Contemplating and SCUT
/ Contemplating and SCUT #21
You read what I said Lol. I believe the only factory cab for under 30 hp tractors is the 2650, yes kioti has a field cab and other may have field cabs, or cabs that come with it, but what that is, is just a curtiss cab or something that factory either bolts on or ships to dealer to have installed, so essentially its aftermarket, not saying thats bad or not good, just there is only one true factory cab in the smaller tractors
Then the 2650 is what you should get
/ Contemplating and SCUT #22
The Mahindra, and the 2 separate Branson tractors have factory cabs.
Like I said, did you even look at the other tractors in the links?
Answer = No. No you did not.
Click the links for yourself and check them out.
I've looked. I'm in the researching stage. Why is it important that I respond to every post? I'll make my own decisions and don't think I need to share or feedback on every reference.
/ Contemplating and SCUT #24
I was replying to nards444 with my previous post. That was why I quoted him in my reply. He was stating that "only 1" tractor comes with a factory cab. I was just showing him that that was not the case. That's all.
/ Contemplating and SCUT #25
Like I said that just an aftermarket cab the factory is putting on, dont know who makes them but they are on mahindra, TYM etc, Not saying they arent good. Again I go back to the 2650 is the only factory cab in that class to have both AC and heat and the cab is built for the specific tractor, curved back etc. Those are the square cabs made by whoever that is put on a lot of makes and models.
I'm not saying to buy a 2650 just stating what is out there.
/ Contemplating and SCUT #26
That is very interesting. I didn't know that. How do you come by this knowledge?
And do you have a reference source?
I'm just curious.
/ Contemplating and SCUT #27
He obviously didn’t look at the Kioti field cab. Not an aftermarket cab, rather engineered and manufactured by Kioti with curved glass and style sheet metal like the factory cab. Just dealer installed.
/ Contemplating and SCUT #28
If you read earlier I stated Kioti does have a cab from the factory designated as a field cab that is dealer installed. Dealer installed is not a true factory cab and is not named as such, but is named a field cab.
/ Contemplating and SCUT #29
I'm just curious.
Well you can look by looking at specs and the machines, and talking to dealers and doing other research. Again the 2650 is the only cab at this time for this class that is installed at the factory, has both heat and AC, had a curved back window, etc. So I digress.
take a look at the TYM, Mahindras of the world with the red box cabs they are an aftermarket design that may be put on at the factory depending on make and model. If you also look the cab might be built for the machine but is more or less stuck on the tractor rather than integrated big difference, compare them sometime and youll understand what I am saying. Not saying one is better then the other, but going back to my first sentence if you want a cab that is factory, has both heat and AC and curbed glass there is only machine that has it.
/ Contemplating and SCUT #30
So you're just speculating then. No actual factual information on sources of cabs.
And yes, the 2650 has AC and heat. But we weren't talking about cabs with AC on subcompact tractors. Were we? That was something you brought up, not the OP.
OP asked about factory installed cabs with heat.
Come to me with facts, not opinions. Or say, "I think... ", which is fine.
And if the FACTORY puts the cab on the tractor, isn't it a FACTORY CAB tractor? How do you KNOW each one of those cabs weren't specifically made for the specific model it is factory installed on? I mean KNOW, not speculate?
Really don't see where you're going with all this?
/ Contemplating and SCUT #31
Not going anywhere. pointed out simple facts. Go look at Mahindra, TYM, etc at their cabs sometime and then look at others that are factory that will tell you right there. Kioti is a field cab not put on by the Factory, TYM doesnt put cabs on anything until you get to the 39 hp version, same with Mahindra. Maybe they are provided by the factory, but those red boxed cabs are clearly an after thought on those tractors in the sub compact class, which again doesnt make them bad or not as good.
Take it for what it's worth, if you want a sub compact/compact tractor under the 20 hp that has both heat and AC, installed and designed by the factory with a curved back the kubota 2650 is the only tractor to do so right now. Simple fact there. take it for what it is worth. Yes there are field cab options for a few models and brands, but they are the boxy run of the mill cabs found on anything, JD has the same things except there are curtiss and come in green or yellow.
40ft High Cube Shipping Container (A65583)
40ft High Cube...
2000 FORD F-550 XL SUPER DUTY DUALLY SERVICE TRUCK (A60430)
2000 FORD F-550 XL...
(2) Denman Tires w/Rims (A64127)
(2) Denman Tires...
2003 Toyota Tundra Extra Cab Pickup (A62613)
2003 Toyota Tundra...
Caterpillar 446B Backhoe (A66285)
Caterpillar 446B...
2013 PETERBILT 367 (A65643)
2013 PETERBILT 367...
