Belarus 920 - starter motor will not activate
/ Belarus 920 - starter motor will not activate #1
ozebee
Belarus 920
After not being used for some 3 months the starter motor will not kick in. Batteries are all OK but no action from starter motor - not even a click. What should I be diagnosing first and how. How do I jump start it bypassing the ignition switch? How can I test if the solenoid is getting power? Is the solenoid jammed and if so how do I free it up?
Any help will be greatly appreciated.
/ Belarus 920 - starter motor will not activate #2
For the solenoid to do anything it has to be getting power when you turn the key. If you know the location of the solenoid put a voltmeter on the terminal from the key and see if you have voltage when the key is turned. You could have a defective or dirty key switch or a loose wire between there and the starter. Mice like to chew wires, too.
/ Belarus 920 - starter motor will not activate #3
I often use an old style pointy testing light. The brightness of the bulb can tell you more than a meter. Clip it to a good ground, and see if you have power coming from your battery at the starter.
The thing is, that if you have a high resistance connection, a digital meter will still read full battery voltage which can be very misleading if you don't understand electrical theory.
/ Belarus 920 - starter motor will not activate #5
Yeah... I have $500 worth of digital and analog meters and the point test light is my first go to on non computer automotive/tractor circuits....
To OP, as for troubleshooting start issue, put test light on terminal/wire that energises solenoid and see if you are getting "power" to energise solenoid ... That should tell you which way to troubleshoot....
Dale
/ Belarus 920 - starter motor will not activate #6
I noticed this old post. did you get your problem solved. I have a few of those Belarus tractors.
2012 Chevrolet Sonic Hatchback (A61569)
2012 Chevrolet...
New/Unused Grapple for CFG Mini Excavator (A61166)
New/Unused Grapple...
UNUSED WOLVERINE 8' FORK EXTENSIONS (A62131)
UNUSED WOLVERINE...
2021 Chevrolet Equinox SUV (A61569)
2021 Chevrolet...
2018 Komatsu D61PX Crawler Tractor Dozer (A59228)
2018 Komatsu D61PX...
New/Unused 3 Point Ball/Flat Hitch (A61166)
New/Unused 3 Point...
