Eagle V Plow Or Straight??
/ Eagle V Plow Or Straight?? #1
tjklein
Member
NJ
none
Looking to get a plow for my UTV-- Decided on the Eagle Brand as they make a mount for my UTV that most companies do not offer- So for my long paved driveway would you go with a Straight plow with Hydraulics or the V plow without Hydraulics- Also is it a pain to get out and change the pivot points on the V every time you want to go from V to straight to scoop- thanks for the advice-
/ Eagle V Plow Or Straight?? #2
Straight blade if you can control everything without doing it manually..
/ Eagle V Plow Or Straight?? #3
I would "go with" neither!
I would "go to" Florida!
/ Eagle V Plow Or Straight?? #5
Had an Eagle Vee plow a few years back mounted on a Deere 855 (Diesel) Gator.
I didn't use the "Vee" feature much since I normally wanted to push the snow to one side. This one was manual adjust that I bought used (and cheap). It worked well and I'm sorry I sold it.
To me, it's not a pain to get out and manually pivot the blade...it's only a minute to do this...and the expense of a hydraulic blade wasn't worth it to me. Also, the weight of the hydraulic units can lead to wear on the UTV's front end.
A UTV/Plow setup isn't very good for heavy snow (8-10 inches or more). You'll run out of traction...or, at least, I did. But for lighter snows, it's a great combination and fast.
Snow plowing can be tough on a UTV...be aware of that. And, if the winch is used to raise and lower the blade, you'll wear out the first foot or so of the wire rope. I swapped out my wire rope for a boat strap which worked much better. Also, it's better to have at least a windshield, if not a full cab.
That's my 2 cents...
/ Eagle V Plow Or Straight?? #6
A "V" would only be OK for the first snow event to 'open' the path.
A UTV simply lack weight for traction which U need to push sufficient snow.
If U insist on using your UTV I look for self contained front mounted snow blowers as a compromise solution, they exist.
BLOW that white stuff as far away as U can, plowing makes for berms that make for bigger drifts and that calls for more weigh and power.
/ Eagle V Plow Or Straight?? #7
I agree.. The self contained blower is the way to go on an ATV/UTV.. Less stress on the lighter machine and no banks to move..
/ Eagle V Plow Or Straight?? #8
I used a 7' Snowsport plow on the front of my RTV900 and it pushed great. The RTV900 weighs in at 2000 lbs though.
thks- Since here in NJ- we have not gotten deep snow for awhile so I am thinking the cost of a front end blower would be to much-Seems to be a pain I think to keep gettting out of the enclosed cab to switch the pins on the V all the time or am wrong- thanks for all the advice-
/ Eagle V Plow Or Straight?? #10
Nj and even southern NY gets snow thats really to wet most early and late season to blow real well. A plow has very few moving parts and works in slush- powder.
I went from streight to V plow on my truck. Il never own a streight blade again. Saves me roughly 30* on time and i can stack or move a whole pile across the driveway with next to no spillage. This means no snow tails to clean up later.
/ Eagle V Plow Or Straight?? #11
What did you end up with tjklein??? I'd go with a straight blade. I've been happy with the 6ft one on our 6x6 so far but let me add. I don't thing much of Moose made we got, they are pretty light..
ended up getting a 6 foot eagle straight blade with hydraulics= thks for all the advice-
2007 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A65643)
2007 DRAGON 150...
2016 Ford Transit 350 Wagon Passenger Van (A64556)
2016 Ford Transit...
2012 Chevrolet Equinox AWD SUV (A64557)
2012 Chevrolet...
(5) Round Grass Hay Bales (A66408)
(5) Round Grass...
2024 MODASA  MH-25 I GENERATOR (A65643)
2024 MODASA MH-25...
3ft Metal Chevrolet Tailgate (A65583)
3ft Metal...
