Battery Tenders
/ Battery Tenders #21
"Battery Tender" is a registered trademark (patent?) of Deltran Corp. in DeLand, Fl.
Those pictured are not Battery Tenders!
Maybe Harbor Freight?
Yep HF, I call all my battery maintainers battery tenders, i am normally not referring to one particular brand, forgot I had this little solar one in my basement not being used also.
/ Battery Tenders #22
Well....to show you how little I know.... I didn't realize (given your comment) that there might be a choice!!!
So, yes...solar powered.
Buy a good one if your going to do solar, I bought 3 from HF and two are in the garbage and one is still in the box, I know there is one made for boat lifts that is real nice, think it is Extreme solar?
/ Battery Tenders
The thrust of my question however, is.... would a higher wattage be needed or is a lower trickle charger type sufficient?
Presumably the battery would be at a decent/good charge when parked verses dead.
I suppose these automatically shut down?
/ Battery Tenders #24
Whatever type you buy, make certain that it is UL/CSA approved.
A fire caused by cheap electrical devices can destroy a tractor, as well as the building it is stored in.
I do not buy any unattended electrical items from HF.
/ Battery Tenders #25
I have battery maintainers on all my equipment and vehicles but I do not let them stay on all the time. I have them on timers that turn them on and off once or twice a day for 30 minutes depending on what it is attached to and how old the battery is. Before I started using them I had read many accounts of them cooking batteries (even the high priced brands) and even some blamed for starting fires so I decided using a timer was the way to go. The added benefit has been longer battery life since I started using them. Never tried a solar unit since all my goodies stored inside near to power.
/ Battery Tenders #26
A good battery fully charged with the positive cable disconnected will hold its charge for at least 6-7 months, the boat dealer I used to work at stored around 600 boats over the winter months and the only ones that had battery issues were either not fully charged, bad to begin with or were left fully hooked up when put into storage and were slowly draining over the winter, boats are stored indoors in unheated turkey barns, or unheated storage buildings, maybe 50 or so are left outside.
Batteries are unpredictable, might last 7 years or might last 1 start, I did Exide battery warranties for over 13 years.
/ Battery Tenders #27
I do like you do except I will just unplug them for a day to a few days depending if they are inside or outside and what they are on, if it is below zero outside I will just leave them on. A few years ago I forgot to put the charger back on my golf cart and had two batteries freeze and crack open, what a mess on my garage floor.
/ Battery Tenders #28
Whatever the brand, use a bit of caution, I had a Deltran Battery Tender, I hooked it up to my Harley's battery, plugged it in, and smoke started rolling out of it. I unplugged it and threw it into the trash. I have bought two Schamacher smart chargers, so far so good, unlike the Battery Tender, the cases are plastic...if a component overheats they will be more of a fire hazard than the Tender. I use them with caution.
/ Battery Tenders #29
I have a two Deltran, and one CTeK. On the pickup, motorcycle & tractor. All are on all the time. Never once had any type of problem. They do a great job of keeping the batteries fully charged. At thirteen years on my previous tractor - had the battery checked at Les Schwab. Still in great shape. I had a Deltran on that battery from the day I bought it - 24/7/365.
Buy a quality battery tender - use it correctly - very little chance of any problems. All three run at around 1.25 V.
/ Battery Tenders #30
I have the same issue with my truck. It must have a slight electric leak and the batteries are getting old. Instead of worry about trying to park close to the house or barn then running an extension cord, I just use this solar charger. It works great. I have been using it for about a year now. I keep it in the center console and it plugs into the cigarette lighter. It also comes with clamps that I have used on my riding lawn mower.
https://amzn.to/32EW24T
/ Battery Tenders #31
A good battery/electrical system dosnt need to be on a tender for months at a time. I have quads that havr been sitting for months over the winter. They start fine.
/ Battery Tenders #32
CTEK model 56-158
/ Battery Tenders #33
Have to disagree when it gets below -0 here in Michigan you need a battery tender.Unless to like buying new batteries every 2-3 years.Have the CTEK model tender on my 2018 challenger over the winter in my insulated barn.
/ Battery Tenders #34
Buy a quality battery tender - use it correctrely - very little chance of any problems. All three run at around 1.25 V.
Same here!
If I am planning to not use a vehicle, or machine, for more than 2 weeks, I keep a battery tender on.
/ Battery Tenders #35
Lol 2 weeks.
I hope you guys know that these tenders can do damage and even boil off water in batterys. Theres no need for a battery tender for a few months in the off season and def not 2 weeks.
/ Battery Tenders #36
Lol 2 weeks.
NOT if you buy a good brand one!
I've only seen one do that, it was a HF brand...
SR
/ Battery Tenders #37
Lol 2 weeks.
Do your homework and buy a quality one that does NOT do that.LOL..
/ Battery Tenders #38
I don't buy the cheap junk!
I leave 'em on everything, and have done so for many years.
Never had a battery boil off water.
I get amazing battery life!
Why would I not use them?
I have 18 batteries.
/ Battery Tenders #39
i have 9. all HF models, NONE boil the battery.
/ Battery Tenders #40
Me to fried,have the boat battery,3 cars,kubota 900,tractor all on battery tenders over the winter months.Some folks have NO CLUE..
2012 FORD F-350 SUPER DUTY FLATBED TRUCK (A64276)
2012 FORD F-350...
29 x 9.0 x 15 5 Lugs Tires (A61573)
29 x 9.0 x 15 5...
CORE CUT CC1300-XL CONCRETE SAW (A64281)
CORE CUT CC1300-XL...
1987 International 1954 Elliott ECE 3-65H Telescopic Boom Lift Truck (A61573)
1987 International...
2018 VOLVO SD75B SMOOTH DRUM ROLLER (A65053)
2018 VOLVO SD75B...
2011 Ford E-350 Passenger Van (A61573)
2011 Ford E-350...
