Think about upgrading tractors but.......
   / Think about upgrading tractors but....... #11
That is a nice looking 2410 you have, thumbs up.
Thank you Jim.
What cab is that? Sims? Curtis? How do you like it?
It's a "Sims Cab Depot" cab, model is a "Indy Cab", It has two soft removable panels below the front windshield on both sides, and a soft removable clear panel at the rear (hard fixed panel would be in the way for using the backhoe). I really like it and in the summer I have just started removing the door for easier access.
I do believe Curtis still makes a cab for the MF GC2410 and since I have purchased my Sim's cab over 10 years ago, maybe there might be others that make a hard sided cab for the MF.
Here's a pic of what I usually will have installed on the MF in the summer.
KC
Thanks guys-I am looking at using the 3ph instead buying another machine. Cost and maintenance and parking are an issue.
   / Think about upgrading tractors but....... #13
Thank you Jim.
KC
I have a GC1710TLB. The only hard factory looking cabs I've found are the Sims and the Curtis even today. I would really love to have one in the winter but it's hard to justify the cost as The appear to be around $6k. I've often thought of buying a nice canopy and making my own modular cab system.
   / Think about upgrading tractors but....... #14
I don't know what the 3 point lift capacity is of your tractor.
But,I knew I had seen something to increase the lifting range of the 3 points and I found it again.
Titan calls it a 3PT scissor lift, I don't know if this would give you the lift needed or if your tractor could handle a ton with this much rear mount.
3PT Scissor Lift
   / Think about upgrading tractors but....... #15
Yes that is a lot for a cab, but if you got the soft sided rear panel (only style available in 2009) like I have you'd save $750 (2009, I paid $3995 which included a pair of work lights kit, a hot water heater kit, a pair of outside side mirrors kit, and installation).
And back in 2009, I thought it was a lot of money also, and I think if you did a search you might find different D.I.Y. cab builds.
Good Luck, KC
   / Think about upgrading tractors but....... #16
This is the one I have been looking at.
   / Think about upgrading tractors but....... #18
3PT Scissor Lift
That is a neat attachment. Thanks for posting the link.
Craftsman YTS 3000 42in. Riding Mower (A49346)
Craftsman YTS 3000...
2011 International WorkStar 7400 Chassis Truck, VIN # 1HTWGAAR6BJ325793 (A51572)
2011 International...
2024 CATERPILLAR 299D3 SKID STEER (A51242)
2024 CATERPILLAR...
2016 Mercedes-Benz GL-Class SUV (A50324)
2016 Mercedes-Benz...
NEVER USED FECON 74in Deck Mulcher FDM74 (A52128)
NEVER USED FECON...
AGT Mini SkidSteer (A50322)
AGT Mini SkidSteer...
