   / Harbor Freight Tools that don't suck #11,811
I got the 8" solid for one of the finish mowers I'm working on. Hub is centered, not offset which is what I needed.
So far, the press is fine.
The Merlin dial air chuck/gauge is acting up. Not reading tire pressure, but seems to read tank pressure instead. Not sure why.
   / Harbor Freight Tools that don't suck #11,812
I just bought four of these tires for a MMM dolly I am making and for only 3.99 each on sale it is a good deal.
They are an amazing bargain for the price, but they don't seem to hold air worth a darn. But then, I'm sure you have an air compressor.
Agreed. I bought four of them to build a portable cart for storing, plywood, cutoffs, etc. They went flat immediately. Slimed them and I still have to put air in them when I move it. I think if you have much load on them, they aren't worth it.
   / Harbor Freight Tools that don't suck #11,813
I've had good luck with those tires, but I always select the firmest available in the store. They only need air maybe once or twice a year.
Bruce
   / Harbor Freight Tools that don't suck #11,814
Bruce
Bruce, are your tires heavily loaded? I admit, I have a very heavy cart storing lots of plywood sheets and other misc lumber and it sits most of the time.
   / Harbor Freight Tools that don't suck #11,815
Mostly light loads; hand trucks, garden carts.
Bruce
   / Harbor Freight Tools that don't suck #11,816
I have several of the 8" 2 on a HF concrete mixer that are working fine. Did not have to add air either. After doing some mods to the mixer it is so far pretty good for what it is, light duty. Added the 8" wheels and it moves a lot easier. Also installed a rain proof switch, the existing burned out first load using it in the rain.
Ron
   / Harbor Freight Tools that don't suck #11,817
Ron
I replaced mine ... before ever using it. Wheels came off a rusted out fertilizer spreader.
   / Harbor Freight Tools that don't suck #11,818
That "10% off any item, no exclusions coupon" says "Non-transferrable. Original coupon must be presented." Has anyone had any luck using a picture on their phone with this? If not, where did it originally appear? I don't recall seeing tis in any mailings I received.
I have always used screen shots of coupons at HF.
Just checked my receipts and yes the 10% coupon was honored from a screen shot.
   / Harbor Freight Tools that don't suck #11,819
I pull up my email on my phone and show them the add, they always honor it..
   / Harbor Freight Tools that don't suck #11,820
I got mine through email and just printed the coupon and cut it out. Worked for me.
1999 International 8000 Semi Truck (A59814)
1999 International...
30 INCH TOOTHLESS BUCKET FOR MINI EXCAVATOR (A58214)
30 INCH TOOTHLESS...
2013 Ford C-Max Energi Hybrid PHEV Hatchback (A59231)
2013 Ford C-Max...
Loader Bucket (A59228)
2008 MOTIV ALUMINUM TRAILER CO. 32 TRI AXLE GOOSENECK ENCLOSED TRAILER (A58214)
2008 MOTIV...
MARATHON 20KW GENERATOR (A55745)
MARATHON 20KW...
