Pat's Easy Change Pat's Quick Hitch - [Not] a complaint
/ Pat's Quick Hitch - [Not] a complaint #1
Mudfarmer
Gold Member
Western Washington
JD 3005, Kubota B2710, Kubota B2650 (sold the ford 1700 and kubota B7100)
I got a set of Pat's from the TractorBy Net black Friday sale to put on my new Kubota B2650. I have older model Pat's on my other tractors and between them and a hydraulic top link, hooking up an implement is not easy but the least difficult that I can make it. Imagine my surprise when I went out a couple of days ago to install the new Pat's and they didn't fit!. The first thing to note is that although the design hasn't really change, Pat's are no longer fabricated from steel plating, but rather forged whole. That is not the problem. The issue came in trying to push the pins through the lower arm receiver balls (for want of the technical name). The pins were two large. I thought at first it might be that the paint having not worn off was impeding them. But, no, the pins were just too large. I don't think this was Kubota's problem. Pictured is my solution . Fortunately I had some pins on hand that were right sized. One of the Pat's pins is at the bottom of the photo. Since I don't have need for the Pat's spreader bar (adjustable sway bars rather than turn buckles on the Kubota) these will work just fine. Maybe some one one ought to tell Pat's.
MF
/ Pat's Quick Hitch - [Not] a complaint #2
I too got Pat's on the black Friday sale and they installed perfectly on my Kioti CK2610HST.
/ Pat's Quick Hitch - [Not] a complaint #3
Someone may have packed the wrong pins possibly.
/ Pat's Quick Hitch - [Not] a complaint #5
I also bought through Tractorbynet black Friday sale. I got Pat's cat 2 to cat 1. They are welded steel not cast. Mine came with 2 1 1/8" pins, one fit and 1 didn't. It looked like maybe it wasn't forged quite right. A little grinding and it slipped right in.
/ Pat's Quick Hitch - [Not] a complaint #6
What difference does it make whether PAT'S is forged or fabricated from steel plating? Just curious.
/ Pat's Quick Hitch - [Not] a complaint #7
Should result in more uniform fit.
Not sure what's going on with the pins.
/ Pat's Quick Hitch - [Not] a complaint #8
The Pat's are cast,,, not forged,,
if they were forged, they would cost three times what fabricated ones would cost,,
Mine are perfect, but, I did change the hardware to Grade 8 bolts, of the correct length,, no nuts,,,
Now, I gotta use them for something besides carrying my chain,,, :confused2:
:laughing:
/ Pat's Quick Hitch - [Not] a complaint #9
I guess that "cast" means that they are poured steel into a mold. Forged products must be a special treatment for durability. Guess I could (google) look all that up. As to PAT'S, I guess a "cast" product is all that's is needed for ordinary usage.
I gotta get me some of those grade 8 bolts of the correct length.....That sure makes a cleaner looking mount.
/ Pat's Quick Hitch - [Not] a complaint #11
I took my old pat's off my 3940 and put them on my 2650. One of my pins fell out while rototilling. I came up with the same solution you did.
/ Pat's Quick Hitch - [Not] a complaint #12
Forged is when the metal is hammered, squeezed, or forced into shape. It takes heavy equipment vs just a mold metal is poured into.
/ Pat's Quick Hitch - [Not] a complaint #13
On a trip to Iowa once, I was offered a tour of the JD plant that made cotton strippers. There I saw the Forging Process and yes you take a glowing orange, Ingot, with a pair of tongs (in this case), and stick it into a huge press, do the process and the ingot comes out in a different shape. Then into the cooling medium being some kind of oil....in this case...have heard Peanut Oil delivers the right temper in a/some Forging process(es).
My Cat II Pat's are definitely Cast. My take on casting vs cold rolled steel is that the ductility of the steel can be important in some applications where cast iron is not ductile and when the material stress limits are overcome, it will break, like a high tensile Grade 8 bolt (acting like a cast part) vs Grade 2 (acting like a cold rolled steel part) as an example.
2018 GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A67714)
2018 GENERAC...
2007 HEIL TRAILER (A67714)
2007 HEIL TRAILER...
GAS CYLINDER TRANSPORT BED (A67714)
GAS CYLINDER...
2006 Heil DOT 406 9,500 Gallon Comp T/A Fuel Tanker Trailer (A68183)
2006 Heil DOT 406...
1998 TRAILMASTER PUP FUEL TRAILER (A67714)
1998 TRAILMASTER...
PORTA POTTY (A68842)
