Grapple + Piranha
/ Grapple + Piranha #1
trentk
Cleburne, Texas
Zetor 4321
Has anyone built a brush grapple with the intention of fitting their Piranha tooth bar on it? Not the moveable jaw but the bottom. I'm going to try it. I have lots or briar and small brush to clear and I think it will work good. The Piranha bar works well for this with it on the bucket but without the grapple ability it just makes a mess. I don't think just adding a grapple to my bucket would help much as it's a full bucket and not the skid steer type of bucket. I don't think I need any kind of root rake or digging with this. The bar on the bucket as is takes down brush 1-1/2 diameter easily.
My tractor is a ZETOR 4321 59hp
I intend to build something similar to this but along the front of the bottom tines will be a plate that the Piranha bar mounts on.
I was just wondering if anyone had done something similar.
All comments positive or negative are welcome.
/ Grapple + Piranha #3
The MTL design is shaped similar to the Piranah. Just need to take a grinder or plasma cutter and sharpen the teeth.
/ Grapple + Piranha
Thank you. I had not seen that grapple. That is the design I had in mind. The one I am building will have a beveled plate on the front for the piranha to mount on.
/ Grapple + Piranha #5
That's really not the right type of grapple for brush. You need a clamshell type grapple for that. But, I understand trying to make what you have work. I use my landpride sgc 1072 effectively for brush, but it wouldn't move a bunch of firewood like your grapple could.
/ Grapple + Piranha #6
I have had my eye on this grapple/clam bucket for a while and did not even think about putting my Piranha bar on it now I am even more interested in it thanks to reading this thread, thanks.
/ Grapple + Piranha
I think it would work very good for thick small brush. If you go with that let us know how it works out.
/ Grapple + Piranha #8
In March I will get more serious about this unit, it is made in Mn and within a hour and a half drive from my home and only 800.00 so more then likely I will drive there if I decide it is the way I want to go but looking at it having a Piranha bar on it I can see a lot of promise with it from removing thicket to hauling wood, gravel and dirt to a certain limit. I just need to see what valve system I want to go with on my 1705.
/ Grapple + Piranha
I decided to move forward with the project. I hope it will work as well as I think it will.
/ Grapple + Piranha #12
Any finished pictures? How does it work?
Altec Digger Derrick Hydraulic Boom (A61572)
Altec Digger...
(4) METAL DRUMS (A63291)
(4) METAL DRUMS...
Skid steer Asphalt attachment (A61567)
Skid steer Asphalt...
26 ft trailer 20 ft bed (A61567)
26 ft trailer 20...
Brown 826 (A64119)
Brown 826 (A64119)
2025 IREV Electric Scooter (A64194)
2025 IREV Electric...
