't sell it.
/ Chainsaw self sharpening attachments #9
I bought a used Stihl 170 with one of those... I had them swap it out for a real bar and chain. I go through chains quickly enough without having that added expense.
/ Chainsaw self sharpening attachments #10
Here's an Oregon chainsaw with the sharpener built in. . . . Oregon CS1500 18 in. 15 Amp Self-Sharpening Corded Electric Chainsaw Amazon.com : Oregon CS15�� 18 in. 15 Amp Self-Sharpening Corded Electric Chainsaw : Garden & Outdoor
Stihl's least expensive corded electric chainsaw is around $160; their 15 amp saw (MSE 210) is around $450. The Oregon on Amazon is around $130. If you get what you pay for and you are getting an automatic chain sharpener with the Oregon, how much chainsaw are you getting?
/ Chainsaw self sharpening attachments #11
I also sharpen my own chains.
Hey, as long as you don't hit a nail or try to cut a stone sharpening (tweaking) is a no brainer.
Just grab the proper file and every second tank fill give each tooth one or 2 strokes simply following (eyeballing) the existing angle.
LOL, even if off a degree or two on the angles I suspect the cordwood production won't suffer all that much.
Thanks for the input. I clearly don't need the hassle - and apparently it would not work with any of my saws (Husqvarna Rancher, Echo 58V, Craftsman pole saw, or my 2 or 3 small corded saws I keep around -in the wood shed - for small jobs). I will keep sharpening by hand or with my Granberg sharpener (hooks up to tractor battery or battery charger).
/ Chainsaw self sharpening attachments #14
Oregon came out with those a few years ago. There is a reason thy never really took off.
Learning to sharpen is not at all difficult. Sharpening freehand with just a round file takes some practice to do well, but I've taught people to use one of the several file guides out there in just a few minutes. By the time they've touched up a chain or two, they are getting very good results.
/ Chainsaw self sharpening attachments #15
/ Chainsaw self sharpening attachments #16
I used to only file sharpen my saws and hand split my firewood, but after 40 years of that I now use an electric splitter and an Oregon bench grinder.
I have started touching up with the file again before it gets too dull but in general, sharpening is now on the bench in the warm shop.
Ordered 2 new chains for the Jonsey 2172:D
2012 Ford Explorer SUV (A61574)
2012 Ford Explorer...
1993 International 4700 Crew Cab Landscape Dump Truck (A61573)
1993 International...
5' Bush Hog Mowing Deck (A62613)
5' Bush Hog Mowing...
38" FIRE PIT RING / DISK (A64281)
38" FIRE PIT RING...
2004 COMBILIFT CL30060LA45 FORKLIFT (A63276)
2004 COMBILIFT...
2016 FORD F550 CREW CAB SERVICE TRUCK (A59905)
2016 FORD F550...
