Hydro whine
/ Hydro whine #1
Texasmark
Elite Member
N. Texas
Ford: '88 3910 Series II, '80 3600, '65 3000; '07 6530C Branson with FEL, 2020 LS MT225S. Case-IH 395 and 895 with cab. All Diesels
In purchasing my 6530 with geared transmission but shuttle shifter, I had no detectible whine, nor did I have whine in my steering pump. As time passed I started getting annoying whine and blamed my THD Premium fluid..
As posted herein, I accidentally stumbled across a rubber hose connecting the pipe from the main sump to the common shaft main and steering pump inputs which had deteriorated and was letting air into the pump on the suction side.
Well, after installing a new hose ($22) and running it for awhile, getting all the air bubbles out, the whines are gone.
I thank the guys on here that said the pump was sucking air answering my posting of the problem.
So, as a thank you and a heads up for you folks with annoying hydro whine, maybe your pump(s) are sucking a little air. I should have done something about it when I saw it. The engine is dusty but has no oil leaks.....other than the last time I had the side panels off and noticed some oily residue around the bottom of the pumps (both were sucking air...same hose, one inlet 2 outlets)......which (recollecting) had never been there before. I should have investigated and you might think about that for your equipment.
/ Hydro whine #2
Thx for the follow-up! It’s nice to get an outcome- keeps TBN alive and well! But the best part- an all positive post- no whining!
/ Hydro whine
Thank you. I agree on closure. It helps responders "stay in the game".....and the site is probably full of "grouchy old men"....like me at 78. Grin
/ Hydro whine #4
No I am a SOB. Surly Old Buzzard :)
/ Hydro whine
2017 International HX620 Quint Dump (A62613)
2017 International...
Chevrolet 2500 Flat bed (A63118)
Chevrolet 2500...
UNUSED WOLVERINE R-31-G1.5T 1R RIPPER (A62131)
UNUSED WOLVERINE...
2016 John Deere HPX Gator 4x4 Gas Utility Cart (A61567)
2016 John Deere...
2018 CATERPILLAR TL1055D TELESCOPIC FORKLIFT (A62129)
2018 CATERPILLAR...
UNUSED SDLANCH DIAMOND PLATED PLASTIC MATS (A62131)
UNUSED SDLANCH...
