Ford 1720 Clutch
/ Ford 1720 Clutch #1
John Knoble
Antelope Acres Ca
1990 Ford 1720
Are all Ford 1720 tractors doomed to have a dual stage clutch? I know the run on these tractors were from 87/99,i have a 1990 and according to the $26 service manual I could have either dual or single stage.My modle #AL413A. I've determined the clutch needs replacing and don't want to order the wrong clutck and release /pilot bearings.Any help with making the right call would be appreciated.
Thanks John:thumbsup:
/ Ford 1720 Clutch #2
AFAIK the 12x12 has a double clutch and the 9x3 has a single clutch. A single clutch will stop travel and the PTO concurrently, a double clutch will not. If in doubt, split the tractor before ordering parts. Yeah, I know, you don’t want to do that.
/ Ford 1720 Clutch #3
Did the 1720 have the rubber covers on the side to inspect the clutch?
/ Ford 1720 Clutch
Thanks for your response.I took the steering column panels off and did not see any rubber grommets to take a look see. I read that in the service manual,but hadn’t had a chance to look at till today. Kinda recovering from a crash on my mini bike that I upgraded from the junk 3hp to the Predator 6.5hp,got a unintended wheelie that got away from me I知 glad I left the governor on I壇 be in traction
Thanks John
/ Ford 1720 Clutch #5
#24. Might be behind the loader mount if you have one. Screenshot_20191016-160718_Chrome.jpeg
/ Ford 1720 Clutch
I’ll take a look at that,I’m thinking the left hand side possibly. And I do have a loader,but was thinking it would be located on bell housing or similar place.
Thanks John ��
/ Ford 1720 Clutch
Thanks for your response Rick.The diagram in the manual shows a small plate but can’t see anything right off��
/ Ford 1720 Clutch #9
If your 1720 is the same as my 1920, and I think it is.....
The clutch inspection plate IS behind the Left side loader mount.
You cannot see it until you remove the left side loader mount.
/ Ford 1720 Clutch
Thanks I’ll look into that ��
2021 Peterbilt 579 (A64127)
2021 Peterbilt 579...
3 Point Boom Lift (A62613)
3 Point Boom Lift...
2017 Ford F-150 Pickup Truck (A64556)
2017 Ford F-150...
JOHN DEERE 5403 TRACTOR (A65643)
JOHN DEERE 5403...
Log Chain (A65640)
Log Chain (A65640)
(1) New 7ft Chain Sling (A65579)
(1) New 7ft Chain...
