Good morning!!!!
   / Good morning!!!! #101,141
Buckeye, that sounds like fun.
Just sent helper home, finished ripping out the okra and doing a lot of garden cleanup.
Now I'm bushed and intend to stay off my feet.
Got some nice seat time in big Massey mowing fields and roadsides, had to get up and down a bunch of times for trash.
But sure was nice to be out.
home made blackberry/blueberry preserves made from my bushes.
Yum. Thank you neighbor.
found my one tractor picture of the trip, not very good, little JD with a big leaf sucker.
   / Good morning!!!! #101,142
47 degrees and misty with some fog this morning; cleared off before 10 a.m. and eventually got up to 64 degrees. I had to take my wife and her sister to meet their brother for lunch about 75 miles east of here. Nice day but I'm glad to be back home.
   / Good morning!!!! #101,143
Ron, I opened your crane pic in a new tab then enlarged it. Looks like the bird was looking straight at you while you were taking the pic.
I got the firewood piles relocated, the flatbed trailer moved and the grass beat down where it parks. Took about 2 hours, now it is Miller time.
   / Good morning!!!! #101,144
I was standing at kitchen sink window. About 50’ from Crane. There are 3 of them. One is always looking out while the other 2 are eating. They take turns doing this. They do not run away unless Sassy is chasing them. I am sure they can see me at the sink.
   / Good morning!!!! #101,147
Canada Geese do the same thing. Depending on the size of the flock, there might be two watching for predators.
   / Good morning!!!! #101,148
My internet Mobley and mini router sit in an unfinished room above the garage. There’s no outlet in the room, so they are plugged in a hall outlet near the door.
Today I decided I needed an outlet in the room. Do ran wire down along ductwork to basement. Installed outlet. Went to wire into panel and discovered the breaker I thought was spare has wire on it, feeds garage outlets.
Then found I had no romex clamps for the box, so didn’t get it done. Lowe’s trip tomorrow.
Legs are screaming pain now from all the up down stairs. Looking back, a month ago I was still scooting up down stairs on my butt, so I’ve come a long ways.
Got my first LTD check in the mail today. Wasn’t expecting that yet. Pay for October.
When I was building my house I enjoyed the geese flying over. Some were pretty low.
   / Good morning!!!! #101,149
Good evening all. 46F for the start, overcast, moderate wind and drizzle. Drizzle let up about 9AM, Clouds thinned out in the afternoon, moderate north wind and high temp of 67F. Had less than a .1 inch rain in bucket, trace more till 9 am. Tuesday, Wednesday, and Thurday do no look like biking weather, about 2 inch rain forecast, windy and turning colder. Bike ride this morning, cold and wet till 9 then things got a lot better. 2 hour nap this afternoon.
David sounds like progress. Is the new generator in position, and just need the fuel and electrical hookups and engine inspection oil change etc?
Eric been a while since a new tool did that for me (smile when you walk by).
Drew can you shut off propane at the bottle at end of trip or does that cause problems also? good luck with your cord.
Billy, also wondered that myself, but never had a problem starting the ford at 20F or above (no block heater).
Drew, wife and I are in for beach maintenance :)
Don how much will you garden produce in the Fall?
L4N nice progress on winter prep.
Buckeye, nice progress in physical capability.
prayers for all.
   / Good morning!!!! #101,150
surprisingly warm morning, 71 going up to low 80's, going to be a wet day with showers and thunderstorms.
I realized today was last day of ten percent off coupon at TSC, might make a trip downtown for that later, maybe not.
Sort of happy this is a do nothing day.
CASE 850M LGP CRAWLER DOZER (A52709)
CASE 850M LGP...
2018 HINO CONVENTIONAL TYPE TRUCK (A55745)
2018 HINO...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2018 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A59575)
2018 FREIGHTLINER...
IRMC High-End Massage Chair (A57149)
IRMC High-End...
Sheets of Tin (A57149)
