BX2380 tipping concerns
/ BX2380 tipping concerns #1
Andrew2019
Ontario, Canada
Kubota BX2380
Hi guys,
Newbie tractor owner here.
Bringing wood I noticed the tractor seemed to sway a bit. I'm super careful even on the mildest of slopes.
I keep the bucket almost dragging on the ground until I have to lift it and even then only on flat ground, etc.
I found that I could get off my BX and actually almost tip it by hand (by pushing on the roll bar)with the bucket as it was in the pictures
and when the bucket is empty and 6 inches from the ground (although that was harder)
Is this normal? I have sandbags for the ballast box (I didn't have them in the box today)
Would that help or make it tip easier because of extra weight?
Andrew
/ BX2380 tipping concerns #2
Check your tire pressure. This sounds like it is too tippy. I don;t know much about Kubota suspension, but a quick look see to make sure nothing is missing/broken ?
/ BX2380 tipping concerns #3
Add some rear wheel spacers...it’ll definitely help! These tractors are top heavy...have to make the stance a bit wider...
Pretty sure nothing's broken. I've barely used it and just did my 50 hour service.
Front tires are supposed to be 22 lbs and the backs are 20 I believe.
I'll check the manual and check the tires when I get home from work.
Drew
Hi troopr31
I've never heard of a rear wheel spacer.
That sounds like a thing the dealer would have to install?
Is there a link online?
Drew
/ BX2380 tipping concerns #6
I have a B2601...With 2.5” BORA spacers on the rear...
These guys are big players in the BX market. They explain them on the site.
Bro-Tek
If you use a mid-mount mower you can only get a certain width before it contacts the anti-scalp wheels on the rear of your deck...the wider you go, the more stability you get...
/ BX2380 tipping concerns #7
I've had some close calls with my BX. Best thing to do is keep the load as low to the ground as possible. This way if the tractor wants to flip, the bottom of the bucket will help stop it as it hits the ground.
If it feels like it's going to flip, just drop the bucket as fast as you can; make it like an extension of your hand - a reflexive move. It's saved me a lot of those times.
Make sure you wear your seatbelt too, as annoying as it is, it's there for a reason.
Though, the easiest way to prevent any of this is realize that it's a BX and not a big machine. Loading is key.
Just saw a video.
Actually doesn't look too hard to install.
Will two inches make a big difference?
/ BX2380 tipping concerns #9
Andrew....load up that rear ballast box with some weight. Your front axle does nothing to keep you from tipping because it pivots at one point in the center. Your rear axle doesn't pivot so that is the one that keeps you stable but it needs weight to plant it to the ground. Are your rear tires fluid filled? If not, start with 300+ lbs in the box and work up from there.
Hi ruffdog,
My rear tires are air filled.
I'll put the sand in the box tonight and see how that feels.
Andrew
/ BX2380 tipping concerns #11
My BX2360's LA243 loader manual recommends 420lbs maximum on the back when using the loader. I found it makes a big difference. With no implement on the back, and something in the loader, it feels like a gust of wind will blow it over. Even a 250lb implement really helps.
Bruce
/ BX2380 tipping concerns #12
Certainly agree with filling your rear tires with ballast. I have rim guard (beet juice) in mine. Dealership I bought mine off of doesn’t sell a loader on a tractor without some type of ballast in the tires...
Adding ballast to your box, filling your rear tires with ballast and 2” spacers will make a very large difference in handling...
As far as “suspension”...these tractors don’t have a suspension system...the only “suspension” is the springs on your seat...
/ BX2380 tipping concerns #13
Had a 2370 for several years - loaded rears - it wasn't to difficult get it to feel tipsy - but for it's size it was nice unit - I always kept the bucket down as low as possible - watched the banks and how I approched - at 265 I would shift my weight on the high side a few times cutting the grass to keep it stable on the banks - but it never failed me and never tipped over - It moved tons of top soil, loaded my pick up with yard waste many times - kept the lawn in order - did it's job - but I learned it's limitations and did not push beyond them - but like others have suggested I would defiantly load the rears - makes a world of difference.....
/ BX2380 tipping concerns #14
Rear wheel ballast and rear wheel extensions made a huge difference on stability. Always have 3pt weight for loader work.
/ BX2380 tipping concerns #16
Doesn't matter if it's a BX or another tractor. If you have a front loader installed you should have fluid in your rear tires. If you are carrying a load in the bucket then you should have additional ballast on the 3-pt hitch.
The setup you have now with no tire ballast and no rear ballast is asking for all kinds of trouble.
After reading all this I'm shocked I haven't tipped it thus far! I didn't even get a casual warning I should have ballast in the back if I use the loader from the dealer when I bought it.
I didn't have the loader on much during the summer, I mainly used for mowing. I have the 60" deck and I thought it felt pretty safe. I was whipping around pretty good in fact.
Is it mainly with the loader that you definitely need the ballast?
As I said I have a bunch of sandbags but if that doesn't get me to 300lbs I have tons of bricks on the property to fill the box.
I've never heard of tire ballast. Is it a liquid you leave in year round?
Andrew
/ BX2380 tipping concerns #18
Another reason you need sufficient ballast is your steering cylinder gets overworked from excess weight on the front axle and prematurely fails. Ask me how I know that. I came extremely close to tipping my bx and would have if a heavyweight friend saw the disaster in progress and jumped on the back fender as the rear wheel started coming up.
/ BX2380 tipping concerns #19
Andrew,
To me it sounds like your tippy feeling is very different than my experience. Yes, I have my rear tires filled with fluid. You can youtube it and do it yourself or have your dealer do it which is what I've always asked for at time of purchase. It makes a huge difference even when mowing side-hills. And also, I did recently have my tires air pressure down in the rear (due to the colder whether) and that also made a huge difference. I use a box blade on the back when doing any loader work and you'll be amazed with loaded tires and rear ballast how much more work your loader will do and how much more stable it is.
That said, I'd never raise the loader much on side hills and travel with it as low as possible, but I do a lot of loader work and if on fairly flat ground, I've never had an issue running around quickly with loads. If on a hill, yes, I take it very slow and always have my hand on the joystick ready to drop the bucket to the ground to prevent roll over.
This is my 3rd tractor and the BX's feel much more stable to me than the L's. When mowing, I side hill stuff I never would have considered with my old JD lawn tractor. I just slow down some where appropriate. You'll get the feel of it, but I definitely would get your rear wheels filled asap.
Hi David,
I did check my tire pressure a week on the weekend but the temperature here dropped considerably since then so that's on my list today.
The manual says 14 psi for rear turf tires (the ones I have) but I believe my pressure on the tires themselves are 22 in the front and 20 in the back.
14 seems odd. I may be reading the manual wrong but I always default to what the actual tire says.
Andrew
2005 MACK CV713 MIXER TRUCK (A65643)
2005 MACK CV713...
2012 HINO 268 4X2 S/A BOX TRUCK (A59914)
2012 HINO 268 4X2...
1974 Transtar 4300 Roll Back Truck (A65563)
1974 Transtar 4300...
(3) Wheels and Tires for 4-Wheeler (A65579)
(3) Wheels and...
Multipurpose Skid Steer Mount Backing Plate  (A62679)
Multipurpose Skid...
2005 Chevrolet Silverado 3500 4x4 Crew Cab Pickup Truck (A64194)
2005 Chevrolet...
