Eagle V Plow Or Straight??
/ Eagle V Plow Or Straight?? #1
tjklein
Member
NJ
none
Looking to get a plow for my UTV-- Decided on the Eagle Brand as they make a mount for my UTV that most companies do not offer- So for my long paved driveway would you go with a Straight plow with Hydraulics or the V plow without Hydraulics- Also is it a pain to get out and change the pivot points on the V every time you want to go from V to straight to scoop- thanks for the advice-
/ Eagle V Plow Or Straight?? #2
Straight blade if you can control everything without doing it manually..
/ Eagle V Plow Or Straight?? #3
I would "go with" neither!
I would "go to" Florida!
/ Eagle V Plow Or Straight?? #5
Had an Eagle Vee plow a few years back mounted on a Deere 855 (Diesel) Gator.
I didn't use the "Vee" feature much since I normally wanted to push the snow to one side. This one was manual adjust that I bought used (and cheap). It worked well and I'm sorry I sold it.
To me, it's not a pain to get out and manually pivot the blade...it's only a minute to do this...and the expense of a hydraulic blade wasn't worth it to me. Also, the weight of the hydraulic units can lead to wear on the UTV's front end.
A UTV/Plow setup isn't very good for heavy snow (8-10 inches or more). You'll run out of traction...or, at least, I did. But for lighter snows, it's a great combination and fast.
Snow plowing can be tough on a UTV...be aware of that. And, if the winch is used to raise and lower the blade, you'll wear out the first foot or so of the wire rope. I swapped out my wire rope for a boat strap which worked much better. Also, it's better to have at least a windshield, if not a full cab.
That's my 2 cents...
/ Eagle V Plow Or Straight?? #6
A "V" would only be OK for the first snow event to 'open' the path.
A UTV simply lack weight for traction which U need to push sufficient snow.
If U insist on using your UTV I look for self contained front mounted snow blowers as a compromise solution, they exist.
BLOW that white stuff as far away as U can, plowing makes for berms that make for bigger drifts and that calls for more weigh and power.
/ Eagle V Plow Or Straight?? #7
I agree.. The self contained blower is the way to go on an ATV/UTV.. Less stress on the lighter machine and no banks to move..
/ Eagle V Plow Or Straight?? #8
I used a 7' Snowsport plow on the front of my RTV900 and it pushed great. The RTV900 weighs in at 2000 lbs though.
thks- Since here in NJ- we have not gotten deep snow for awhile so I am thinking the cost of a front end blower would be to much-Seems to be a pain I think to keep gettting out of the enclosed cab to switch the pins on the V all the time or am wrong- thanks for all the advice-
/ Eagle V Plow Or Straight?? #10
Nj and even southern NY gets snow thats really to wet most early and late season to blow real well. A plow has very few moving parts and works in slush- powder.
I went from streight to V plow on my truck. Il never own a streight blade again. Saves me roughly 30* on time and i can stack or move a whole pile across the driveway with next to no spillage. This means no snow tails to clean up later.
/ Eagle V Plow Or Straight?? #11
What did you end up with tjklein??? I'd go with a straight blade. I've been happy with the 6ft one on our 6x6 so far but let me add. I don't thing much of Moose made we got, they are pretty light..
ended up getting a 6 foot eagle straight blade with hydraulics= thks for all the advice-
2020 Ram 1500 Pickup Truck (A64194)
2020 Ram 1500...
2015 International DuraStar 4300 Elgin Broom Bear Street Sweeper Truck (A64556)
2015 International...
Unverferth Ripper Stripper (A64126)
Unverferth Ripper...
New/Unused Landhonor Hydraulic Quick Attach Pallet Forks (A65583)
New/Unused...
Kobelco SK55SRX Excavator (A65579)
Kobelco SK55SRX...
2021 Felling FT-45-2LP 29ft. 26 Ton Tag Trailer (A64194)
2021 Felling...
