Ford 1720 Clutch
   / Ford 1720 Clutch #1
John Knoble
Antelope Acres Ca
1990 Ford 1720
Are all Ford 1720 tractors doomed to have a dual stage clutch? I know the run on these tractors were from 87/99,i have a 1990 and according to the $26 service manual I could have either dual or single stage.My modle #AL413A. I've determined the clutch needs replacing and don't want to order the wrong clutck and release /pilot bearings.Any help with making the right call would be appreciated.
Thanks John:thumbsup:
   / Ford 1720 Clutch #2
AFAIK the 12x12 has a double clutch and the 9x3 has a single clutch. A single clutch will stop travel and the PTO concurrently, a double clutch will not. If in doubt, split the tractor before ordering parts. Yeah, I know, you don’t want to do that.
   / Ford 1720 Clutch #3
Did the 1720 have the rubber covers on the side to inspect the clutch?
   / Ford 1720 Clutch
Thanks for your response.I took the steering column panels off and did not see any rubber grommets to take a look see. I read that in the service manual,but hadn’t had a chance to look at till today. Kinda recovering from a crash on my mini bike that I upgraded from the junk 3hp to the Predator 6.5hp,got a unintended wheelie that got away from me I知 glad I left the governor on I壇 be in traction
Thanks John
   / Ford 1720 Clutch #5
#24. Might be behind the loader mount if you have one. Screenshot_20191016-160718_Chrome.jpeg
   / Ford 1720 Clutch
I’ll take a look at that,I’m thinking the left hand side possibly. And I do have a loader,but was thinking it would be located on bell housing or similar place.
Thanks John ��
   / Ford 1720 Clutch
Thanks for your response Rick.The diagram in the manual shows a small plate but can’t see anything right off��
   / Ford 1720 Clutch #9
If your 1720 is the same as my 1920, and I think it is.....
The clutch inspection plate IS behind the Left side loader mount.
You cannot see it until you remove the left side loader mount.
LOAD OUT AND SHIPPING (A51573)
LOAD OUT AND...
MARS AIR DOORS TAN BANK (A51248)
MARS AIR DOORS TAN...
NEW Wolverine 72'' Skid Steer Tiller (A53002)
NEW Wolverine 72''...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
Kubota SSV75 Compact Wheel Loader Skid Steer (A51691)
Kubota SSV75...
