Flail Mower Just bought a Nova-tractor Ditch Mower
   / Just bought a Nova-tractor Ditch Mower
Just some early pictures. I will load a video soon. This machine is a great machine and worth the money. 28, 1.75-pound hammers spinning at 2200 RPM will absolutely destroy about anything you run over, leaving nothing but finely mulched debris.
My principal purpose for this machine is to trim around the hayfields and ponds on the property. What I have found is its a better machine to move close-in to the fence rows compared to the other mower I have been using. Keeping 5 miles of Ky Blackboard fence trimmed takes some work!
Speaking of fences, while cleaning up adjacent to a deeply enshroud woven fence, the unit grabbed some fencing material that was apparently just left adjacent to the fence and wrapped the barbed wires nice and tight around the spindle. Wire cutters could not cut these wires, but the grinder sure could. Cut the wires, sharpened a couple of hammers while at it, and went back to work.
I have been clearing some areas with heavy brush and saplings and this tool absolutely impresses me. I don't want to sound over-zealous, but seriously, compared to other models available on the market, the extra cost was worth it.
Here is another example I just took about an hour ago. Had to quit for the day as I shattered my rear window backing into a branch and temporarily blinded by the sun. Shoot - always something.
VimeUhOh
   / Just bought a Nova-tractor Ditch Mower #14
Wow! That thing works great.
   / Just bought a Nova-tractor Ditch Mower #15
Hello Unwiredone,
I'm hoping you can give some additional feedback on the Nova BCRM175 I'm considering buying one at this very moment. I'm also considering the BCRM200 as well.
A few quick questions
Q1: what do you think of the mower since using it ?
Q2: How is the reliability and cut quality
Q3: How does it do cutting brush and rough stuff
Q4:How does your NX5010 handle it ? (I'll be using it with an RX7320 so more concerned about the weight of the BCRI200 but if BCRM175 is "no problem at all" on NX5010 I figure my RX7320 with loader and filled tires can handle the extra 500lbs of the BCRI200)
Q5: Would you buy this mower again ?
Thanks,
John
Hello Unwiredone,
Thanks,
John
Hi, John. Happy to help here.
A1: I love the mower, yet its also very special use. Living here in Kentucky on a small horse farm (~ 300 acres), I have lakes, fence rows, and woods bordering fields that all were in definite need of a good cleanup and this mower got the job done and then some. The mower is a beast, but it's not designed for speed. I don't think any flail mowers are as they are special purpose.
A2/A3: Reliable? Very much so. Cut quality? It's not a finish mower (For trim I use an 84" Bushhog brand finish mower), but it will mulch and obliterate whatever you run over. A large selling point for me was the hammer weight and qty. 28, 1-3/4 pound hammers turning at 2000+ RPM is going to destroy small brush (I've run over aged 3-4" logs and it will blast them apart). Also, the forged hammers are easy to sharpen and also a feature I really like.
A4: With the mower extended to its furthest reach, on a slope, it definitely changes the center of gravity if its raised off the ground. Yet any attachment that extends out from the center will have the same effect. With the mower off-set just behind me, not an issue. Now, vertical, like trimming hedges (More about this in a moment), you just have to be very aware of terrain, slopes, etc. It's not a boom mower with a large counter weight.
A5: Would I buy this brand again or this mower? Yes and yes, but let me take this a step further. I'm not super impressed with the sales rep (He was ok), but the owner of the company? Holy cow that man is knowledgeable, fast to respond, and under promises and over-delivers. I am probably more impressed by the company than the mower - and I really like this mower.
Misc comments:
So you know, I have broken parts on this mower already doing things with it I probably shouldn't. I have had to get the grinder out to cut off a large ball of barbed wire that the mower got into. No belt breaks, no harm to the tractor, cut it off, went back to work. For the record, I've broken my tractor while using this thing, so it's not the quality of the machine, but rather the operator (Falling on the sword here.).
The manufacturer has replaced a couple of hoses that sprung leaks and for my troubles, sent me some extra hammers too. It might not be your experience, but that's just an example of the company standing behind its product.
The idea of hedging with a flail mower...it doesn't do a good job. I don't recommend it. One, you have to crawl as limbs tend to be pushed out of the way by the front guard and when they spring back, at any speed, will miss the flails.
Clearing the banks around the lake - fantastic. Clearing underbrush around the fields equally impressive. With this offset hanging 6' out and dragging it through the brush, many times you won't even see it - but you'll hear it. I positively love how it drops the cuttings in-place versus slinging and scattering. You will hit rocks and large limbs and it will typically bounce or ping right over top.
Also, I was originally going to use the FEL hydraulics to manipulate the controls, but after using it, I elected to just add a 2nd remote valve. Nice having the counterweight of the FEL along with the ability to push some material away. Further, the mower is more set and forget while working it. You're not going to be doing a lot of position manipulation like you might be thinking.
I hope this helps and if I can answer any more questions, don't hesitate to ask.
- David
Disclaimer: I am not a paid shill for this product. I bought my mower and these are simply my personal experiences.
By the way, John, how do you like your RX7320? I've actually considered making that my next tractor purchase. The NX5010 is my 'small tractor' as I have others, but I'm thinking I might need a mid-range 70HP or so.
- David
   / Just bought a Nova-tractor Ditch Mower #18
Hi David,
Thanks very much for the detailed reply, I wish I could give as detailed a review of the RX7320 but I've yet to receive it :-(
Dealer has it now and is prepping it,fluid filling the tires, installing an additional rear remote and a third function valve for the FEL.
I should have had it a few weeks ago but it got tied up in the Cyber attack that had KIOTI crippled..
I'm hoping to get it this weekend.
The Nova mower would be my first implement to go with it, I'm also planning to get the KIOTI 12FT Batwing (same as woods) but they can't get me one until after we are deep in snow cover in New Hampshire so I figure I could get the Nova and use it in a similar manner as you are. I'm kind of disappointed its not very good at vertical trimming as I wanted to do quite a bit of that around my field edges and woods roads.
Before I found the Nova Ditch mowers I was looking at getting a standard hydraulic offset flail (Was thinking woodmaxx) and then in the spring getting a Lane Shark for vertical trimming but the cost of those two pieces is twice that of the Nova. I was hoping the Nova could do double duty
Thanks Again,
John
It appears you are going through the same exact throught process I was doing ask I looked at the off-sets and the Lane Shark. Let share with you that you can use it to hedge, its 1) Not going to be pretty and 2) You have to go slow. You could always take off the front guard. Don't think for a second I haven't used it to hedge - I have - an I have managed to push the brush pretty far back. Too, I'm going to hit again soon once the leaves are off. I may actually be able report a different experience.
I looked at Betsco and Woodmax, but Nova, although a bit more expensive was definitely the right decision.
Now let's talk about the lane shark and the knock off that Titan did. I frankly think a good fabricator and build one for half the cost if not less. I put together a parts list and I could buy all the parts for under $900. You can buy the hydraulic oil motor for about $200, the quick attach frame was also $198 on Amazon. Hoses and misc parts about $400 including the steel. So....I'm likely to do something along this route.
   / Just bought a Nova-tractor Ditch Mower #20
Thanks David!
Very informative thread.
A one more quick question-Any joystick control comes with this mover?
Thanks
2014 Ford F-150 Ext. Cab Pickup Truck (A53422)
2014 Ford F-150...
2014 MACK ELITE LEU613 GARBAGE TRUCK (A57192)
2014 MACK ELITE...
Lounging Mermaid Statue (A55853)
Lounging Mermaid...
2012 Kia Sorento SUV (A55853)
2012 Kia Sorento...
2012 Ford F-150 Ext Cab 4x4 Pick-Up Truck (A55852)
2012 Ford F-150...
2015 ISUZU NRR DEBRIS TRUCK (A57192)
2015 ISUZU NRR...
