Log splitter modifications
/ Log splitter modifications #1
Bradbilt
Gilbert PA
Ford 260C, Ford 8N, NewHolland GT22,
Hey guys,
Doing some mods to my 27 ton Troybuilt(MTD) log splitter.
I was sick of tilting the splitter vertically and working on my knees or blowing out my back and picking up the big pieces.
So...... I added a log lift on one side and better tables on either side of the I-beam.
Well the time change is here and it is DARK.
Has anyone ever put and LED on a log splitter? It is a Honda 160cc engine
Suggestions?
/ Log splitter modifications #2
Work closer to the out buildings. Use the yard lights.
Oh, I wish it was that easy
/ Log splitter modifications #4
There are all sorts of solar flood lights available. As long as they get an all day charge, they'll last at least a few hours.
/ Log splitter modifications #5
When it's light could you take some pics of your mods? They sound interesting.
/ Log splitter modifications #6
Hey guys,
Suggestions?
What is the complete model of the Honda engine?
Can a lighting coil be added?
Richard
I hope to do my firewood this weekend
So maybe I can get you pictures
/ Log splitter modifications #8
One thing I did to my Swisher splitter was I had a buddy weld about another 14" on to the tongue. Now when I need to hook it up to the UTV I ran the ram out to shift the weight rearwards. That makes the tongue fairly light and a little easier to back it up without jackknifing. It's also much lighter to just walk the thing back into a corner to store it.
/ Log splitter modifications #9
I added about 30” inches on my splitter tongue so I could keep it hooked to the truck and load the truck. I’m considering counter balancing the back because it’s too heavy to lift the front by myself. IMG_7070.JPG
/ Log splitter modifications #10
I don’t think the Honda puts off much if any available electric for powering a light. You might use a deep cycle battery that you take off to charge. Second option is a generator. I do most of my splitting under a cover and I put up four 300 watt light bulbs. IMG_7774.JPG
I don’t think the Honda puts off much if any available electric for powering a light. You might use a deep cycle battery that you take off to charge. Second option is a generator. I do most of my splitting under a cover and I put up four 300 watt light bulbs. View attachment 627571
Ok, thanks. I wasn't sure If there was anything available to tap into
/ Log splitter modifications #12
This might be a good project for all the free blue LED lights from harbor freight!!!! just rig up 5 or 6 or them!
/ Log splitter modifications #15
/ Log splitter modifications #16
I have an electric start log splitter, 15hp out of a lawn mower. I debated adding a light pole to it but a good head lamp works just as good. I also have a 3 bulb flood light thats got a normal 120v plug on it. Basicly makes for a portable lamp post. Screw it on trees, my garage or just zip tie or on anything. Just need 120v power.
Same light last year while i was doing my garage roof after the time change and after work. The most enjoyable time to do roof work is when its nice and crisp.
/ Log splitter modifications #17
There’s plenty of cordless work lights ranging from free to hundred of dollars. I won’t buy any non rechargeable lights. I’ve got a dewalt one that I like because it runs almost forever on a battery charge. I might pick up a second one. IMG_7787.JPG
New/Unused Landhonor Hand Chain Lever Hoist (A65583)
New/Unused...
2018 Lincoln MKT Town Car AWD SUV (A61574)
2018 Lincoln MKT...
2020 VERMEER LP873SD1 VAC-TRON VACUUM TRAILER (A63276)
2020 VERMEER...
New/Unused Landhonor 16ft x 13ft Metal Carport (A65583)
New/Unused...
2013 Komatsu WA320 Wheel Loader (A60352)
2013 Komatsu WA320...
SHOPBUILT TRI-AXLE COMBINE HI-CYCLE TRAILER (A63291)
SHOPBUILT TRI-AXLE...
