Tires Kubota l6060
/ Kubota l6060 #1
johnabs
2005 L3400
Looking for front wheel spacers, any ideas where in western Canada to purchase
Thanks
/ Kubota l6060 #2
Why front spacers? Due to the pivot on the front axle extra width adds very little stability. I dont remember how close offhand, but that might out you close to hitting the loader when it's down & you are turning.
/ Kubota l6060 #3
Thanks
I know nothing about front wheel spacers for the L6060, but you can move the wheels/tires to the opposite side to add width.
Of course, doing so will likely cause interference between the tires and FEL brackets if so installed unless you readjust the steering stops, which will increase turning radius.
SDT
/ Kubota l6060 #4
Thanks
Also if you install after market and something happens to anything related to the new parts it will not be warrantied. Personally I would not mess with the front axle in this way, especially as it bears a great deal of the weight from a loaded FEL.
/ Kubota l6060 #5
Thanks
/ Kubota l6060 #6
Does Kubota even recommend spacing the front wheels out? As has been mentioned spacing the wheels out increases the likelihood of breakage at the front axle due to the added leverage working against it. You may wish to rethink WHY you want to space the front wheels out in the first place.
/ Kubota l6060 #7
My old M5030DT front wheels could be interval spaced out for crop work like the back wheels. The manual giving spacing dimensions. Canadian built 530 loader was very strong. I spaced the fronts out some to help hill side loader work. Yes I understand the front axle pivot but on rough ground wider is better. Did decrease turning radius. Does increase stress to the front axle. In the 80’s that tractor was made seriously heavy and made to take it. With a no-spin front diff that tractor could pull!
/ Kubota l6060 #9
Yes but that is a M series utility tractor. The L series is a compact tractor. It is pretty beefy, but not quite as beefy as the M series. It is not designed to be a field work machine, but I am sure it will do fine if you need it there.
Do what you want it is your machine!
/ Kubota l6060
Ok thanks for the tip
/ Kubota l6060
Why front spacer cause where I live there lots of hills , thinking it’s dangerous to work the tractor in areas where I’m haying fields and feeling like I will flip. On my L3400( which I sold) I just switched front tires like the rear tires, they were wider and worked fine.
I did widen the rear tires on L6060, ( bought this tractor month ago, nice machine) feel more stable, but still feel unsafe on hills.
/ Kubota l6060 #12
I don't know about your L6060 but my M6040 Op Manual says - "no spacers, either front or rear". But then, I should never need spacers. I adjust both front and rear wheels to six different widths using the rim and center of the tire. All being done to accommodate row crop farming or increased stability.
2001 Sea Breeze RV (A62613)
2001 Sea Breeze RV...
UNUSED WOLVERINE 3PT QUICK HITCH (A64281)
UNUSED WOLVERINE...
2015 Ford Explorer SUV (A61574)
2015 Ford Explorer...
2016 Ford Fusion Sedan (A61574)
2016 Ford Fusion...
2017 GMC Sierra 2500 HD 4x4 Crew Cab Pickup Truck (A61573)
2017 GMC Sierra...
2005 Ford F-150 Ext Cab Pickup Truck (A61573)
2005 Ford F-150...
