Building with railroad rails
/ Building with railroad rails #1
bcp
Super Star Member
SW WA
Kubota BX2360
Every once in a while, someone will mention building a bridge or some other thing using railroad rail for strength. Rail is far more flexible than most people think, Many people are only familiar with short lengths, but long pieces are different. :)
Watch this video from about 6:15 to 7:50. It is a telephoto view that exaggerates the flexibility, but is still surprising.
Bruce
/ Building with railroad rails #2
Ribbon rail...
/ Building with railroad rails #3
I have a piece here that will probably never get used. I have seen them drop and break.
/ Building with railroad rails #4
I once saw a pole building a guy built, using railroad rails...
SR
/ Building with railroad rails #5
Steel composition is a malleable mixture, designed to be flexible. For bending moment elimination they have to set on a structural base that is also somewhat flexible; as wheels go over it there is constant vertical movement as weight goes off and on. As they flex and crystallize, they have to be replaced before they fail. Cracked rails lead to derailments.
Vertical, like the pole barn is OK. Building will flex well in a wind storm.
Ron
/ Building with railroad rails #6
I don`t know about bridges out of rail, but I made an anvil out of a bit about a foot long, and its handy for little jobs.
/ Building with railroad rails #7
I toured a mill nearby that produces rail. They ship in 1,400 foot lengths!
/ Building with railroad rails #8
There's a big difference in the flexibility of the same rail, comparing it at 4:30 and at 6:30. At least it appears there is.
/ Building with railroad rails #9
I've read a couple of times that rails are never sold. If this is true, there are an awful lot of ameture blacksmiths pounding on stolen rails.
/ Building with railroad rails #10
The building I work in has overhead cranes and they run on the same rail. A few bits leftover were quickly swept up by the blacksmiths!
/ Building with railroad rails #11
My grandfather worked for the railroad, I inherited his rail anvil.
/ Building with railroad rails #12
I thought Sherman's Neckties during the civil war was interesting/ Not very stiff.
/ Building with railroad rails #14
I had an uncle that would take a piece of railroad rail and use it as the body of a weiner dog. Then he'd weld an upside down hook on one end for the head. Then 4 upside down railroad spikes for the legs. The heads of the spikes were the feet on the legs. Then he'd weld another spike to the other end for the tail, this time with the head of the spike down on the body. They were really cute and he sold them as doorstops. I never did figure out his supply for rail, spikes, hooks, etc... but seemed he had a bunch of them. This was back in the 60s and 70s. Wish I had one. If I ever get a chunk of rail, I'll make one just for sentimentality. :)
/ Building with railroad rails #15
This is how they transport 50 of these long pieces of rail. Just think how much pressure it takes to bend them all around the curves.
/ Building with railroad rails #16
Was that the place off of 30 over towards FW? Looks very interesting.
Yep, that's the place. We get our steel (for work) from there. It is rather impressive, and I'm glad I don't have to pay their electric bill!
/ Building with railroad rails #17
Just a point of interest.
When scrapping out rail you can save a lot of time by just cutting the bottom flange, let the rail cool down then smack it with a hammer. I have seen 20' length of rails broken up this way with one smack of a sledge hammer.
Back to your regular programming.
/ Building with railroad rails #18
i found a 18" piece of old rail metal detecting in an area where they logged cedars back about 100 years ago. it was about 2' under the ground. It was probably used by their blacksmith at the time. now its in my shop.
