light staying on.
/ light staying on. #1
bronco2
swva.
kioti lk3054
why does my lighting volt light stay on all the time? is that a charging issue or what? thanks
/ light staying on. #2
Welcome to TBN & the forum bronco2. Simple answer - your system is not charging. The reasons are just a few. Look in your owner's manual and see what it says. Most likely - a problem with the alternator or with the battery. Check that the ground wire off the battery is in good shape and where it connects to the frame is not corroded. Take the battery to a "battery store" and have it checked. Around here - I would suggest Les Schwab.
/ light staying on.
i have a brand new battery in it. i will check the voltage in a bit and the ground cable. thanks for the help sir
/ light staying on.
check the ground. all good there. at 1500 rpm's it is putting out 15.1 volts.
/ light staying on. #5
Well, it's over charging then, which can ruin your battery if you run it for long period of time.
/ light staying on.
not sure what to do about that
/ light staying on. #7
It's either a bad wire somewhere to the regulator or the regulator itself is not right.
/ light staying on.
i will check it . thanks
/ light staying on.
i cant find anything
/ light staying on. #10
What did you look for? If you're testing the regulator, is the alternator continuously charging the battery at above 15 volts? It shouldn't exceed 14.5 volts for normal charging. Recommend changing out the alternator.
/ light staying on. #11
Did you check the voltage at the battery and not the alternator lug?
New/Unused Mini Skid Steer Mounting Plate (A65583)
New/Unused Mini...
2015 Caterpillar 308E (A64126)
2015 Caterpillar...
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2020 CHEVROLET...
Preliminary Listing / Full Catalog Coming Soon! (A62177)
Preliminary...
CATERPILLAR D1 CRAWLER DOZER (A65053)
CATERPILLAR D1...
Approximately 100 Ratchet Tie Downs (A65579)
Approximately 100...
