13 year old tires, time to replace?
/ 13 year old tires, time to replace? #41
99.999999999999999999999999% of men will die with no chance of being resurrected
/ 13 year old tires, time to replace? #42
Never, ever heard a peep about tractor tire age and liability in the same sentence. I think you are fear mongering.
Fear mongering? Call your insurance guy. Ask him ....if you fail to replace a known tire that is beyond reliable service and you or someone else get hurt will they gladly cover you for it?
Im not saying you shouldnt run old (AG) tires that are cracked, worn out etc. thats your call, your choice. It really only affects you or your family. not me.
/ 13 year old tires, time to replace? #43
If I called my farm policy agent with that question he would likely hurt himself as he fell out of his chair while laughing.
/ 13 year old tires, time to replace? #44
Do you actually know this or are you extrapolating information from highway use to off-road applications?
I am pretty sure I know the answer.
How old are the tracks on your mini-ex?
/ 13 year old tires, time to replace? #45
Hey, all rubber products on a truck or tractor have date codes on them.
OK, as individuals we generally get by but as our municipal garage director told me they replace vehicles mainly due to date coding.
Being gov't vehicles the annual inspections are much more closely monitored for all those codes.
Think as to how labor intensive replacing ALL rubber would be.
Hoses, brake lines, shock mounts, bladders etc on and on.
And unionized workers don't come cheap.
Heck our municipal garage has huge lifts in every bay and nobody will heft more than a 20 kilo item, much less do a tire change.
/ 13 year old tires, time to replace? #46
Yea....... but that is in Canada, the North American country of maximum regulations, where even a gas discharge permit is required for farting.
/ 13 year old tires, time to replace? #47
Not sure of the question but I do know if you fail to maintain any equipment in a safe manner and cause harm because of it Its on you not the insurance company.
You do know excavator tracks are different? In answer to this they are 1 year 4 months old.
/ 13 year old tires, time to replace? #49
^^^^^^^Absolutely agree!
/ 13 year old tires, time to replace? #50
Really?
Excavator tracks are different?
Why?
/ 13 year old tires, time to replace? #51
:stirthepot::stirthepot::stirthepot::stirthepot:
Just trying to see what kind of a response I would get.
Now I’ve got to go order tires.
COSTCO often has good tire pricing.
/ 13 year old tires, time to replace? #52
I guess all the hyd. hoses on my trencher need replaced. They are well over 20 years use. So I need to replace the seat also? What about a 1965 Case 730? If a tires gives up while haying will I scare a neighbor, or frighten a cow?
I better check with my ins. agent. Sounds like ALL my equipment will need to be scrapped. Sure don't want to sell it at an auction and be liable for something!
/ 13 year old tires, time to replace? #54
The thing about a hydro hose is, that of it pops a leak on a high pressure side, and a person is in the wrong place, injury could happen from being sprayed.
Probably about as likely as having a blow out on a high speed excavator track tho.....
:laughing:
/ 13 year old tires, time to replace? #56
/ 13 year old tires, time to replace? #57
I have a JD Model N manure spreader, '60s origin best I can tell, with the original tires still intact, still holding air such that I don't have to air them back up to use it annually, weather cracked like you never saw a tire weather cracked. Totally amazing, but they are not overworked either by the weight they have to carry, or the friction they have to produce to roll the scraper bars along the bottom of the unit.
/ 13 year old tires, time to replace? #60
Might put some good tire sealant in them and run them until they pop.
2015 MACK CXU613 SLEEPER (INOPERABLE) (A63569)
2015 MACK CXU613...
JLG Scissor Lift (A64047)
JLG Scissor Lift...
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A60460)
2018 Freightliner...
2008 Case IH 2152 Combine Header (A63688)
2008 Case IH 2152...
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59911)
2016 FREIGHTLINER...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
