Price Check Kabota L3010HST
/ Kabota L3010HST #1
srxgreg
Oswego ny
New Holland TC45da
I am looking at a 2002 Kabota L3010HST with 72" mid mount mower tractor has 1750hr in very good condition always stored indoors. How much should I pay. Guy is asking 8700.00 usd
/ Kabota L3010HST #2
How much should you pay? What do they go for where you live? Does it have FEL? If I could have made that purchase here last summer I probably would have snapped it up. Personally I don't think it's unreasonable at all but I don't live in New York.
/ Kabota L3010HST #3
Kubota L3010
1998 - 2002 Grand L10 Series
Compact Utility tractor
Previous model: Kubota L2900
Next model: Kubota L3130
Manufacturer: Kubota
Variants:
L3010HST: 4WD Hydro
Kubota L3010 Engine:
Kubota 1.5L 3-cyl diesel
Kubota E-TVCS D1503 diesel
liquid-cooled
91.5 ci [1.5 L]
Bore/Stroke: 3.26 8x3.638 inches [83 x 92 mm]
Power (gross): 32.1 hp [23.9 kW]
Fuel system: indirect injection
Pre-heating: glow plugs
Rated RPM: 2700
Coolant capacity: 7.4 qts [7.0 L]
Capacity:
Fuel: 9.2 gal [34.8 L]
Hydraulic system: 10.3 gal [39.0 L]
3-Point Hitch:
Rear Type: I
Control: position control and optional draft control
Rear lift (at 24"/610mm): 2,200 lbs [997 kg]
Power Take-off (PTO):
Rear PTO: live
Rear RPM: 540 (1.375)
Mid PTO: semi-independent
Mid RPM: 2000
Dimensions
HST Weight: 2,745 lbs [1245 kg]
Wheelbase: 65.7 inches [166 cm]
Length: 110.8 inches [281 cm]
Width: 56.7 inches [144 cm]
Height (ROPS): 84.3 inches [214 cm]
Ground clearance: 13.8 inches [35 cm]
Front tread: 43.5 inches [110 cm]
Rear tread: 44.1/48.0/51.4/55.3 inches
[112/121/130/140 cm]
4WD turn radius: 8.2 feet [2.5 m]
Engine (gross): 32.1 hp [23.9 kW]
Engine (net): 30.4 hp [22.7 kW]
Gear PTO (claimed): 25.5 hp [19.0 kW]
Hydro PTO (claimed): 24 hp [17.9 kW]
Mechanical:
Chassis: HST - 4x4 MFWD 4WD
Steering: hydrostatic power
Brakes: wet disc
Cab: Two-post ROPS.
Hydraulics:
Type: open center
Capacity: 10.3 gal [39.0 L]
Pump flow: 7.0 gpm [26.5 lpm]
Steering flow: 4.7 gpm [17.8 lpm]
Page information:
Last update: December 28, 2018
Copyright: Copyright 2018 TractorData LLC
Contact: Peter@TractorData.com
/ Kabota L3010HST #4
With a Loader I would consider $8,700 a high value price in New York for a first iteration Kubota 'Grand L'.
The nearest equivalent in Kubota's product offering today is the L3301, which is not available with a mid-PTO but does have the advantage of an 'independent' rear PTO.
/ Kabota L3010HST #5
With loader I traded my 1300h (or so) L3410 with loader for 12k. That was after negotiation on the new machine, so I am sure the dealer planned on 14k reselling it.
The L3010 is slightly less HP, but even without a loader I would say $8700 is a good deal. Appearance is a plus, but that does not necessarily mean the machine is in good condition.
Also, pre emissions tractors are getting a premium price, and generally sell fast.
/ Kabota L3010HST
it doesnt have FEL all it has is 72"MMM and turf tires
17601CFL (A59228)
17601CFL (A59228)
GATOR UTV (A63276)
GATOR UTV (A63276)
Colombo Twin Master (A64126)
Colombo Twin...
EZ Trail 3400 (A63688)
2010 New Holland Boomer 8N (A62613)
2010 New Holland...
2014 MASTER END DUMP TRAILER (A65643)
2014 MASTER END...
