What have you done to your Branson today?
   / What have you done to your Branson today? #432
I was impressed when Pedro first showed pictures earlier of his homemade FEL. Now that I see he also made his own rams: I am REALLY impressed.
   / What have you done to your Branson today? #433
Thanks for sharing the video Bob.
It's a time consuming build but in the end, it's very rewarding to see it working.
I've had a couple people not believing that it was actually a home-built loader, so I guess I did something right. :)
   / What have you done to your Branson today? #434
Pulling 6x6x8' posts out of the ground. Shoulda set 10 footers in the first place so re-doing it. Mostly I wanted to show you guys the:
1) 3 Point to Universal Quick Tach Adapter and
2) 60" Tree Boom Attachment.
I purchased both from Titan attachments for about $600 including taxes and shipping.
I ran the engine and cycled the hydraulics to coat the cylinders, checked tire pressures. I am going to catch up to the thread, sorry.
The original battery gave up the ghost last season. Recently, changed fluids, and removed seat panels to access grease zerks and clean out rodent nest. Recently, I noticed fluid coming from the front axle. R&R the front axle breather fitting (ds near hood) since it got obstructed.
   / What have you done to your Branson today? #437
Lots of running around today, scraped about 3 inches of snow yesterday afternoon just scraped again another inch,
went to start sander truck to spread some sand and ashes, danged battery dead.
So now I have the ashes dumped in the tractor bucket, guess I'll run into town get 5 gallons of gas for the sander motor
and 10 gallons of K1 dump 5 gallons in the tractor for the low temps coming up this week.
When I get back from hopefully batterys are up enough to start truck and get it loaded and spread on the driveway.
   / What have you done to your Branson today? #438
This week I decided to fix my air conditioner that didn't work this past summer. A couple of months ago a friend, who has the equipment, charged it with refrigerant. We checked and checked and finally found a very small leak on a crimped fitting on the line from the compressor to the condenser. The line has two 10mm O.D. aluminum tubing ends connected by a crimped-on rubber hose. I ordered a new line from Branson, and when it came in it was wrong. The part number listed in the parts book for the 4720ch is the wrong part for my 4720ch. It seems Branson changed condensor suppliers somewhere along the line. The listed condensor has an inlet port in a different location than mine. My dealer has put in several hours in trying to help me, but so far Branson's parts dept. hasn't been able to track down the proper part.
I called a hydraulic hose shop, and they said they could probably repair it. So yesterday I finally got around to taking the line off to try and get it fixed. After driving several hundred miles, and visiting several stores (5 in total) who specialize in that sort of work, I was unable to find anyone who would repair or replace the line because 1) they didn't have the right sized repair materials to fit this line 2) they couldn't silver solder and adapter to the existing ends on my line because they are made of aluminum, 3) one shop said they could send it off and TIG weld new hose fittings on to the old ends, but it would cost about $200 for the repair and take a week to do. 4) No one had the proper end fittings to fabricate a totally new line. Finally in frustration, at the end of a long seeming unproductive day, I went back to the "House of Hose" in Spokane (they were the most friendly shop I had been to) and told them what I have been through. The manager listen to my story and apparently felt sorry for me. He made a repair using my old ends and crimping on a new 13/32" I.D. air hose (as close to the original 10mm hose as he could find). He said he wouldn't guarantee the results, but was fairly confident it would hold pressure. So I am putting back together tomorrow, pull a vacuum on it, and will heat up my shop nice and warm so it will get a good charge, and hope it works next summer.
   / What have you done to your Branson today? #439
...I went back to the "House of Hose" in Spokane (they were the most friendly shop I had been to)
We must have driven past each other. I was at Costco across the street today!
.... The manager listen to my story and apparently felt sorry for me. He made a repair using my old ends and crimping on a new 13/32" I.D. air hose (as close to the original 10mm hose as he could find). He said he wouldn't guarantee the results, but was fairly confident it would hold pressure. So I am putting back together tomorrow, pull a vacuum on it, and will heat up my shop nice and warm so it will get a good charge, and hope it works next summer.
I'd be concerned with how the rubber air hose reacted with the refrigerant and oil. It could deteriorate and clog your metering device and contaminate your whole system.
DRILL CABINET SKID (A58214)
DRILL CABINET SKID...
2022 Ford F-150 XL Pickup Truck, VIN: 1FTFX1E88NFB23656, Extended Cab, 4 x 4, 3.5 L EcoBoost Gas (A59076)
2022 Ford F-150 XL...
XCMG CV83PD (A53317)
2007 Ford F-550 Crew Cab 11ft Flatbed Truck (A55852)
2007 Ford F-550...
LOT OF PALLET RACKING (A58374)
LOT OF PALLET...
2022 FREIGHTLINER CASCADIA SLEEPER (A56129)
2022 FREIGHTLINER...
