Oil Question
/ Oil Question #1
hks003
Monticello, AR
2014 LS G3038
So, the tractor I bought in January is my first experience with a diesel engine. It's an LS G3038. When I bought it, it had 140 ish hours on it. The guy I bought it from said he changed the oil at the 50 hour mark per the manual, and had the receipt for the oil and filter.
Now, when I bought it, the oil was relatively dark already, and now at 170 hours it's slightly darker. If this were my truck, I'd be changing it. But, my manual says to change the oil at 300 hours. I'm seeing different places online where it's expected to see diesel engines turn oil black pretty quickly due to soot.
What's the general concensus here? Do you change it per the manual, or do you look for some other sign than color to know when to change it?
/ Oil Question #2
You can’t tell by looking at the oil when it’s time to change it. As long as it’s not grey (meaning water has gotten in it) and it doesn’t smell like diesel fuel (that would indicate an injector or possibly a high pressure pump problem), then run it the recommended change interval.
Change it earlier if you feel better, but it sounds like it was changed on schedule, so it’s fine as is.
/ Oil Question #3
There is so much soot and the like from diesel combustion that motor oil almost immediately turns dark, no worries
/ Oil Question #4
The manual,always do what the manual says,not what I say,not what they say,not what their manual says. ALWAYS do what your manual says. WHY??? Because I said! :D
/ Oil Question #5
Some diesels blacken the oil more quickly than others. My Mitsubishi oil turns almost black shortly after I change it. I pay no attention to the manual, I just change it every spring. I think I average fifty hours use each year but I don't think it hurts to change the oil that often.
/ Oil Question
I appreciate all the information! I feel better about it now, that's for sure.
/ Oil Question #7
My first tractor, Ford 1700, turned the oil black - like India ink - within ten hours. My 2009 Kubota M6040 has no noticeable change when I change it annually.
/ Oil Question #8
As others said I would not worry about the color. You have had it 9 months and only 30 hours. I think you will hit the time limit way before the hours.
I own 17 things with Diesel engines. I change the oil in them at 200 hours or once a year which ever occurs first. Oil breaks down over time due the combustion byproducts. I would not run it much over a year without changing it regardless of the hours.
250 hours probably won't hurt anything and I have even seen some manuals that say 300 or more. I stick to 200. Oil is relatively cheap.
/ Oil Question #9
Diesels differ from gasoline engines if the oil you are comparing to is a gas engine truck. Even the newest emissions engines which are not allowed to burn oil like the older engines get blackened by soot quickly. My diesel pickup is a 2003 and my mini-excavator is 2005, but all my diesel tractors (4) are 2015 or newer. Can’t tell the difference between them 30 hours after a change - they are all black. The newer ones have longer 400 hour change intervals. The best is to use the latest CK-4 oil which has better oxidation characteristics and reduced shear (oils, especially mineral oils with viscosity enhancers), can shear down so a 15W-40 becomes more like a 15W-30 at oil change time. Those characteristics, plus easier on any emissions system, are the reasons the CK-4 oil was introduced in 2016 to replace CJ-4.
/ Oil Question #10
Every other year on the tractor, which is about 150 hours. On my truck that only gets 1,000 miles/yr, I change about every 5 years.
Ralph
/ Oil Question #11
Being a retired mechanic... I change oil in most everything once a year.
cheap insurance. peace of mind.
Wasteing the oil? not really it gets recycled
/ Oil Question #12
Usually, the manuals state xxx amount of hours or once a year, whatever comes first.
If you put your tractor away through winter, change the oil and filters before you put it back to work in the spring.
If you use your tractor through the winter, change oil and filters in fall. You don't wanna fiddle around with oil chugs or plugged filters at sub zero temps.
/ Oil Question
Subzero! Ha! I'll be lucky to see sub freezing for more than a week.
/ Oil Question #14
One more opinion here. When I buy a piece of used equipment, which is mostly all that I buy, I go through it and change all the oil and filters. No telling what the previous owner did or used for oil. It痴 also sort of a ritual to learn the machine and make it mine.
/ Oil Question #15
Diesels differ from gasoline engines if the oil you are comparing to is a gas engine truck. Even the newest emissions engines which are not allowed to burn oil like the older engines get blackened by soot quickly. My diesel pickup is a 2003 and my mini-excavator is 2005, but all my diesel tractors (4) are 2015 or newer. Can稚 tell the difference between them 30 hours after a change - they are all black. The newer ones have longer 400 hour change intervals. The best is to use the latest CK-4 oil which has better oxidation characteristics and reduced shear (oils, especially mineral oils with viscosity enhancers), can shear down so a 15W-40 becomes more like a 15W-30 at oil change time. Those characteristics, plus easier on any emissions system, are the reasons the CK-4 oil was introduced in 2016 to replace CJ-4.
^^Right you are.^^ In addition where low annual milage/short trips are the norm,moisture condenses throughout engine and oil. That require's oil change based on time rather than mileage. An engine used 15 minutes daily should have oil changed sooner than one used 4 hours twice per month. Once engine reaches operating temperature,continued use pull's moisture out through pcv.
/ Oil Question #16
On so few hours I doubt you have a sludge buildup on the bottom of the oil pan.....but a finger wipe next time you have the drain plug out will answer that question. I bought a 1988 tractor last year with 900 hrs. Changed the oil and it immediately got dirty again. Drained and felt inside and found about シ" of sludge. New oil and filter and a can of Sea Foam in the crankcase and about a 30 minute run at moderate temps, non working, just sitting. Drained the oil and new filter again and it stayed clear this time and the finger wipe showed slight sludge...surface film sort of thing.
On manual info, I saw a picture of a 6530C like mine in a Korean rice field. I don't live in Northern Canada and only use my tractor for snow plow activities. Absolutely no way is my tractor subject to such harsh conditions. Therefore I use some common sense and what "I say" is good judgement when I follow OM recommendations. Your machine, your money, you do what you want.
2018 F-150 4WD (A63688)
2018 F-150 4WD...
250 Gallon Diesel Fuel Tank w/ Pump (A64047)
250 Gallon Diesel...
KUBOTA BX23SLB-R-1 TRACTOR (A62129)
KUBOTA BX23SLB-R-1...
NEW Wolverine 84" Skid Steer Bucket, 38" Depth (A62679)
NEW Wolverine 84"...
(2) 15.0/55-17 TIRES W/ 6 LUG RIMS (A64280)
(2) 15.0/55-17...
2014 Freightliner Bucket Truck (A56438)
2014 Freightliner...
