Hooks on Bucket
/ Hooks on Bucket #1
Logan979
Member
Kubota
should I weld a base plate & then grab hooks on plate or just grab hook ? going on a 6'6" skid steer QA Kubota 525 loader. L3901 tractor ?
/ Hooks on Bucket #3
I'll go along with Jeff. I got Ken's hooks and they're great. If you do your own you should probably put a plate inside the bucket as well as one outside to add extra strength.
/ Hooks on Bucket #4
Another vote for Ken's Bolt on Hooks
/ Hooks on Bucket #5
Did I say I'm cheap?
I modified a standard 3/8 hook* and welded it onto 3 x 4 1/4plate and then the plates onto my bucket center.
That was like 12 years ago.
More than a few times I kind of 'tested' the hook as I actually have raised the tractor rear end off of the ground! (and I have a ballast weight as well as my tires are loaded).
Total cost was one chain hook, a cut off disk and probably 2 welding rods and 1/2 hour.
* local stores could not supply 'weldable hooks'.
also a 3/8 can handle 5/16 chain.
/ Hooks on Bucket #6
I sort of did my own thing.... I could make these for about 1/3 the cost of "other" options...
About 2 feet of 2 X 1/4 inch angle iron, 6 bolts (grade 8), 6 nuts, 12 flat washers, 6 lock washers...
Dale
/ Hooks on Bucket
so ---- is bolting the preferred method ? this Kubota 525 bucket is 2 layers thick, will I be able to drill it or ask Ken ?
BTW love the slits never thought of that.
/ Hooks on Bucket #8
I was planning on adding hooks to my bucket but once I put the grapple on I hardly ever us the bucket it seems. Have only had it on once to move some dirt since then so decided not to worry about hooks. With the grapple I can just run a chain through and use it. Moved a couple of new shooting benches into place that way and it worked fine.
/ Hooks on Bucket
Q: What if the top of my bucket is double-walled?
A #1: Some heavy duty buckets have a double wall construction on the top, and bolting hooks to them could damage the bucket by compressing the wall’s together, and you would not be able to properly torque the bolts. If you have this type of bucket construction, then these hooks may not be the best option and you should consider having the hooks welded on.
In summery, KBOGH/BoltOnHooks LLC does not recommend or endorse the use of the bolt on products for these heavy duty, double walled style buckets.
Thanks for bringing this to my attention
/ Hooks on Bucket #10
I did bolt on because If I sell tractor new owner may not want them, and my welding is not quite professional grade, but they do not fail (yet)...
Dale
/ Hooks on Bucket
What manufacturer grapple, what size ?
/ Hooks on Bucket #12
I have an Armstrong Ag Mini Grapple. IT is 60 inches wide and opens to 45 inches, so has a big bite. It has 11 tines with 6 inch spacing and weighs 440 pounds. IT has 2 2 1/2 x 7 cylinders. Cost me I believe $1,100 at the local dealer. So far no issues and I've worked it pretty good. The below is a Yaupon Holly I pulled with it. Got all the brush in the background burnt today. Yay! finally caught up on burning brush.
/ Hooks on Bucket #14
The area where the hooks will mount is not doubled, they will go on that heavy plate the runs across the top and there is access from the rear. Here is one picture, there is more on the Kubota page - we have a section dedicated to the style bucket you have.
Thanks for your interest in our products.
/ Hooks on Bucket #15
I had my friend who is a very good welder zap on two 3/8" grab type hooks on the corners of the bucket. I'm not really a fan of bolting things on in an application like this.
/ Hooks on Bucket #16
Per: Proof Load Tensil Strength For Grade 2, 5, & 8 a grade 8 5/16" coarse thread bolt has a proof strength of 6300#.
A pair of them should be good for 12,600#, at a 3 to 1 safety margin, that is 4200#, more than most any of us can lift with a loader (or even pull on a unreinforced bucket without it pulling through).
Aaron Z
/ Hooks on Bucket #17
iF bolt is good quality and correctly sized it will survive any pulling you can load it with, chain will probably be first place to expect failure.... Welds of hooks (not commercially made and proof tested) probably second place failure will occur...
I am using a 1/4 inch chain proof tested to 1,250 pounds with two bolts rated at 12,000 lbs tensile strength (for each slot bracket or shackle mount) on a tractor the can only apply 1400 pounds ground/traction weight... Don't see my bolts failing, maybe pulling through base material first....
Dale
/ Hooks on Bucket #18
Just an option to the hooks. Slotted angle iron has several advantages. You can hook from front or the backside of the bucket, the angle iron adds strength to the top of the bucket and there are more slots along the top of the bucket to hang excess chain or to vary where you are hooking too.
/ Hooks on Bucket #19
Another satisfied user of Ken's product. I went with bolt on because I did not have a welder at the time.
610468d1561565504-piranah-bar-kicks-arse-piranha-jpg
UNKNOWN  SPOOL TRAILER (A58216)
UNKNOWN SPOOL...
(INOP) 1995 CATERPILLAR 446B TURBO BACKHOE (A62129)
(INOP) 1995...
2015 BOBCAT T770 SKID STEER (A62129)
2015 BOBCAT T770...
2016 Chevrolet Express 2500 Cargo Van (A61568)
2016 Chevrolet...
2022 New Holland C327 Compact Track Loader (A63118)
2022 New Holland...
2005 Chevrolet Impala Sedan (A61569)
2005 Chevrolet...
