Iced drive
/ Iced drive #1
jpm
Redbud.southern vt
4110 mahindra
How do others deal with iced drives? I was reading one member used their power rake to break up his ice, has anyone used a pulverizer to break ice? I have used a box blade with the rippers down and it chipped some but it bounced slot also . Or has anyone tried a tiller?
/ Iced drive #2
I have a heavier box and use the rippers. The snow melt doesn’t really work below about 25°f. I’ve spread a bit of driveway material (5/8” minus) that I keep stockpiled. That works well too.
In the spring I’ll put ice melt on in the morning and rip in the afternoon. The surface is still frozen but it seems to be melted between the road and ice on top.
/ Iced drive #3
Welcome to the real winter world.
Chains, salt and or small crushed stone are your friends, that or patience and spring will soon come.
/ Iced drive #4
I have a mile long gravel driveway. Occasionally a big field of snow will melt - drain down on the driveway and freeze. It's on the down slope into the only valley on the driveway. I've used sand or gravel or wood chips or wood pellets. All work pretty well on this 100 foot section. Usually the driveway ditch handles this melt water - sometimes not so much.
/ Iced drive
Oh I have all the normal stuff ,studded snows ,studded chains ,plows ,blowers ECT . I'm talking freezing rain on zero degree frozen ground back to zero three inch thick stuff. You can't even walk on it stuff .The sand is under all frozen so life sucks type of ice.
/ Iced drive #6
If ice soft I rough it up with tire chains,if not heavy layer sandy grit.
/ Iced drive #7
That's why I prefer small crushed stone as it protrudes that ice coating and won't wash away on slopes.
The road contractors also keep a stash 4 those freezing rain events.
Also some box stores offer crushed smelter slag that is in the 1/4 or so size in 20 lb sacks.
That is the best of the best and worth every $ they get.
Generally 1 bag or 2 last me the winter as you spread it like salt and pepper eg very sparingly.
I also keep an approximately 1 gal in my car all winter 'just in case'. (along with booster cables and a tow line)
I'm that 'good Samaritan' as I seem to rescue a 1/2 dz every winter here in the back roads.
/ Iced drive #8
Our road is to long to sand so it stays bare. I drive up hill on an iced road like a bottle in my wife's CRV or my P/U with 4WD and studded tires all around no problem. It is generally only like that for a couple days. Running over that type of ice with my tractor chains to rough it up and make some chips which act like sand helps a lot to.
EDIT: sand is the real answer if you already use it but there will always be times it is getting covered over with freezing rain quicker than it can be spread. Keep a pair of ice micro-spikes for your boots in the car so you can park the car and walk up the drive home.
gg
/ Iced drive #9
Sand for the driveway and sidewalks when needed.
A sealed container of kitty litter in each vehicle during the winter.
Wife has the slip on spikes for her walks.
/ Iced drive #10
My driveway gets iced up at times from wet snows or freezing rain.
My tractors have excellent chains, the old plow/sander truck has 2 link spaced square link chains,
and the pickup and other 4wd or awd vehicles run studded tires.
I have seen times when the studs were inadequate on the highway vehicles,
that usually happens during a freezing rain storm when it also becomes quite difficult to even walk up the driveway.
I have been able to make it up on foot most times walking in my ditches with difficulty, The other alternative
is I call my brother with a chained truck or tractor or my nephews with a snowmobile with a studded track.
Once I get to the top my sand pile is accessible, I keep a good sized pile of treated sand (salted) under a plastic cover
for winter use.
In this picture I'm actually loading coal ash from my coal insert to spread on the driveway.
/ Iced drive #11
Ash from my wood boiler goes straight onto my very steep driveway.
/ Iced drive #12
Wood ashes, coal ashes work fine for me. The pellet ash goes furthest out, it is pretty fine and inky. The Missus does not like it in the house.
/ Iced drive #14
Boxblade with scarifiers down and wood stove/grill ashes work for me.
Decent slip-on traction aids for footwear outside. One must be very careful about the quality of some Chinese-made knockoff products.
/ Iced drive #16
It's just a matter of how much do you want to spend.
Enter the infrared heater...Problem solved.
/ Iced drive #18
I've used box blade scarfiers on some drives for some neighbors with steep gravel that got iced up. RIP until some of the gravel is pulled up & mixed in, or at least the ice is roughed up. No way I'd mangle my tiller on ice. Tillers just arent designed for that hard of material.
A lot of cold & snow here in Colorado, but rarely enough sustained issues for ice. The elevation & UV melt ice (and to a lesser degree snow) off in a hurry. Sand is the usual temporary solution & darkens up the ice to make it melt faster as a side benefit.
Today is a high of 80, tomorow high of 25 & 2-4" of snow. This weekend will be back I to the 70s. Spastic weather up here.
/ Iced drive
I had hoped there was something else i hadn't thought of short of a mig jet engine but no such luck. I'm going back to basics with a truck load of very course 3/8 stone
And build something over it.
/ Iced drive #20
In the end, there’s not really much you can do other than wait for it to melt. Even if you did melt your driveway, the roads would probably be iced over too.
2017 CATERPILLAR 120M2 MOTORGRADER (A52709)
2017 CATERPILLAR...
2018 RoGator 1100C (A61307)
2018 RoGator 1100C...
4019CFL (A59228)
4019CFL (A59228)
2015 Kubota RTV-X900 4x4 Diesel Utility Cart (A59228)
2015 Kubota...
MORBARK WOOD HOG 6400 XT HORIZONTAL GRINDER (A60429)
MORBARK WOOD HOG...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC55 55ft. Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
