Good morning!!!!
   / Good morning!!!! #102,581
Drew ... if I can do a task with tractor hydraulics ... that's my preference over another gasoline engine to maintain.
Yep about 90% of our trees are oaks. We have a few hundred cedars but, I'm slowly getting rid of them.
I considered getting a 3 point splitter, but with only one tractor, and using the 3pt lift to carry rounds and the FEL with bucket or grapple to carry more rounds or logs, decided to go with the gas engine model.
Thanks for the moth ball tip. I had forgotten. I'll buy some.
   / Good morning!!!! #102,582
Good morning 30's and rain today.
Not much planed today with the weather other than mopping floors after every trip outside with the dogs they always seem to find the mud.
WNG I can sympathize with you and skunk problems although this has been a skunk free year (knock on wood) I had problems in the past. When I went through K9 training we were told the best way to clean and de oder the dog was with Massengill Douche, Honestly I didn't know a dog handler who didn't have a case of it in the trunk of the police vehicle and from personal experiance it works. But I have found white vinegar and water work just as well only doesn't smell as good lol. Just need to be careful around the dogs eyes.
   / Good morning!!!! #102,583
I need to hook up the 3-point log splitter and prep some wood for our outdoor fire pits. I ordered a replacement 24" x 1/2" hydraulic hose that goes between the control valve and cylinder and will get that installed as well. I built a stand for it so, all I need to do is get one of the tractors close enough to hook up hoses to tractor remotes.
RNG ... maybe you can see light, at the end of the tunnel, on your van? What's the old saying? I see light, at the end of the tunnel ... hope it's not a train!
So far, Rick, most of what I've been doing has involved replacing old, worn out, parts, or fixing bad workmanship or defective parts installed by the ex-mechanic. If there's a light at the end of the tunnel, it is that most of what's left involves new parts that I'll purchase and install myself. I'm not saying there won't be problems, but they'll be my problems, not dragon eggs left behind by someone more careless than me.
Speaking of the ex, I still haven't gotten an itemized statement of what he thinks I owe him. I've been asking one for over a year, and I have no expectation I'll ever see one.:confused2: But I have been putting together a detailed list of the problems he created, and it seems it gets longer the more I drive the van, and the more I look into what was done.
That looks like a good solid splitter stand, too. But one of the things I'm very happy with on the Airens is the height of the beam. I don't have to bend over at all when I'm splitting in the horizontal position, except when I stack the splits on a pallet. Makes for a lot less back pain, though that's usually the reason I only run through one or two tanks in a session.:2cents:
   / Good morning!!!! #102,584
Good Morning!!!! 51F @ 7:45AM. Partly cloudy skies. High 67F. Winds light and variable.
I'll add looking you up in the Daytona pits to the things-to-do-and-see list on that eastern trip, Rich. I think that would be a blast!
Bodyman neighbor came over yesterday with the biggest tire I've ever seen off a pickup truck, his son's 4WD Tacoma. It was part of a set of four he'd purchased, and the tire's sidewalls were split in several places. He needed to get it off to hammer out a dent in the rim, and replace the tire. Well the thing was so wide it barely fit in my tire changing machine, but between the two of us we managed to make do. One bead busted off easily, but we had to go all the way around the other side until we found a spot that would let go. As we were finishing up, the fella with the gravel was rumbling down the driveway, so the timing was perfect. Spent the rest of the day replacing the wooden shims under the shipping container with aluminum ones, then building ramps on each end from the 3/4 minus road base. Used the tractor and a tamper to pack it down, and it seems very solid now, but I have to wonder if the ramps'll stay that way when they're saturated with water. Guess I'll find out over the next week or so, we're expected to pick up a couple of inches of rain.
More seat time today, with some grading and then spreading out the new decomposed granite, which looks like coarse golden sand. It'll be nice to get the charcoal covered up, and the scraggly areas that I tried to turn into lawns.
Hope everyone enjoys the rest of their weekend!
   / Good morning!!!! #102,585
I’m still experimenting with final height of the stand for comfortable loading of rounds, I’ll then build a real stand of steel that I can firmly attach the splitter to and be able to move it with pallet forks as well. I think I’ll put it on the 3-point hitch, one more time to determine most comfortable working height.
Edit: what ever I build for a steel stand... I want to retain the ability to swing the splitter vertical as well.
   / Good morning!!!! #102,586
68°F and 1.54 inches rain. And raining.
Today I start my 73rd trip around the big heat tab in the sky.
No big plans today. Watch some football, hand & Foot later.
Prayers for all
Be safe
Have a great day
   / Good morning!!!! #102,587
Today's low temperature was 28ºF @ midnight. The snow started in the wee hours (~2AM), by 4:00AM the temp was 30ºF and there was 1.25" of accumulated snow as the sleet started to mix in briefly before the precipitation activity started to slow down. The mixed precipitation has since picked up slightly. Temperature = 34ºF presently; probably close to today's high temp. A hot coffee and a fired wood stove kind of morning, Another nap in my easychair by the wood stove listening to more football blather kind of afternoon.
Bruce- Thanks for sharing. I am happy that you had a good ride and time with fellow cyclists. I could spend a long time sampling those 100 taps.;)
BEF- I do not like instant replay at the college level.
" Jay, football, UM of meets OS next weekend. Lots of rivalry."- RonJH That should be a great game. I am glad that PSU beat the point spreads yesterday. With a 27 wins against 2 losses by history PSU should beat Rutgers next week, but Rutgers can give PSU trouble.
Billy- Good luck with the skunk
"... Instant Pot country ribs for dinner tonight? Rick That's a nice looking wood splitter and stand. Your planned dinner reads to be great eats. :cool: Tonight I am making Cajun smothered steak. This is a meal for people who love black pepper and really warms one up which is nice this time of year.
"... mopping floors after every trip outside with the dogs they always seem to find the mud."- DABSGT Mopping floors is almost a daily task around here.
RNG- I hope you have a good day on the tractor and you continue to see precipitation.
David- Happy birthday. I wish you many more trips around the sun in health and happiness.
I hope that everyone has the Sunday that they anticipated.
My + thoughts and prayers
   / Good morning!!!! #102,589
J and all up north in the weather, stay warm! Expected to hit 68F today and maybe 80F tomorrow here. The fireants are coming out to join the party.
BEF- sorry your HS team lost. Our team is playing a team loaded with talent this week, so it will be an uphill miracle if they win.
Happy Birthday David! Glad to hear the task load is low now.
Cowboys vs Patriots....pretty sure the Pats will win, but would like to see a change from the norm.
City is having citywide Thanksgiving service at our church tonight. Good chance to fellowship with members from other congregations.
   / Good morning!!!! #102,590
Happy trip around the sun day!!!
2014 FORD F-250 UTILITY TRUCK (A58214)
2014 FORD F-250...
Atlas Copco XAS90JD Portable Air Compressor (A57453)
Atlas Copco...
TPM RM900SB All Terrain Remote Controlled Weed and Brush Mower (New/Unused) (A59225)
TPM RM900SB All...
2000 FREIGHTLINER CLASSIC (A58214)
2000 FREIGHTLINER...
2015 Ford Focus Sedan (A56859)
2015 Ford Focus...
LOT: Steel Work Table 36" x 72" w/8" Craftsman Grinder, (2) Lockers (VISE NOT INCLUDED) (A59076)
LOT: Steel Work...
