WHICH ROOT RAKE/GRAPPLE ?
/ WHICH ROOT RAKE/GRAPPLE ? #41
Great!
Thank you.
That would seem to mean if I used a 785 lb. grapple that I would have a potential lift capacity of 1615 lbs.
I will have to think some more about that.
I very much like the idea of lighter, but of course, I like the idea of stronger too.
I would really like 1/2" steel on the end teeth. If the others are only 3/8" that would be OK.
There do not seem to be many manufacturers of 66" full width lid grapples that have open bottom teeth.
I would really like to have some others to compare.
I would not recommend purchasing a piece of equipment that has friction joints with no grease fittings. If you arent lifting rocks, then the only thing left is wood. How high do you plan on lifting wood? Your capacity a few inches off the ground is probably close to 4000 lbs. How high do you need to carry stuff around?
/ WHICH ROOT RAKE/GRAPPLE ? #42
Your Land Pride certainly does look like a very nice grapple.
The problem for me though would be the tooth design.
I need the longest teeth possible, and spaced much wider than those appear to be.
I need to reach into trees/bushes to hook/snag the bittersweet vines, yet keep the actual damage to the trees/bushes to a minimum.
I am thinking longest possible teeth, with tooth spacing at 11" or slightly more.
Any more closely spaced teeth will likely pull/break off branches of the trees/bushes themselves.
It would be nearly impossible for me to grab the bittersweet at ground level, but I can grab it much higher on the tree/bush, where it is actually weaving it's choking vines up through the tree/bush.
If I can snag the vines, curl up or down, and pull up, some will break off, but when the ground is moist, most vines will cleanly rip out.
Getting rid of bittersweet (like kudzu) is a reoccurring problem.
It will eventually grow back, and need to be ripped out again.
The $3400, 141hp tested, 660 pound Wicked 66" root rake grapple you refer to... Best Rated 66 Inch Wicked Root Rake Grapple from Everything Attachments.. is a nasty, beastly, bad to the bone chunk of most premium materials money can buy. If someone with an L48 planned to be rough and desires bomb proof, then I couldn't argue, but I'd also tell you to take a serious look at the 60".. Best Rated 60 Inch Wicked Root Rake Grapple from Everything Attachments .. , which is 400 pounds and also features similar materials, only a bit thinner and scaled down.
Longer teeth with wider spacing? Sounds like you're describing the EA Xtreme Root Rake Grapple.. Tractor Loader Root Rake Grapple by Everything Attachments I'm on vacation this week, so my posting skills on my phone aren't great, but I feel like our offerings needed to be clarified. Also, I hear we'll be offering a 5% off Cyber Monday discount. Travis . Screenshot_2019-11-28-12-44-29.png
I wish.
Your EA root rake has tubular horizontal cross members welded between teeth, both top and bottom.
Nice looking rake, but to best snag the bittersweet vines I feel they need to be able slide all the way in to the very rear of both the top and bottom teeth.
The tubular cross members would prevent the vines from getting to get the rear of both the top and bottom teeth.
I bought this one a couple of years ago. I haven't had any problems moving brush and logs. I was able to pick it up at the factory where it was made. The price was better than most I've seen.
Tomahawk Attachments :: Tomahawk 66" Two Cylinder Brush Grapple
The cross tubes welded between the teeth make this grapple design unacceptable for me.
I need the vines to be able to slide firmly against the very back of the bottom grapple teeth for my use.
I want a single lid, and want relatively high placed cross tubes at the lid teeth also.
I may have found something that will work for me from an attachment mfg. in NC., though I will need to ask if they can add zerk fittings, or modify it myself.
/ WHICH ROOT RAKE/GRAPPLE ? #46
you might be able to latch on to some of them, but pulling them out without cutting them off at the bottom first
I think will be your challenge. I know you want the roots out, but like
the old lady asking "where's the beef?",
I'd ask where's your grip?
/ WHICH ROOT RAKE/GRAPPLE ? #47
I don’t think my Favor is going to let go of much that a single lid would have caught. It covers the teeth pretty good and the lids overlap. IMG_7872.JPGIMG_7873.JPG
/ WHICH ROOT RAKE/GRAPPLE ? #48
Yes I was thinking this also. You could also just use forks if you just care about the vines sliding all the way down. However, no grip.
There actually will be no real "grip".
It will be just a case of snagging enough of the twisted vines to get them caught tightly enough in the grapple tines to be able to pull.
Some of the vines will actually rip out from the roots, some of the vines will break off at or above the roots, and some will slip through.
So be it!
Better than nothing....I think.
I have never mastered the TBN picture thing, but if interested, here is what I am thinking might work for me.
E-Bay # 193184262157
The pivot wear points do not have zerks, and with A36 steel, that is an issue that must be resolved.
/ WHICH ROOT RAKE/GRAPPLE ? #51
I had a Titan grapple before on my L3240. The whole thing was junk but the pivot were just bolts on a plasma or laser cut hole with no grease fittings. I used that grapple a bunch and wear wasn’t an issue. You said in another post your tractor use was 10-15 hours a year and you’re nearly 80 years old. I put nearly 800 hours on my L3240. Of course not all of it was grapple use but a lot was. I don’t think wear is going to be an issue in your case.
Thanks for that perspective.
You are probable right!
79+ years of wear on ME is most likely the MAJOR issue here.
/ WHICH ROOT RAKE/GRAPPLE ? #54
So I looked up your eBay grapple and the 2 problems biggest problems I see way ahead of pivot points is the hose routing sucks and there’s nothing to keep the lid from racking sideways. My Titian suffered from the same failure. I bent both lids and tore one cylinder mount off. That piece of crap is the reason I tripled my budget the next go around. If the first thing you did was weld a brace like this it would be better off. IMG_7877.JPGIMG_7874.JPG
So I looked up your eBay grapple and the 2 problems biggest problems I see way ahead of pivot points is the hose routing sucks and there’s nothing to keep the lid from racking sideways. My Titian suffered from the same failure. I bent both lids and tore one cylinder mount off. That piece of crap is the reason I tripled my budget the next go around. If the first thing you did was weld a brace like this it would be better off. View attachment 630731View attachment 630733
Good info!
Thank you.
Those angle braces make complete sense.
If I buy that thing I will definitely do the angle braces before using.
I hadn't noticed the hose routing, but that does look to be an issue also.
For fun, I just might take a trip up to Denton, NC. to see how it is made, and if they will build to my requirements.
/ WHICH ROOT RAKE/GRAPPLE ? #56
As far as ripping out brush with a grapple, it all depends on the roots, strength of the vines and the quantity of the vines. Our Himalayan blackberry is nasty but has physically weak roots (other than they grow back like you would not believe). I have another type of Bush (do not know what it is) that I have to drive as fast as I can into the thicket with my grapple just above the ground and break as much off before I come to a stop. 10,000 lb machine. There is no way I can uproot it with my 2500 lbs of lift, just too many strong vines rooted well. After breaking it off I mow every year and am trying to outlast it.
Bittersweet vines are quite resistant to breaking, and have long close to the surface roots.
I do think I can pull them, but obviously, some will break off, and some will slip through.
I am reasonably certain that my 2450 lbs. of lift can pull a group of a few vines with each bite.
The Buckthorn Puller would do the job for sure, but at one thin vine per pull it would take forever.
It would be difficult with the holly too, as their branches restrict viewing under the trees.
There seems to be no lasting way to eliminate all bittersweet, short of spraying, which would then kill the host trees.
Even after spraying, bittersweet sometimes makes a successful comeback.
Horrible stuff!!
/ WHICH ROOT RAKE/GRAPPLE ? #58
I use glyphosate, it will not harm the larger trees as long as you don't spray the foliage.
And .....how would I not spray the foliage on full skirt English holly trees?
/ WHICH ROOT RAKE/GRAPPLE ? #60
Lonestar Panel (4) 24ft. Free Standing Panels (A65640)
Lonestar Panel (4)...
Ripper Tooth Excavator Attachment (A61567)
Ripper Tooth...
Kivel Skid Steer Forks (A65640)
Kivel Skid Steer...
NEW Wolverine 84" Skid Steer Bucket, 38" Depth (A62679)
NEW Wolverine 84"...
ATS 40 Gallon 2 Stage Air Compressor (A62679)
ATS 40 Gallon 2...
2008 SUBARU LEGACY 4 DOOR SEDAN (A65054)
2008 SUBARU LEGACY...
