   / Harbor Freight Tools that don't suck #11,781
Al, IIRC the basic saw without long table or Beismeyer fence attached is around 350-400 pounds - if your situation is a bit dicey, you can remove the top and motor - but if you do that, the top is normally held to the base with three bolts - these have loose fitting holes, and control the relationship between the blade and the miter grooves. If you just loosen and remove them, you will need to realign when you reassemble. A slightly less painful way is to scribe lines marking the top/base positioning on ALL THREE bolt holes, BEFORE you loosen them. That way if the saw WAS aligned, you can get it back pretty close or exactly as it was.
Most of the PM66's had either Leeson or Baldor motors, if yours has something else there's a good chance it got swapped. My saw is a 3 horse, leeson motor and 3 belt drive.
There's quite a bit more to setting these up if you intend to do cabinet grade work; rather than waste good HF tool time, you can PM me if you don't already know this and want more... Steve
It was cheap. $180 for the saw from a woodworking equipment auction. It has the longer fence, a side table, and a Bosch router attached to it. I'm assuming that I'm going to be doing a complete rebuild. It has a 3hp 3 phase Baldor so I'll most likely add a VFD to it.
   / Harbor Freight Tools that don't suck #11,782
Wow, almost sounds like you bought a router and they threw in the saw for free :laughing: Enjoy... Steve
   / Harbor Freight Tools that don't suck #11,785
Years ago when I worked for IBM someone thought it would be a great idea to add Leatherman multi tools in our crib. The crib held the parts needed to repair the equipment but also tools needed for the job. Two things happened. 1st a lot of people who worked there gave family Leathermans for Christmas. Secondly lots of people were cutting themselves on the extremely sharp blades.
   / Harbor Freight Tools that don't suck #11,786
I bought a coil roofing nailer, item #92359 from a pawn shop for $50.00. I just used it Sunday to put about 30 square feet of shingles on a small shed I'm building to house my Woodland Mills PTO chipper in and it worked flawlessly! I can't say how it would hold up for a contractor, but for my limited usage it is perfect. It will shoot .120 x 3/4" - 13/4" nails. I'm completely pleased with it thus far.
   / Harbor Freight Tools that don't suck #11,788
HF got a bit of my money this week. 3 20 foot chains on sale and a garden cart with the 20% off coupon. Hoping they will all get the job done.
   / Harbor Freight Tools that don't suck #11,790
2012 DIAMOND C  40FT GOOSENECK TRAILER (A58214)
2012 DIAMOND C...
Meyer 8' Snow Plow w/ Bracket (A55272)
Meyer 8' Snow Plow...
2001 Ford Crown Victoria Passenger Car, VIN # 2FAFP71W41X143155 (A57453)
2001 Ford Crown...
3ft Metal 5-Point Star Art (A55853)
3ft Metal 5-Point...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55853)
2006 iDrive...
New/Unused CFG Industrial MH12RX Mini Excavator (A57453)
New/Unused CFG...
