6 years first emissions problem
/ 6 years first emissions problem #1
MHarryE
Elite Member
Northeastern Minnesota
Kubota M7-171, M5-111, SVL75-2, RTV900XT & GR2120; CaseIH 1680 combine
My first tractor with DPF and/or DEF purchased in 2013 and this week first problem. Received items in pic in the mail. Don't look like much of a problem but instructions:
1 - park on firm surface, set brake
2 - lower all attachments
3 - set controls to neutral
4 - release hydraulic system residual pressure
5 - stop engine; remove key
6 - wait for everything to cool
7 - clean work area around machine
8 - disconnect ground cable
9 - hang DO NOT OPERATE tag on operator station
10 - don work clothes and protective equipment
11 - read instructions
12 - follow local safety regulations/law
13 - if working with others, communicate
14 - chock front and rear wheels
Remove fuel cap, place green emblem over fill port, install fuel cap
Remove DEF cap, place blue emblem over fill port install DEF cap
If necessary, you can contact your selling authorized Kubota Dealer for Assistance.
After the emblems are installed, it does not say anything about reinstalling battery cable, key, etc.
/ 6 years first emissions problem #2
Are you serious?
Good gawd man!
I’d hate to see the instructions for filling it with fuel.
Haz mat suits and respirators I presume?
Stream barriers and dikes set up in a 300’ radius, fire dept on standby?
/ 6 years first emissions problem #3
"After the emblems are installed, it does not say anything about reinstalling battery cable, key, etc."
That's where calling the dealer comes into play.....
/ 6 years first emissions problem #4
That's interesting because a couple weeks ago I had to get a part for my Ford. They also sell Kubota. I asked the guys at the parts desk if they've had much trouble with the new emissions systems. They said the problems that did come in were for the most part owner related, like adding washer fluid or diesel fuel to the DEF tank. Looks like Kubota's trying to eliminate owner carelessness.
/ 6 years first emissions problem #5
You've got a lot of instructions for job preparation and safety. You may have even followed them. Is there a job involved or some included equipment to install? I thought all changes to the DPF system were the responsibility of the dealer not the end user to ensure they were done correctly.
Yes, the 2 labels in the picture. And yes, it states that if you so desire, the dealer will install them for you.
I’m sure there is a way to foolproof DEF fill but they have already done a lot. The DEF fluid container comes with a tip that fits the filler precisely. If you try to fill out of a bottle such as the one for windshield washer fluid, the fluid will spill out on the ground as the tube into which you insert the filler is recessed in the opening. Trying to pour from a one gallon bottle without the spout will result in most of the fluid going on the ground. The cap on the DEF tank is bright blue. It should not be rocket science; however, many of my colleagues traveling to Europe will fill their diesel rental car with gasoline due to American habit.
/ 6 years first emissions problem #8
As soon as they make it foolproof they make a better fool !
Years ago worked at a nursery with a good sized fleet.
I painted the fuel caps and fuel pump nozzles to match. They still managed to put gas in the diesels so I built a skid tank and fueled the tractors myself.
/ 6 years first emissions problem #9
"many of my colleagues traveling to Europe will fill their diesel rental car with gasoline"
My son did exactly that, on his honeymoon in France!
/ 6 years first emissions problem #10
Even though, every rental place will put a big sticker near the fill port with the type of fuel that the car uses.
Wonder if they modify fuel map on rentals because of that happening so much, but then one traffic less Sunday morning in Germany I was able to verify the speed limiter on my Audi A6 actually limited it to its advertised 255 kph and figured it was not detuned unless it had the ability to sense fuel quality. But - driving that speed did not come from going there, renting a speedy car, and going to try it out. Hundreds of thousands of miles and training before doing that and then lucking out to be provided such a rental without special request.
2017 Ford Explorer AWD SUV (A59231)
2017 Ford Explorer...
2008 JOHN DEERE 700J LGP CRAWLER DOZER (A62129)
2008 JOHN DEERE...
2013 FORD F-350 FLATBED (A58214)
2013 FORD F-350...
2016 Jeep Patriot SUV (A61569)
2016 Jeep Patriot...
(2) 460/85R38 TIRES W/8 LUG RIMS (A62130)
(2) 460/85R38...
UNUSED KJ 40'X20' STEEL CARPORT SHED (A62131)
UNUSED KJ 40'X20'...
