A good hydraulic shop should be able to either be able to make new rods to go into your cylinder or be able to get you pricing on complete new ones.
This is about the third thread in the last week or so about this happening and not one of the posters has explained how it happened. Doesn't seem possible for this to happen so often.
or expecting too much of an undersized machine.
i see a lot of forum members complaining that their compact tractors are unable or damaged to do the job at hand. unrealistic expectations
& then they wish they had gone bigger.
best of luck to the OP. there's a lot of good advice on the forum
Back dragging with bucket curl cyls fully extended. The bucket grabs the dirt like a fishhook........VIOLA......bent rods
Happens all the time, most control valves do not have work port reliefs to retract them when snagging the ground.
Bent cylinder rods are not a "must replace" situation. If they are carefully bent back close to straight (using padded blocks, straight-edge, etc) the glands/seals usually have enough clearance to operate without binding. Looking at the straightened rod while using the tractor makes a continuing reminder to avoid whatever bent it.
If the rod is scratched, smooth off any high spots and fill the groove with super glue. I've done that on a friend's outrigger cylinder - stopped the leak.
